Home Assistant Add-on: rtl_433 with MQTT auto discovery
Hi there.
How can I point this to install a newer version of the rtl_433? the Govee leak sensors are all now shipping with a new protocol, so they won’t work with this version and we need to apply the changes in a branch or wait for the master to pull.
Any chance you quickly update this when rtl_433 has a new pull? I know a lot of people use this for the govee detectors and the change is going to make it very difficult for new devices/users until we have that branch wrapped into this add-on.
Thanks for the work!
I’m working on a PR to do this at Build both a specific commit and master of rtl_433 by deviantintegral · Pull Request #129 · pbkhrv/rtl_433-hass-addons · GitHub. I actually fell down a rabbit hole where for some reason the docker image cache isn’t working on builds, which really speeds up the arm builds. I think I’ll probably postpone getting that working since it works, but is just slow.
That’s awesome! You’ll have to excuse me since I’m a real newbie at this. What does your reply actually mean? I should update this add-on and it’ll work? or do I need to point at a different repository?
Thanks! Sorry to have NO clue how to work on this…really dove into the deep end on this one.
In summary: I’m working on making it easier and automatic for new releases of rtl_433 to be included in the addon. But, it’s not done yet.
Amazing. Thank you!
Hi Guys,
I’m really keen to get my electricity data in to HA, I have a clamp style meter and am in the UK.
I see the readings and a current value in the data but it’s not automagically working - can anyone help me get this working please?
Debug mode shows the value within the data. e.g. 2.9 or 2.7 but the message says skipped!?
Any tips please?
INFO:root:Enabling debug logging
INFO:root:Discovering all devices
DEBUG:root:MQTT Client: Starting Loop
DEBUG:paho.mqtt.client:Sending CONNECT (u1, p1, wr0, wq0, wf0, c1, k60) client_id=b''
DEBUG:paho.mqtt.client:Received CONNACK (0, 0)
INFO:root:MQTT connected: Connection Accepted.
INFO:root:Subscribing to: rtl_433/+/events
DEBUG:paho.mqtt.client:Sending SUBSCRIBE (d0, m1) [(b'rtl_433/+/events', 0)]
DEBUG:paho.mqtt.client:Received SUBACK
DEBUG:paho.mqtt.client:Received PUBLISH (d0, q0, r1, m0), 'rtl_433/9b13b3f4-rtl433/events', ...  (105 bytes)
DEBUG:root:MQTT message: "{\"time\":\"2023-01-25 08:59:03\",\"model\":\"Clipsal-CMR113\",\"current_1_A\":2.7,\"current_2_A\":0,\"current_3_A\":0}"
DEBUG:root:homeassistant/sensor/Clipsal-CMR113/Clipsal-CMR113-UTC/config:{"device_class": "timestamp", "name": "Clipsal-CMR113-UTC", "entity_category": "diagnostic", "enabled_by_default": false, "icon": "mdi:clock-in", "state_topic": "rtl_433/9b13b3f4-rtl433/devices/Clipsal-CMR113/time", "unique_id": "Clipsal-CMR113-UTC", "device": {"identifiers": ["Clipsal-CMR113"], "name": "Clipsal-CMR113", "model": "Clipsal-CMR113", "manufacturer": "rtl_433"}}
DEBUG:paho.mqtt.client:Sending PUBLISH (d0, q0, r0, m2), 'b'homeassistant/sensor/Clipsal-CMR113/Clipsal-CMR113-UTC/config'', ... (377 bytes)
INFO:root:Published Clipsal-CMR113: time
INFO:root:Skipped Clipsal-CMR113: current_1_A, current_2_A, current_3_A
DEBUG:paho.mqtt.client:Received PUBLISH (d0, q0, r0, m0), 'rtl_433/9b13b3f4-rtl433/events', ...  (105 bytes)
DEBUG:root:MQTT message: "{\"time\":\"2023-01-25 08:59:15\",\"model\":\"Clipsal-CMR113\",\"current_1_A\":2.9,\"current_2_A\":0,\"current_3_A\":0}"
DEBUG:root:Discovery timeout in the future for: homeassistant/sensor/Clipsal-CMR113/Clipsal-CMR113-UTC/config
That means that the script doesn’t understand how to map current_1_A and so on to Home Assistant entities. You would have to configure them manually.
Do you know what’s meant by 1 / 2 / 3? The autodiscovery script looks like it expects only a current_A output: rtl_433/rtl_433_mqtt_hass.py at 4968419bf748ac9b5fca5ebfc267b7cd9f31c0e6 · merbanan/rtl_433 · GitHub
oh yes - not sure if it helps but the devices has three outputs that you can connect the clamp to. I’m currently in number 1.
