I’m running HA on a ESXi machine using the OVA.
my router is based on OPNsense and is also running as a VM on the same ESXi host.
I use the NGINX plugin that is available in OPNsense to get SSL via Let’s Encrypt.
Before I enabled the reverse proxy I had everything working, all sensors (especially my location) worked on my Android 11 OnePlus8T phone (same story for my wife’s phone (all the same)).
But after changing everything to my domain name (I have split DNS set up, so my domain for HA resolves to internal IP on my internal network) (and enabling WebSockets) all seems to work fine, until I noticed my location sensor wasn’t updating anymore, again everyting else seems to work just fine. It does NOT matter if I’m on my local LAN or not.
I checked to app logs and it’s filled with this error (changed some privacy bits…):
--------- beginning of perf
07-31 13:15:34.711 7092 7576 I 111 : OptJank - continuously drops frames:4
07-31 13:18:26.729 7092 7576 I 111 : OptJank - continuously drops frames:4
07-31 13:30:15.240 7092 7576 I 111 : OptJank - continuously drops frames:4
07-31 13:30:15.266 7092 7576 I 111 : OptJank - continuously drops frames:4
--------- beginning of main
07-31 13:33:22.453 7092 13788 E sqlite3_android: ONEPLUS_NAME_PARTS_MATCH SQLITE_OK
07-31 13:33:22.466 7092 7092 D ViewRootImpl[WebViewActivity]: windowFocusChanged hasFocus=false inTouchMode=true
07-31 13:33:22.468 7092 13788 E sqlite3_android: ONEPLUS_NAME_PARTS_MATCH SQLITE_OK
07-31 13:33:22.589 7092 18670 D SensorWorker: Updating all Sensors.
07-31 13:33:22.590 7092 19047 I WM-Processor: Moving WorkSpec (e6646f84-37dd-4502-8163-b987c057843f) to the foreground
07-31 13:33:22.593 7092 7092 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android/androidx.work.impl.foreground.SystemForegroundService (has extras) }
07-31 13:33:22.626 7092 7092 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
07-31 13:33:22.639 7092 7092 D LocBroadcastReceiver: Not requesting accurate location, last accurate location was too recent
07-31 13:33:22.666 7092 18670 D UrlRepository: localUrl is: false and usesInternalSsid is: true
07-31 13:33:22.709 7092 18670 E SensorReceiver: Exception while updating sensors.
07-31 13:33:22.709 7092 18670 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: retrofit2.HttpException: HTTP 403
07-31 13:33:22.709 7092 18670 E SensorReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.updateSensors(IntegrationRepositoryImpl.kt:519)
07-31 13:33:22.709 7092 18670 E SensorReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl$updateSensors$1.invokeSuspend(Unknown Source:15)
07-31 13:33:22.709 7092 18670 E SensorReceiver: at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
07-31 13:33:22.709 7092 18670 E SensorReceiver: at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:104)
07-31 13:33:22.709 7092 18670 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(CoroutineScheduler.kt:571)
07-31 13:33:22.709 7092 18670 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(CoroutineScheduler.kt:750)
07-31 13:33:22.709 7092 18670 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(CoroutineScheduler.kt:678)
07-31 13:33:22.709 7092 18670 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(CoroutineScheduler.kt:665)
07-31 13:33:22.709 7092 18670 E SensorReceiver: Caused by: retrofit2.HttpException: HTTP 403
07-31 13:33:22.709 7092 18670 E SensorReceiver: at retrofit2.KotlinExtensions$await$2$2.onResponse(KotlinExtensions.kt:53)
07-31 13:33:22.709 7092 18670 E SensorReceiver: at retrofit2.OkHttpCall$1.onResponse(OkHttpCall.java:161)
07-31 13:33:22.709 7092 18670 E SensorReceiver: at okhttp3.internal.connection.RealCall$AsyncCall.run(RealCall.kt:519)
07-31 13:33:22.709 7092 18670 E SensorReceiver: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
07-31 13:33:22.709 7092 18670 E SensorReceiver: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
07-31 13:33:22.709 7092 18670 E SensorReceiver: at java.lang.Thread.run(Thread.java:923)
07-31 13:33:22.711 7092 19046 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=e6646f84-37dd-4502-8163-b987c057843f, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
07-31 13:33:22.713 7092 7092 I WM-SystemFgDispatcher: Stopping foreground service
07-31 13:33:24.456 7092 13788 E sqlite3_android: ONEPLUS_NAME_PARTS_MATCH SQLITE_OK
07-31 13:33:24.462 7092 13788 E sqlite3_android: ONEPLUS_NAME_PARTS_MATCH SQLITE_OK
07-31 13:33:41.070 7092 7092 D LocBroadcastReceiver: Got single accurate location update: Location[fused 10,517606,3,876328 hAcc=12 et=+46d2rye4m12s658ms alt=20.80231479884924 vel=0.044443576 bear=122.52486 vAcc=22 sAcc=??? bAcc=??? {Bundle[mParcelledData.dataSize=52]}]
07-31 13:33:41.070 7092 7092 D LocBroadcastReceiver: Location accurate enough, all done with high accuracy.
