Home Assistant Addon: OpenAI Codex Bridge (GPTMock)
Codex Bridge (Home Assistant Addon)
I’ve ported the well-known GPTMock application into a Home Assistant app. GPTMock itself is not forked or modified. The build installs a checksum-verified upstream repository commit and adds a small management layer for Home Assistant ingress.
This gives you the option to use your ChatGPT/Codex subscription directly within Home Assistant without paying for a separate API key.
Repository: https://github.com/h3racl3z/codex-bridge-hassio-addon
For clarity to newer and future users, I suggest including the term App in your documentation, especially in the Repo. Add-on term has been deprecated over a year ago. Also once you determine installation instructions, remember to use ones that work using the term App and not Add-on. Most of the samples you find including what an AI will build for you use the old add-on structure and will not work.
Thanks for contributing to Home Assistant Community!
