Home Assistant Add-on: WireGuard UI
A basic, self-contained management service for WireGuard with a self-serve web UI.
Features
- Self-serve and web based
- QR-Code for convenient mobile client configuration
- Optional multi-user support behind an authenticating proxy
- Zero external dependencies - just a single binary using the wireguard kernel module
- Binary and container deployment
Screenshot
Installation
The installation of this add-on is pretty straightforward and not different in comparison to installing any other add-on.
- Add my Home Assistant add-ons repository to your home assistant instance.
- Install the add-on.
- Edit the configuration (see below)
- Click the Save button to store your configuration.
- Start the add-on.
- Open the webUI and adapt the software options
Configuration
Note: Remember to restart the add-on when the configuration is changed.
A little more extensive example add-on configuration:
endpoint: myautomatedhome.duckdns.org dns: 1.1.1.1
Note: This is just an example, don’t copy and paste it! Create your own!
Option: endpoint
This configuration option is the hostname that your clients will use to connect to your WireGuard add-on. The host
is mainly used to generate client configurations and SHOULD NOT contain a port. If you want to change the port, use the “Network” section of the add-on configuration.
Example: myautomatedhome.duckdns.org
, for local testing hassio.local
will actually work.
DO NOT attempt to use a URL such as a Nabu Casa endpoint, the entry needs to be either a DNS entry or IP address that is accessible by the clients.
Option: dns
(optional)
A DNS server used by the add-on and the configuration generated for the clients. This configuration option is optional but highly recommended
Network configuration/ports
Port: 51820/udp
Port of the endpoint which the clients will connect through (the port you need to forward in your router)