07-31 13:33:41.070 7092 7092 D LocBroadcastReceiver: Last Location:
07-31 13:33:41.070 7092 7092 D LocBroadcastReceiver: Coords:(20.5176063, 10.8763277)
07-31 13:33:41.070 7092 7092 D LocBroadcastReceiver: Accuracy: 30.053
07-31 13:33:41.070 7092 7092 D LocBroadcastReceiver: Bearing: 115.52486
07-31 13:33:41.070 7092 7092 D LocBroadcastReceiver: Begin evaluating if location update should be skipped
07-31 13:33:41.070 7092 7092 D LocBroadcastReceiver: Received location that is 1224 milliseconds old, 162774419846 compared to 162441221070 with source fused
07-31 13:33:41.071 7092 18670 D UrlRepository: localUrl is: false and usesInternalSsid is: true
07-31 13:33:41.079 7092 7092 D LocBroadcastReceiver: Received location update.
07-31 13:33:41.081 7092 7092 D LocBroadcastReceiver: Last Location:
07-31 13:33:41.081 7092 7092 D LocBroadcastReceiver: Coords:(42.5176116, 41.8763221)
07-31 13:33:41.081 7092 7092 D LocBroadcastReceiver: Accuracy: 4.228
07-31 13:33:41.081 7092 7092 D LocBroadcastReceiver: Bearing: 0.0
07-31 13:33:41.081 7092 7092 D LocBroadcastReceiver: Begin evaluating if location update should be skipped
07-31 13:33:41.081 7092 7092 D LocBroadcastReceiver: Skipping old location update since time is before the last one we sent, received: 162773111324 last sent: 16274441221070
07-31 13:33:41.097 7092 7092 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
07-31 13:33:41.133 7092 18670 E LocBroadcastReceiver: Could not update location.
07-31 13:33:41.133 7092 18670 E LocBroadcastReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request update_location
07-31 13:33:41.133 7092 18670 E LocBroadcastReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.updateLocation(IntegrationRepositoryImpl.kt:184)
07-31 13:33:41.133 7092 18670 E LocBroadcastReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl$updateLocation$1.invokeSuspend(Unknown Source:15)
07-31 13:33:41.133 7092 18670 E LocBroadcastReceiver: at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
07-31 13:33:41.133 7092 18670 E LocBroadcastReceiver: at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:106)
07-31 13:33:41.133 7092 18670 E LocBroadcastReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(CoroutineScheduler.kt:571)
07-31 13:33:41.133 7092 18670 E LocBroadcastReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(CoroutineScheduler.kt:750)
07-31 13:33:41.133 7092 18670 E LocBroadcastReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(CoroutineScheduler.kt:678)
07-31 13:33:41.133 7092 18670 E LocBroadcastReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(CoroutineScheduler.kt:665)
07-31 13:34:01.045 7092 7092 D LocBroadcastReceiver: Received location update.