I see the last commit on the git was a few months ago. Do we have an ETA on implementing new features from the RTL_433 git? The govee sensors will no longer work with this add-on, but have been fixed in the RTL_433 main branch.
I having problem with auto discovery:
here my details:
  • rtl 433 config:
frequency 868300000
frequency 433920000
hop_interval 60
protocol 172
protocol 12
output mqtt=http://core-mosquitto:1883,user=***,pass=***,retain=1
convert si
report_meta time:iso:tz:local
output json
  • auto discovery config:
mqtt_host: core-mosquitto
mqtt_port: 1883
mqtt_user: ***
mqtt_password: ***
mqtt_retain: true
rtl_topic: /rtl_433/+/events
discovery_prefix: homeassistant
discovery_interval: 6
force_update: false
log_level: debug
  • auto discovery logs:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
mqtt found in this Home Assistance instance.
Starting rtl_433_mqtt_hass.py...
INFO:root:Subscribing to: /rtl_433/+/events
DEBUG:paho.mqtt.client:Sending SUBSCRIBE (d0, m1) [(b'/rtl_433/+/events', 0)]
DEBUG:paho.mqtt.client:Sending PINGREQ
DEBUG:paho.mqtt.client:Received PINGRESP
  • rtl_433 logs:
[devices] Tuned to 433.920MHz.
[devices] {"center_frequency" : 433920000, "frequencies" : [868300000, 433920000], "hop_times" : [60]}
[devices] Allocating 15 zero-copy buffers
[devices] {"time" : "2023-02-06T14:50:53+0100", "model" : "Bresser-6in1", "id" : 338715378, "channel" : 0, "sensor_type" : 1, "wind_max_m_s" : 2.900, "wind_avg_m_s" : 2.800, "wind_dir_deg" : 338, "rain_mm" : 360.400, "startup" : 1, "flags" : 1, "mic" : "CRC"}
[devices] {"time" : "2023-02-06T14:51:13+0100", "model" : "Oregon-THGR810", "id" : 139, "channel" : 1, "battery_ok" : 1, "temperature_C" : 18.900, "humidity" : 74}
[devices] Tuned to 868.300MHz.
[devices] {"center_frequency" : 868300000, "frequencies" : [868300000, 433920000], "hop_times" : [60]}
[devices] {"time" : "2023-02-06T14:52:04+0100", "model" : "Bresser-6in1", "id" : 338715378, "channel" : 0, "sensor_type" : 1, "wind_max_m_s" : 2.700, "wind_avg_m_s" : 2.700, "wind_dir_deg" : 338, "rain_mm" : 360.400, "startup" : 1, "flags" : 1, "mic" : "CRC"}
[devices] {"time" : "2023-02-06T14:52:16+0100", "model" : "Bresser-6in1", "id" : 338715378, "channel" : 0, "battery_ok" : 1, "temperature_C" : 10.800, "humidity" : 72, "sensor_type" : 1, "wind_max_m_s" : 3.200, "wind_avg_m_s" : 3.100, "wind_dir_deg" : 112, "uv" : 0.000, "startup" : 1, "flags" : 0, "mic" : "CRC"}
[devices] {"time" : "2023-02-06T14:52:28+0100", "model" : "Bresser-6in1", "id" : 338715378, "channel" : 0, "sensor_type" : 1, "wind_max_m_s" : 3.200, "wind_avg_m_s" : 3.100, "wind_dir_deg" : 112, "rain_mm" : 360.400, "startup" : 1, "flags" : 1, "mic" : "CRC"}
[devices] {"time" : "2023-02-06T14:52:40+0100", "model" : "Bresser-6in1", "id" : 338715378, "channel" : 0, "battery_ok" : 1, "temperature_C" : 10.800, "humidity" : 72, "sensor_type" : 1, "wind_max_m_s" : 2.000, "wind_avg_m_s" : 1.800, "wind_dir_deg" : 315, "uv" : 0.000, "startup" : 1, "flags" : 0, "mic" : "CRC"}
[devices] {"time" : "2023-02-06T14:52:52+0100", "model" : "Bresser-6in1", "id" : 338715378, "channel" : 0, "sensor_type" : 1, "wind_max_m_s" : 0.800, "wind_avg_m_s" : 0.800, "wind_dir_deg" : 45, "rain_mm" : 360.400, "startup" : 1, "flags" : 1, "mic" : "CRC"}
  • mqtt explorer screenshot:
I cannot see no entities or devices in home assistant,
can someone help me?
found the issue:
/rtl_topic: /rtl_433/+/events -> rtl_topic: /rtl_433/+/events
Hey folks, I just released new versions of the addons. The biggest new feature is not in the addons themselves, but in new parallel addons that automatically rebuild and track rtl_433’s master branch. You do have to uninstall and reinstall the addon in HA for it to get a new version, but that matches how zigbee2mqtt works and is really a HA limitation. Hope this helps for the folks waiting for Govee sensor fixes and other updates. As always, PRs are welcome in the repo with fixes and improvements.
