Home Assistant Add-On Immich
I have been trying on and off for a few months to run this add-on.
Unfortunately every version released so far, results in the same issue for me.
The log says the database cannot be reached, rretrying.
There is nothing in the instructions to change the database host name, port or anyhting else so I have tried the defaults and also changing the hostname to the local ip address. Both have the same issue.
Any ideas or tips?
DB Hostname tryed:
127.0.0.1
192.168.0.4
homeassistant.local
All fail
[Nest] 1140 - 08/18/2024, 12:51:09 AM ERROR [TypeOrmModule] Unable to connect to the database. Retrying (1)…
Error: connect ECONNREFUSED 127.0.0.1:5432
Paul
Do you mean this: GitHub - outadoc/immich-home-assistant: Home Assistant component to display random pictures from your Immich library.
hassio-addons/immich at master Ā· alexbelgium/hassio-addons (github.com)
did you read this line in the docs linked above?
Beware that you need to install a separate postgres addon to be able to connect the database. You can install the postgres addon already in my repository. Beware to change the password BEFORE starting it ; it won’t change afterwards
Also it may need the port number 2283. I have immich installed in on a separate server and it runs on that port.
So you seem to have a habit to create topics, ask for help but you lack the decency to react to any effort to help you, let alone show your gratitude and just stay silent even though you are active on the forum!?
Some character…
Hi everyone I made a repository :package: with a bunch of easy to use all-in-one addons, including Immich :camera_flash:
It’s easier to configure because you don’t have to mess around with Postgres and Redis as they are built in.
And backups and restores are just a simple addon backup and restore without worrying to break any data stored inside Postgres or Redis.
Check it out and if you like the idea maybe you can help me maintaining it or expanding the documentation.
Others addons (all-in-one) that you can find are: Paperless-ngx, Nextcloud, Gitlab, Syncthing and others
Now I’m currently working on Gitea, but if you have other requests feel free to submit them :hugs:
Hi Fabio,
I was earlier using the Immich package from alexbelgium, and I was trying to use the immich app from your repository, because of the all-in package, but i received an error when I try to start it:
Data page checksums are enabled.
initdb: error: directory ā€œ/config/postgresā€ exists but is not empty
initdb: hint: If you want to create a new database system, either remove or empty the directory ā€œ/config/postgresā€ or run initdb with an argument other than ā€œ/config/postgresā€.
Can you help me with this error? Do i need to manually remove some files that was earlier created by the postgres addon (from alexbelgium)? I cannot find a folder /config/postgres…
Thanks in advance
You are right, my bad.
Now it’s fixed
still the same, after updating to 1.124.2-v0
EDIT: had to remove the addon_config/postgres folder manually and restart the addon fixed the issue.
Thank you!
Hi Fabio,
thank you so much for your work, I’m quite new to HA but slowly I’m learning…
Everything works for me, but I have two questions, is there a way to change the default folder where the photos are saved (like on an external HD)?
I saw that in external libraries it is possible to insert your own path, but I don’t know how to indicate a simple HD connected directly to a Raspberry 4…
Second, is it possible to integrate a cloud backup? or is there any way to bind it?
To avoid both problems, I had thought of mounting the Raspberry SD as large as possible and thus avoiding having to specify an external HDD. At this point, when Home Asssistant backs up to OneDrive, it should also bring all the contents of immich right?
A thousand thanks!
At the moment Immich stores its library under /media/immich and can’t be changed as it would break Immich
HA OS doesn’t let you specify where to mount your usb drive, so the only thing you could use it for is as an external library (can’t upload to it)
If you want to mount a usb drive to ha, you can follow this:
My advice is to use a nas if you can
Regarding backups, if your immich folder isn’t on any external storage, it will be included in the ha full backups
Dare I ask here, but I am using HAOS native on a n100 box, installed your immich add on, and it is working. Is there a simple way to add some yaml config so it uses the n100 gpu for hardware acceleration?
Is there a complete walk through of setting Immich up in HAos? I checked around and could not find much about it. Also there is more than one version, which one is the one to use?
versionsImmich
I managed to get immich setup and running but I would like to change the default photo storage location of Immich. I am running immich in HAos and there is a setting in the Configuration section for: library_location which I have set to: /192.168.1.80/HD8TB/immich
I have tried all combinations for data_location, library_location and localdisks, but all fail to work.
These are the errors I get and the local disk mounting successfully:
[08:07:16] WARNING: Library folder in /share/immich/library already exists, is a real folder, and is not empty. Moving to /share/immich/library_old
[Nest] 1314 - 04/28/2025, 8:08:06 AM ERROR [Api:StorageService] Failed to read /share/immich/library/.immich: Error: ENOENT: no such file or directory, open ā€˜/share/immich/library/.immich’
[Nest] 1641 - 04/28/2025, 9:11:18 AM ERROR [Api:StorageService] Failed to read /192.168.1.80/HD8TB/immich/encoded-video/.immich: Error: ENOENT: no such file or directory, open ā€˜/192.168.1.80/HD8TB/immich/encoded-video/.immich’
[Nest] 1641 - 04/28/2025, 9:11:18 AM LOG [Api:StorageService] Verifying system mount folder checks, current state: {ā€œmountChecksā€:{ā€œthumbsā€:true,ā€œuploadā€:true,ā€œbackupsā€:true,ā€œlibraryā€:true,ā€œprofileā€:true,ā€œencoded-videoā€:true}}
api worker exited with code 1
Starting api worker
[09:09:29] INFO: Available Disks for mounting :
NAME LABEL SIZE FSTYPE RO
ā”œā”€sda2 24M squashfs 0
ā”œā”€sda3 256M erofs 0
ā”œā”€sda4 24M squashfs 0
ā”œā”€sda5 256M erofs 0
└─sdb1 HD8TB 7.3T ext4 0
└─sdc1 HD3TB 2.7T ext4 0
Supported fs : ext3 ext2 ext4 squashfs vfat msdos iso9660 erofs ntfs3 exfat btrfs
Inspired from : dianlight (Lucio Tarantino) Ā· GitHub
Local Disks mounting…
… HD8TB is a device by label
[09:09:29] INFO: Mounting HD8TB of type ext4
[09:09:29] INFO: Success! HD8TB mounted to /mnt/HD8TB
@fabio-garavini thanks a lot for composing and creating the immich add-on. works like a charm! :slight_smile: :+1:just out of the box, incl immich folder on my NAS.
Thanks again :pray:
and no, no question or issue - just a thank you :wink:
Would immich work if /media/immich was a symbolic link to /data/immich?
No because also /data/immich should be mounted inside the addon and hassio doesn’t let you do it
/data is a persistent mount for addons.
Yes but is not mounted where you think. The addon’s /data folder is actually mounted on the HA host at <hassio folder>/addons/data/<addon name> which on HA OS is not accessible from the user. Other folders can be mounted inside a addon, like /config on the latest versions is mounted /addons_config/<addon name> (HA OS)
