Home Assistant 7.1 > Super Slow
Raspberry Pi 4 8GB
System Health
version: core-2021.12.7
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
user: root
virtualenv: false
python_version: 3.9.7
os_name: Linux
os_version: 5.10.63-v8
arch: aarch64
timezone: Europe/Dublin
GitHub API: ok
Github API Calls Remaining: 4493
Installed Version: 1.18.0
Stage: running
Available Repositories: 999
Installed Repositories: 20
logged_in: false
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: failed to load: timeout
host_os: Home Assistant OS 7.1
update_channel: stable
supervisor_version: supervisor-2021.12.2
docker_version: 20.10.9
disk_total: 57.8 GB
disk_used: 32.3 GB
healthy: true
supported: true
board: rpi4-64
supervisor_api: ok
version_api: ok
installed_addons: Samba share (9.5.1), Nginx Proxy Manager (0.11.0), MariaDB (2.4.0), File editor (5.3.3), SSH & Web Terminal (10.0.0), Node-RED (10.3.0), Z-Wave JS to MQTT (0.32.2), Z-Wave JS (0.1.51), Studio Code Server (3.7.0), Emulated HUE (0.2.10), AdGuard Home (4.4.2)
can_reach_server: ok
dashboards: 1
resources: 11
mode: storage
I just updated to 7.1my system is super slow, even turning a light on and off (Zigbee) have a 5 seconds delay…
navigating to the interface is super slow too…
There are 2 things that may help.
  1. Reboot the system if you have not already.
    2, Upgrade to the latest patch release 2021.12.7 The release Notes indicate many thread related issues that have been resolved.
Thank you, I’ll try this
I also have a slow system after updating from 7.0 to 7.1.
I also see in my firewall a lot of lines of an ip v6 address that are blocked. As soon as I remove Home assistant from the network, the notifications in the firewall also disappear.
I can’t explain this, maybe one of you.
First of all, unless you are running IPv6 on your home network, disable IPv6 on your HA server, It is not needed and will not be used.
Since I do not yes run IPv6 ( my ISP does not support it) I cannot advise further.
mine keep rebooting in loop
Where do I disable IPv6 on my HA server?
How did you install HA? the process varies depending on the operating system.
I have installed home assistant operating system on a raspberry pi 4b with ssd
found it, disabled and no more notifications in my firewall. thanks.
OK so I assume you used the HaOS image installation. Glad you got it resolved.
Did that resolve the slow performance issue? Can you elaborate where/how you found and disabled IP6?
Btw to disable IPv6 : configuration /add-on backup and supervisor/ system > IP adress
no that did not resolve the performance issue
After I updated HA to 2021.12.8 I have no more performance issues.
