Home Assistant Addon: Traefik v3.x.x +
This is an updated Traefik addon for Home Assistant, as the previous one i was using wasn’t getting updated past v2.10.5.
I have also added some additional defaults and options to the configuration menu/s.
As of today, the updated addon will deploy v3.5.0.
About
Traefik Proxy
Traefik is a leading modern open source reverse proxy and ingress controller that makes deploying services and APIs easy. Traefik integrates with your existing infrastructure components and configures itself automatically and dynamically.
This addons has several configurable options :
  • Log Level
  • access_logs
  • forwarded_headers_insecure
  • Config File Path
  • LetsEncrypt configuration
  • Ability to add extra environment vars
  • Network Ports
Installation
  1. Add the Hass.io add-ons repository to your home assistant instance.
  2. Install this add-on.
  3. Click the Save button to store your configuration.
  4. Search and add Traefik from the addon store.
  5. Configure, then start the add-on.
  6. Check the logs of the add-on to see if everything went well.
Support
You can open an issue on GitHub, in case you ran into a bug, or maybe you have an idea on improving the addon:
excited for this