So, you’ll need to manually configure that clamp meter for now. If you write a patch for this upstream to the autodiscovery script, feel free to file a PR to pull it in to the addon.
SOLVED: Make sure you restart the VM (from proxmox) and add the usb-device to the VM in the proxmox options (hardware). Started up after I did that and rebooted the VM!
Original Post Below -----
I just moved over to a proxmox install. I’m on the latest (next) install and it just starts then immediately stops. No errors thrown in the add-on logs:
Starting rtl_433 with rtl_433.conf...
[rtl_433] rtl_433 version nightly-2-g371ccfd5 branch master at 202302201511 inputs file rtl_tcp RTL-SDR
[rtl_433] Use -h for usage help and see https://triq.org/ for documentation.
[rtl_433] MQTT: Publishing MQTT data to 192.168.0.190 port 1883
[rtl_433] MQTT: Publishing device info to MQTT topic "rtl_433/9b13b3f4-rtl433/devices[/type][/model][/subtype][/channel][/id]".
[rtl_433] MQTT: Publishing events info to MQTT topic "rtl_433/9b13b3f4-rtl433/events".
[rtl_433] MQTT: Publishing states info to MQTT topic "rtl_433/9b13b3f4-rtl433/states".
[rtl_433] Use "-F log" if you want any messages, warnings, and errors in the console.
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Errors are thrown in the HA logs:
Failed to to call /addons/9b13b3f4_rtl433-next/stats - Can't read stats from addon_9b13b3f4_rtl433-next: Expecting value: line 1 column 1 (char 0)
12:29:48 PM – (ERROR) Home Assistant Supervisor - message first occurred at 12:27:38 PM and shows up 3 times
Error adding entities for domain sensor with platform mqtt
12:24:51 PM – (ERROR) Sensor
Error doing job: Exception in callback MQTT._mqtt_handle_message(<paho.mqtt.cl...x7f121cebb370>)
12:24:51 PM – (ERROR) components/sensor/__init__.py
JSON result was not a dictionary
12:24:51 PM – (WARNING) MQTT - message first occurred at 12:24:50 PM and shows up 26 times
Error parsing value: 'value_json' is undefined (value: 965c92off, template: {{ value_json.code }})
12:24:51 PM – (ERROR) helpers/template.py
Template variable error: 'value_json' is undefined when rendering '{{ value_json.code }}'
New and unexpected behavior here. If I shut down the “autodiscovery” add-on all my acurite sensors update just fine until I reset the box. Then they go “undiscovered” until I boot the autodiscovery add-on back up.
Ideas?
Is mqtt_retain set in the autodiscovery config? If not, then the discovery configuration will be reset when home assistant restarts.
Hm, unknown. I think my HA got a little confused. I rebooted after configuring some other devices and the things populated after about 5 minutes. So all good! thank you for troubleshooting though!
I just want to thank you for your effort. I am using your addon over a year without a problem. And I have just found new usage for it. t There are actually arduino libraries out on the internet which enable one to send sensor data as a weather station, I have just modified my Vindriktning to send PM2.5 data as a Hideki weather station over 433MHz to HA. So instead of banging your head over distance issues with zigbee, zwave or WIFI sensors you just put together ESP/arduino+sensor configuration with powerfull enough 433MHz transmitter to cover desired distance.
How do I change temperature_C to temperature_F in my mqtt rtl_433 transactions?
This is what my rtl_433 conf looks like.
output mqtt://${host}:${port},user=${username},pass=${password},retain=${retain},events=rtl_433[/model][/id]
report_meta time:iso:usec:tz
convert si
protocol 30
protocol 40
protocol 86
protocol 192
thanks
The easiest thing to do is to convert units in Home Assistant:
It may also work if you remove convert si: rtl_433/rtl_433.example.conf at d3fb71696f1a52e8f68a67690371f5beee4f6d4d · merbanan/rtl_433 · GitHub
