I’m a beekeeper and I’d like to connect my hives to a Home Assistant. There are several technical solutions that allow you to monitor the condition of your beehive (temperature, humidity, weight, etc.), such as BuzzBox or Forsage.
It’s good to have an overview of what is happening in the hive, without the bees having to disturb your presence
But maybe some clever handyman could do it, like integration directly into the Home Assistant + sensor.
Yes there are a number of sensors that could easily be implemented with ESPHome. Biggest issue with wifi is its power consumption. Do you have power available at your hives?
If not, then 433MHz rf or zigbee sensors would be the go. Or zwave if you have the $
I didn’t see that you needed the weight.
Well have a look at the various “bed occupancy” threads.
Some of them are based on load cells which is what I believe you need.
Or if the actual weight is not that important just a rough number, then you can use a force sensitive resistor (they need to be connected to an analog input, ESP8266 has one, ESP32 has five or six I believe).
I know…
I laughed too when I first saw it. But now a few months later I’m in negotiations to build one.
We have an air cleaner in our bedroom. Why is that turned off all the time?
Turn it on when we are not in bed.
We have a Google home mini in our bedroom that is on lowest volume to not wake the baby.
Well… If the baby is not in bed make it louder…
Just getting into the HA myself and ran across this thread. Has anyone proceeded with implementing this type of thing? Would like to know your thoughts on the usefulness of it. I myself am intrigued by the concept. Believe I may even dabble with it in the spring when I can open a few of my hives. With the information provided above I believe I can try to put a list of equipment needs together.
I think sensors like temperature and moisture are easy enough to implement. For me, the biggest issue is weight. To keep the measurements consistent over time without drift from temp fluctuations. Does anyone have such a circuit/device in mind?
Sure, i tried a few wheatstone bridges, but they had a LOT of drift from one measurement to the next. And i do mean 1-2kg. Which is too much for a useful measurement
I, too, have been trying HX711’s and have also found drift. I feel it is related to temperature. I live in the Pacific Northwest where day/night temperature swings can exceed 40 degrees Fahrenheit. I am trying a Lamdba filter in an ESP8266 which has a BME280. Unfortunately, the scale is under a working beehive so I get variations from that. Please let me know know if you’ve tried other scale options. Thanks for your time.