07-31 13:34:01.053 7092 7092 D LocBroadcastReceiver: Last Location:
07-31 13:34:01.053 7092 7092 D LocBroadcastReceiver: Coords:(10.5176038, 4.8763263)
07-31 13:34:01.053 7092 7092 D LocBroadcastReceiver: Accuracy: 24.253
07-31 13:34:01.053 7092 7092 D LocBroadcastReceiver: Bearing: 15.51984
07-31 13:34:01.053 7092 7092 D LocBroadcastReceiver: Begin evaluating if location update should be skipped
07-31 13:34:01.053 7092 7092 D LocBroadcastReceiver: Received location that is 16053 milliseconds old, 14444000 compared to 1444731241053 with source fused
07-31 13:34:01.055 7092 18670 D UrlRepository: localUrl is: false and usesInternalSsid is: true
07-31 13:34:01.096 7092 18670 E LocBroadcastReceiver: Could not update location.
07-31 13:34:01.096 7092 18670 E LocBroadcastReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: Error calling integration request update_location
07-31 13:34:01.096 7092 18670 E LocBroadcastReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.updateLocation(IntegrationRepositoryImpl.kt:184)
07-31 13:34:01.096 7092 18670 E LocBroadcastReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl$updateLocation$1.invokeSuspend(Unknown Source:15)
07-31 13:34:01.096 7092 18670 E LocBroadcastReceiver: at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
07-31 13:34:01.096 7092 18670 E LocBroadcastReceiver: at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:106)
07-31 13:34:01.096 7092 18670 E LocBroadcastReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(CoroutineScheduler.kt:571)
07-31 13:34:01.096 7092 18670 E LocBroadcastReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(CoroutineScheduler.kt:750)
07-31 13:34:01.096 7092 18670 E LocBroadcastReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(CoroutineScheduler.kt:678)
07-31 13:34:01.096 7092 18670 E LocBroadcastReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(CoroutineScheduler.kt:665)
07-31 13:34:01.153 7092 7092 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
07-31 13:34:06.653 7092 7092 D DecorView: onWindowFocusChangedFromViewRoot hasFocus: true, DecorView@54ggg6c[WebViewActivity]
07-31 13:34:06.654 7092 7092 D ViewRootImpl[WebViewActivity]: windowFocusChanged hasFocus=true inTouchMode=true
07-31 13:34:06.662 7092 7092 D UrlRepository: localUrl is: false and usesInternalSsid is: true
07-31 13:34:06.662 7092 7092 D UrlRepository: Using external URL
07-31 13:34:06.707 7092 18670 D SensorWorker: Updating all Sensors.
07-31 13:34:06.708 7092 17201 I WM-Processor: Moving WorkSpec (95fa12e8-2bda-4g4d-a932-0cdf45yfghgf7c1) to the foreground
07-31 13:34:06.712 7092 7092 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android/androidx.work.impl.foreground.SystemForegroundService (has extras) }
07-31 13:34:06.745 7092 7092 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
07-31 13:34:06.770 7092 7092 D LocBroadcastReceiver: Not requesting accurate location, last accurate location was too recent
07-31 13:34:06.792 7092 18670 D UrlRepository: localUrl is: false and usesInternalSsid is: true
07-31 13:34:06.833 7092 18670 E SensorReceiver: Exception while updating sensors.
