Home assistant API and Rotary knob for sonos volume
Hello everyone long time lurker, Ive been working on trying to get a physical control knob for my sonos speakers so i can quickly change the volume when needed. I followed this template on github petrepa esphome desk controller. I modified it for esp32 board. And tried to get things working. In the esphome logs i cee the volume increase and decrease with knob rotation but nothing happens in home assistant logbook.
Do I need to make a call before captive portal to define the home assistant entity?
Here is my code.
Thank you
esphome:
  friendly_name: sonos-den-controller
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "4AGkzCOReqUQGqchZoVs7hGcV///fSk4mzSxnmD/9To="
ota:
  password: "ef37e70cb42f3bebb6907f17a7067102"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Sonos-Den-Controller"
    password: "NGEuMVcA7VY3"
captive_portal:
substitutions:
  device_name: sonos-den-contoller
  friendly_name: sonos den controller
binary_sensor:
  # VOLUME KNOB BUTTON ----------------------
  - platform: gpio
    pin:
      number: GPIO19
      #mode: INPUT_PULLUP
      inverted: true
    name: "${friendly_name} Volume Switch Button"
    on_press:
      - homeassistant.service:
          service: media_player.play_pause
            entity_id: media_player.kitchen
  - platform: rotary_encoder
    name: "${friendly_name} Rotary Encoder"
    pin_b:
      number: GPIO23
      mode: INPUT
    pin_a:
      number: GPIO18
      mode: INPUT
    on_clockwise:
          service: media_player.volume_up
      - logger.log: "Turned Clockwise"
    on_anticlockwise:
          service: media_player.volume_down
      - logger.log: "Turned Anti Clockwise"
Have you added the ESPHome device to HA via the integrations page?
i’m such an idiot!
Thank you. I’ve been searching and reflashing all day. Simple error. Thank you thank you thank you.
Common mistake. Good luck with the project.
Huge Sucess with controlling SONOS volume on Phillips Hue Rotary Dial
works a treat !
