How to access your Home Assistant from outside of your home (on Mobile network). I can access on wifi but not out side of wifi network.
Thereās existing documentation that summarises the process. If you want to have authentication (and SSL) remotely, but not internally, then youād want to use something like nginx.
Iāve created a comprehensive guide to external access with SSL that will be part of the documentation in the near future. Thereās still a few minor formatting issues with the page but it should be sufficient to follow at this pointā¦
link removed, scroll down for new link
Hope this helps.
Or you can use TOR. Not that I have done it.
You rock! I have spent a couple of days trying to implement SSL with no luck. Your instructions worked first time out. I did have to restart the ssh service after making user āhomeassistantā a sudo group member.
Thanks for being my first guinea-pig
Glad that it helped, can I ask how long it took you from start to finish? Iām conscious itās a long guide so I was thinking of putting a line at the top saying something like āthis will take about 40 minutesā or whatever.
Iām new to Pi and Raspbian and was researching users and groups in my journey to implement SSL. I took my time because I didnāt want to blow-up my installation. My best guess for a newbie would be approx. 60 minutes.
Cheers ![]()
My guide is now in the official docs, thereās still a few spelling mistakes and minor formatting errors (sorry!) that Iāll fix next week, but it should be all good to follow now.
From a security stand point itās best not to expose your home assistant device to the internet at all, even if you are forwarding through your firewall, encrypting, etc. If your router supports it setup a vpn server. Also password protect home assistant. To access it from outside your network youāll open a vpn connection then sign in to home assistant. Because youāre traversing a secure vpn tunnel you donāt need to enable https, but you can if you want to.
is there a good way to avoid exposing HA to the internet and still working with IFTTT? I just migrated from openhab and have it set up exactly like you just mentioned (via VPN), but I was hoping to set up triggers and automations via IFTTT for stuff like tracking when the last family member leaves home via Life360ā¦but Iām hesitant to expose it to the internet at all.
My HASS has access out to the internet so I can send to IFTTT but I havenāt sent anything back inside. For now for presence tracking Iām using wifi and cell phones. On wifi = home and off wifi = away. You can group all the devices and if any one of them is home the group = home if all are away the group = away. Iād be curious if you find a different way to do it thatās secure.
Has anyone tried TeamViewer? https://www.teamviewer.com/en/use-cases/remote-access/
I used to use it extensively in the past. Removed it from all my machines after there was a security issue. That was awhile ago though so things may be fixed now.
It was great for providing tech support for the older family members, I could log in from anywhere and troubleshoot their issue. I fixed an issue for my wife once while in a bar using team viewer from my iphone.
Teamviewer might be overkill vs using VPN on your router. Although if your router doesnāt have that feature itās another option. I would imagine itās still more secure than exposing your pi to the internet. For me, if Iām just checking the status of the system and sensors and such vpn works well and doesnāt require modifying my pi/hass installation.
what about something like setting up an e-mail client somewhere on the network as a bridge, and use an e-mail address thatās only for IFTTT? IFTTT sends an e-mail to that e-mail address when everyone leaves home, client sees that e-mail comes in and fires off some sort of trigger to HAā¦
how hardened/secure is this? I have been really trying to avoid poking holes in my firewall, but I really would like to use IFTTT ā¦
Hello. I have the same problem.
I can access outside my network but only if itās an wifi connection.
If I connect for example to my work wifi, I can access the home assistant without any problem but if the mobile connection is 3g or 4g it stops asking password (I also disabled password for testing and itās the same)
If you are an iOS user then Homebridge is another way to get external control of some HASS features
thank you but iām using android.
the problem is that it connectās if i use any wifi connection (not my home one).
It canāt connect only if iām using the mobile connection.