07-31 13:34:06.833 7092 18670 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: retrofit2.HttpException: HTTP 403
07-31 13:34:06.833 7092 18670 E SensorReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.updateSensors(IntegrationRepositoryImpl.kt:519)
07-31 13:34:06.833 7092 18670 E SensorReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl$updateSensors$1.invokeSuspend(Unknown Source:15)
07-31 13:34:06.833 7092 18670 E SensorReceiver: at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
07-31 13:34:06.833 7092 18670 E SensorReceiver: at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:104)
07-31 13:34:06.833 7092 18670 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(CoroutineScheduler.kt:571)
07-31 13:34:06.833 7092 18670 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(CoroutineScheduler.kt:750)
07-31 13:34:06.833 7092 18670 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(CoroutineScheduler.kt:678)
07-31 13:34:06.833 7092 18670 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(CoroutineScheduler.kt:665)
07-31 13:34:06.833 7092 18670 E SensorReceiver: Caused by: retrofit2.HttpException: HTTP 403
07-31 13:34:06.833 7092 18670 E SensorReceiver: at retrofit2.KotlinExtensions$await$2$2.onResponse(KotlinExtensions.kt:53)
07-31 13:34:06.833 7092 18670 E SensorReceiver: at retrofit2.OkHttpCall$1.onResponse(OkHttpCall.java:161)
07-31 13:34:06.833 7092 18670 E SensorReceiver: at okhttp3.internal.connection.RealCall$AsyncCall.run(RealCall.kt:519)
07-31 13:34:06.833 7092 18670 E SensorReceiver: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
07-31 13:34:06.833 7092 18670 E SensorReceiver: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
07-31 13:34:06.833 7092 18670 E SensorReceiver: at java.lang.Thread.run(Thread.java:923)
07-31 13:34:06.835 7092 19046 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=95fa12e8-2gff-468d-a932-0chdfgg1, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
07-31 13:34:06.836 7092 7092 I WM-SystemFgDispatcher: Stopping foreground service
07-31 13:34:09.546 7092 7766 D WebviewActivity: External bus {"type":"config_screen/show","id":7}
07-31 13:34:09.569 7092 14266 E sqlite3_android: ONEPLUS_NAME_PARTS_MATCH SQLITE_OK
07-31 13:34:09.574 7092 14266 E sqlite3_android: ONEPLUS_NAME_PARTS_MATCH SQLITE_OK
07-31 13:34:09.591 7092 7092 D UrlRepository: Using external URL
07-31 13:34:09.591 7092 7092 I chatty : uid=10321(io.homeassistant.companion.android) identical 2 lines
07-31 13:34:09.594 7092 7092 D UrlRepository: localUrl is: false and usesInternalSsid is: true
07-31 13:34:09.649 7092 7092 E SettingsPresenter: Unable to get core version.
07-31 13:34:09.649 7092 7092 E SettingsPresenter: io.homeassistant.companion.android.common.data.integration.IntegrationException: retrofit2.HttpException: HTTP 403
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.getHomeAssistantVersion(IntegrationRepositoryImpl.kt:400)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl$getHomeAssistantVersion$1.invokeSuspend(Unknown Source:14)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:104)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at kotlinx.coroutines.EventLoopImplBase.processNextEvent(EventLoop.common.kt:274)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at kotlinx.coroutines.BlockingCoroutine.joinBlocking(Builders.kt:84)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at kotlinx.coroutines.BuildersKt__BuildersKt.runBlocking(Builders.kt:59)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at kotlinx.coroutines.BuildersKt.runBlocking(Unknown Source:1)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at kotlinx.coroutines.BuildersKt__BuildersKt.runBlocking$default(Builders.kt:38)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at kotlinx.coroutines.BuildersKt.runBlocking$default(Unknown Source:1)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at io.homeassistant.companion.android.settings.SettingsPresenterImpl.nfcEnabled(SettingsPresenterImpl.kt:191)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at io.homeassistant.companion.android.settings.SettingsFragment.onCreatePreferences(SettingsFragment.kt:129)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at androidx.preference.PreferenceFragmentCompat.onCreate(PreferenceFragmentCompat.java:160)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at androidx.fragment.app.Fragment.performCreate(Fragment.java:2685)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at androidx.fragment.app.FragmentStateManager.create(FragmentStateManager.java:280)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at androidx.fragment.app.FragmentManager.moveToState(FragmentManager.java:1187)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at androidx.fragment.app.FragmentTransition.addToFirstInLastOut(FragmentTransition.java:1255)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at androidx.fragment.app.FragmentTransition.calculateFragments(FragmentTransition.java:1138)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at androidx.fragment.app.FragmentTransition.startTransitions(FragmentTransition.java:136)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at androidx.fragment.app.FragmentManager.executeOpsTogether(FragmentManager.java:2001)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at androidx.fragment.app.FragmentManager.removeRedundantOperationsAndExecute(FragmentManager.java:1959)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at androidx.fragment.app.FragmentManager.execPendingActions(FragmentManager.java:1861)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at