7.1 keeps exiting on startup with Docker. I have removed all the images and re-downloaded but this doesnt help either. When I revert back to 6.6 all is good.
ee6554787e96 homeassistant/raspberrypi3-homeassistant:stable “/init” 15 seconds ago Exited (129) 6 seconds ago home-assistant
so adding that allowed the container to start up but now there is no internet connectivity past local connectivity so some of my integrations wont work along with nabu.casa
sudo docker run --init -d --name=“home-assistant” --privileged -e “TZ=America/Chicago” -v /home/pi/:/config --network=host --device /dev/ttyUSB0 --device /dev/ttyUSB1 homeassistant/raspberrypi3-homeassistant:stable
I should add reverting back to 6.6 brings the Internet back and all integrations working. The only difference would be I am running the above command without privileged on 6.6
You can also see I have network connectivity but Home-assistant doesnt think so.
docker exec -it homeassistant /bin/bash
bash-5.1# ping google.com
PING google.com (142.250.138.101): 56 data bytes
64 bytes from 142.250.138.101: seq=0 ttl=103 time=30.042 ms
64 bytes from 142.250.138.101: seq=1 ttl=103 time=31.918 ms
64 bytes from 142.250.138.101: seq=2 ttl=103 time=27.824 ms
64 bytes from 142.250.138.101: seq=3 ttl=103 time=30.415 ms
64 bytes from 142.250.138.101: seq=4 ttl=103 time=28.201 ms
^C
— google.com ping statistics —
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 27.824/29.680/31.918 ms
bash-5.1# ping 192.168.1.254
PING 192.168.1.254 (192.168.1.254): 56 data bytes
64 bytes from 192.168.1.254: seq=0 ttl=254 time=9.016 ms
64 bytes from 192.168.1.254: seq=1 ttl=254 time=4.786 ms
64 bytes from 192.168.1.254: seq=2 ttl=254 time=5.121 ms
