Home Assistant and Home Kit…
How do I remove an Accessory in HomeKit after it was added? When I go to HomeKit, then go to the accessory, there is no way to remove it. Just would like to remove it.
Remove the entity or domain from the HomeKit integration in Home Assistant. Reload the HomeKit Integration in Home Assistant. If the device is still showing up in the Apple Home app, you may have to unpair the bridge then add it back.
Thanks for your help…. I also found out that I need to remove the bridge in HomeKit, by going to Home Settings>Bridges> and then remove the Bridge…. I had 14 duplicate switches, but by removing the Bridge they all went away……