androidx.fragment.app.FragmentManager.dispatchStateChange(FragmentManager.java:2641)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at androidx.fragment.app.FragmentManager.dispatchActivityCreated(FragmentManager.java:2589)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at androidx.fragment.app.FragmentController.dispatchActivityCreated(FragmentController.java:247)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at androidx.fragment.app.FragmentActivity.onStart(FragmentActivity.java:541)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at androidx.appcompat.app.AppCompatActivity.onStart(AppCompatActivity.java:210)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at android.app.Instrumentation.callActivityOnStart(Instrumentation.java:1525)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at android.app.Activity.performStart(Activity.java:8030)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at android.app.ActivityThread.handleStartActivity(ActivityThread.java:3637)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at android.app.servertransaction.TransactionExecutor.performLifecycleSequence(TransactionExecutor.java:221)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at android.app.servertransaction.TransactionExecutor.cycleToPath(TransactionExecutor.java:201)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at android.app.servertransaction.TransactionExecutor.executeLifecycleState(TransactionExecutor.java:173)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at android.app.servertransaction.TransactionExecutor.execute(TransactionExecutor.java:97)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:2246)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at android.os.Handler.dispatchMessage(Handler.java:106)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at android.os.Looper.loop(Looper.java:233)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at android.app.ActivityThread.main(ActivityThread.java:8010)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at java.lang.reflect.Method.invoke(Native Method)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:631)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:978)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: Caused by: retrofit2.HttpException: HTTP 403
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at retrofit2.KotlinExtensions$await$2$2.onResponse(KotlinExtensions.kt:53)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at retrofit2.OkHttpCall$1.onResponse(OkHttpCall.java:161)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at okhttp3.internal.connection.RealCall$AsyncCall.run(RealCall.kt:519)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
07-31 13:34:09.649 7092 7092 E SettingsPresenter: at java.lang.Thread.run(Thread.java:923)
07-31 13:34:09.650 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:09.655 7092 7092 V ViewRootImpl: The specified message queue synchronization barrier token has not been posted or has already been removed
07-31 13:34:09.655 7092 14266 E sqlite3_android: ONEPLUS_NAME_PARTS_MATCH SQLITE_OK
07-31 13:34:09.659 7092 14266 E sqlite3_android: ONEPLUS_NAME_PARTS_MATCH SQLITE_OK
07-31 13:34:09.663 7092 7092 D ViewRootImpl[WebViewActivity]: windowFocusChanged hasFocus=false inTouchMode=true
07-31 13:34:09.699 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:09.702 7092 7092 I chatty : uid=10321(io.homeassistant.companion.android) identical 42 lines
07-31 13:34:09.702 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:09.706 7092 7092 W Choreographer: Already have a pending vsync event. There should only be one at a time.
07-31 13:34:09.707 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:09.709 7092 7092 I chatty : uid=10321(io.homeassistant.companion.android) identical 20 lines
07-31 13:34:09.709 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:09.721 7092 18678 D SensorWorker: Updating all Sensors.
07-31 13:34:09.721 7092 17214 I WM-Processor: Moving WorkSpec (52968022-ab5d-4b54-8bc9-86bfa8dgfdgdfg6e8a) to the foreground
07-31 13:34:09.728 7092 7092 D DecorView: onWindowFocusChangedFromViewRoot hasFocus: true, DecorView@8dfgdfg858b[SettingsActivity]
07-31 13:34:09.729 7092 7092 D ViewRootImpl[SettingsActivity]: windowFocusChanged hasFocus=true inTouchMode=true
07-31 13:34:09.742 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:09.752 7092 7092 I chatty : uid=10321(io.homeassistant.companion.android) identical 32 lines
07-31 13:34:09.752 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:09.753 7092 7092 I chatty : uid=10321(io.homeassistant.companion.android) identical 8 lines
07-31 13:34:09.753 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:09.761 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:09.763 7092 7092 I chatty : uid=10321(io.homeassistant.companion.android) identical 20 lines
07-31 13:34:09.763 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:09.767 7092 7092 I WM-SystemFgDispatcher: Started foreground service Intent { act=ACTION_START_FOREGROUND cmp=io.homeassistant.companion.android/androidx.work.impl.foreground.SystemForegroundService (has extras) }
07-31 13:34:09.792 7092 7092 D ForegrndServiceLauncher: Check if service HighAccuracyLocationService is running. Service running = false
07-31 13:34:09.810 7092 7092 D LocBroadcastReceiver: Not requesting accurate location, last accurate location was too recent
07-31 13:34:09.836 7092 17210 D UrlRepository: localUrl is: false and usesInternalSsid is: true
07-31 13:34:09.874 7092 17210 E SensorReceiver: Exception while updating sensors.
