Home Assistant Add-on: OpenSpeedTest
Free & Open-Source HTML5 Network Performance Estimation Tool.
About
This uses the latest official unmodified Docker image of OpenSpeedTest as a Home Assistant Add-on.
Allows testing the network speed between any device in your local network and the device that runs Home Assistant. This is an alternative to running iperf3 server on the Home Assistant server and iperf3 client on another device in your local network. Advantage is that testing is done via your browser.
See https://openspeedtest.com/
Installation
If you want to do add the repository manually, please follow the procedure highlighted in the Home Assistant website . Use the following URL to add this repository: https://github.com/tronikos/home-assistant-addons
Refresh your browser and install the add-on from the new repository.
How to use
Just install, start the container and click on “Open Web UI”.
Example
Again, this tests the network speed between any Web client and your Home Assistant server. It doesn’t test your internet speed. This is helpful e.g. for finding the best location of mesh wireless access points or repeaters.
