Home Assistant : 401 unautorized
I’m posting this because I’m completely blocked.
I tried to configure HA to access it away from home, using duckdns.
I now cannot do anything…
Trying to access https://MyIP.local:8123 -> 404: not found
Trying to access https://MyIP.local:8123/api/ -> 401: Unauthorized
Does anyone knows what to do?
ssh possible?
make sure HA is running
what did you recently change? undo it!!
READ THE FORUM GUIDES
no info = no reply
*hint: post config of what you did when you refer to “I tried to configure…”
Sorry i try to do my best.
I installed last version of HA on a raspberry pi 3 b+
I’m trying but I just can’t undo anything as I can’t access anything…
can you ssh?
is this new install?
If you understand french, I followed this topic
I configure the duckdsn like this
And modified the configuration.yaml adding this
http:
base_url: votre_domain.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
And I opened a port of my internet box
Yes from this week end!
Sorry I’m quite novice. What do you call ssh?
secure shell
connection using terminal/command line
have you check the http://MyIP.local:8123 connection? https not working but maybe http still working
maybe easier to start from new install