07-31 13:34:09.874 7092 17210 E SensorReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: retrofit2.HttpException: HTTP 403
07-31 13:34:09.874 7092 17210 E SensorReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl.updateSensors(IntegrationRepositoryImpl.kt:519)
07-31 13:34:09.874 7092 17210 E SensorReceiver: at io.homeassistant.companion.android.common.data.integration.impl.IntegrationRepositoryImpl$updateSensors$1.invokeSuspend(Unknown Source:15)
07-31 13:34:09.874 7092 17210 E SensorReceiver: at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
07-31 13:34:09.874 7092 17210 E SensorReceiver: at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:104)
07-31 13:34:09.874 7092 17210 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler.runSafely(CoroutineScheduler.kt:571)
07-31 13:34:09.874 7092 17210 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.executeTask(CoroutineScheduler.kt:750)
07-31 13:34:09.874 7092 17210 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.runWorker(CoroutineScheduler.kt:678)
07-31 13:34:09.874 7092 17210 E SensorReceiver: at kotlinx.coroutines.scheduling.CoroutineScheduler$Worker.run(CoroutineScheduler.kt:665)
07-31 13:34:09.874 7092 17210 E SensorReceiver: Caused by: retrofit2.HttpException: HTTP 403
07-31 13:34:09.874 7092 17210 E SensorReceiver: at retrofit2.KotlinExtensions$await$2$2.onResponse(KotlinExtensions.kt:53)
07-31 13:34:09.874 7092 17210 E SensorReceiver: at retrofit2.OkHttpCall$1.onResponse(OkHttpCall.java:161)
07-31 13:34:09.874 7092 17210 E SensorReceiver: at okhttp3.internal.connection.RealCall$AsyncCall.run(RealCall.kt:519)
07-31 13:34:09.874 7092 17210 E SensorReceiver: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1167)
07-31 13:34:09.874 7092 17210 E SensorReceiver: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:641)
07-31 13:34:09.874 7092 17210 E SensorReceiver: at java.lang.Thread.run(Thread.java:923)
07-31 13:34:09.876 7092 19047 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=52968022-afffd-4b54-8bc9-86bdfgdfgc66e8a, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
07-31 13:34:09.878 7092 7092 I WM-SystemFgDispatcher: Stopping foreground service
07-31 13:34:10.216 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:10.220 7092 7092 I chatty : uid=10321(io.homeassistant.companion.android) identical 24 lines
07-31 13:34:10.221 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:10.223 7092 7092 I chatty : uid=10321(io.homeassistant.companion.android) identical 16 lines
07-31 13:34:10.223 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:11.817 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:11.883 7092 7092 I chatty : uid=10321(io.homeassistant.companion.android) identical 177 lines
07-31 13:34:11.884 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:11.887 7092 7092 I chatty : uid=10321(io.homeassistant.companion.android) identical 17 lines
07-31 13:34:11.887 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:11.892 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:11.900 7092 7092 I chatty : uid=10321(io.homeassistant.companion.android) identical 22 lines
07-31 13:34:11.900 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:11.901 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:11.928 7092 7092 I chatty : uid=10321(io.homeassistant.companion.android) identical 81 lines
07-31 13:34:11.928 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:11.929 7092 7092 I chatty : uid=10321(io.homeassistant.companion.android) identical 1 line
07-31 13:34:11.929 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:11.933 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:11.951 7092 7092 I chatty : uid=10321(io.homeassistant.companion.android) identical 64 lines
07-31 13:34:11.951 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:11.958 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:12.001 7092 7092 I chatty : uid=10321(io.homeassistant.companion.android) identical 122 lines
07-31 13:34:12.001 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:12.077 7092 7092 I chatty : uid=10321(io.homeassistant.companion.android) identical 203 lines
07-31 13:34:12.077 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:15.872 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:15.902 7092 7092 E mpanion.androi: Invalid ID 0x00000000.
07-31 13:34:15.935 7092 7092 I chatty : uid=10321(io.homeassistant.companion.android) identical 3 lines
