Home Assistant Addon: Homepage
Homepage Add-on for Home Assistant
Hey everyone!
I created this add-on based on GetHomepage and thought why not share it so everyone can enjoy it too? :blush:
About Homepage
Homepage is a modern, fully static, fast, and secure application dashboard that is fully proxied and highly customizable.
It includes integrations for over 100+ services, multi-language support, and can be easily configured via YAML files or Docker label discovery.
Installation
  1. Add my add-ons repository to your Home Assistant add-ons.
  2. Install the Homepage add-on.
  3. Edit the add-on configuration as needed (currently you can only change the exposed port, which defaults to 3000).
  4. If you need /var/run/docker.sock access or custom icons/images, see the notes in the GitHub repo.
  5. Start the add-on.
  6. Done โ€” enjoy your new dashboard! :tada:
Editing Homepage Configuration Files
  1. Use the File Editor add-on or connect to your Home Assistant via SFTP.
  2. Navigate to your addon_config folder.
  3. Open the folder for the Homepage add-on, e.g., /addon_config/abcd123_homepage/.
  4. Edit the configuration files as needed.
    โ†’ For detailed Homepage configuration info, check: https://gethomepage.dev/configs/
GitHub Repository
More info about the add-on:
Preview
Feedback is welcome!
Let me know if you run into issues or have suggestions for future improvements.
What addons are in repo at the moment?:
Homepage
Spoolman
