Home Assistant App for Garmin
I am running into the same issue on my Fenix 7s. Just tried closing both Connect and ConnectIQ and re-opening, still no luck.
I have verified using the [editor tool](https://house-of-abbey.github.io/GarminHomeAssistant/web/) that my API and JSON file are available on my computer (while on local wifi). Yet, when trying to verify on my phone I see a “Check CORS settings on HomeAssistant server.” for both tests? Not sure what would be different from my phone vs my computer?
I have tried using both hostname urls and direct ip address urls, which fixed a different integration I am using, but still running into the “Unconfigured” → “Unavailable” ui.
When I open the app on my watch, I see an error: “Failed to register Webhook. No Response, check internet connection”.
Yet my phone is connected to the wifi.
Appreciate all the work you’ve done to build and support this app!
IPhone user?
Yup! Running iOS 17.5.1 on iPhone 13 Mini
Did you read all of the previous post?
Yes, I’ve read every doc and suggestion I could get my hands on :slight_smile:
We have observed some peculiar behaviours over the last week or so. We’re worried that the fix that webhooks provided has come with a new infrequent ‘feature’ that we can’t catch in simulation. The latest version, 2.20, includes a speculative fix that we theorise might help. Otherwise, we have had success with uninstalling the app and starting again. Not ideal obviously, hence the speculative fix.
In the GHA app settings, scroll to the end to see your webhook ID, then check that ID is present on HA. On HA that’s under the cloud settings (top item in settings) at the bottom of the cloud settings screen. If your webhook ID is absent from that list, then you’ve fallen foul of this new bug.
But I’m hopefull v2.20 will fix this for you without a reinstall.
I am also running scripts and toggling switches with HassControl, so you can use that as well. But this seems a nicer way of doing it for sure.
EDIT: after quite some trouble setting this up - I managed to toggle a switch once but cannot reproduce using the same code - I think I might fall back to HassControl.
This seems at least in parts unnecessarily complex to set up? Especially the requirement to write json. How does HassControl manage to use a group of entitities? Could this be ported here somehow? (some) Groups are now possible to set up in the Web-UI, so this would reduce the likelihood of errors.
Note on sane defaults:
  • I do agree with an above comment that the base url should be enough and the app can assume that adding /api will render the api URL. (are there any installations where this is not the case?) This would simplify setup dramatically. Any user setting this up already knows their HA’s url, but this cannot be safely assumed for the API URL. (guess how I know :smile: )
  • I’d even be tempted to suggest asking just for the name of the json file, and to document that this file is to be placed in /path/to/homeassistant/www/garmin/ - that way we can safely assume it will be found in ${BASE_URL}/local/garmin/
can confirm and expand.
It looks like the people at HA added a failsafe and <homeassistant>/config/www now points at <homeasistant>/www
The JSON file does not need to on the HA instance. Hence location is not assumed.
It does sound like you have contradicted yourself here. Can it be assumed and therefore enough or not?
Besides, by decomposing the URL, it is actually harder for a user to test & confirm their settings as the URL construction becomes hidden inside the app. By using the full URL the setting value can be confirmed externally and then copied & pasted knowing it is correct. I.e. this is actually simpler and more transparent.
Besides, its rather late to change. It would break the settings for existing users! So it’s not worth that in order to satisfy one new user. Sorry.
This is the working principle of the app. Keep the app simple, and put the complexity externally. Textual configurations are often sought in order to simply both configuration and making changes, e.g. changing a file name to try something new.
The app is aimed at those who are comfortable with managing an HA instance, and hence editing YAML files. YAML is 1:1 with JSON, so its an easy conversion. If this is not to your liking there are other apps! We have a user base that appreciates this method of configuration, so it’s too late to change…
I see your points. While I do believe this app would be more accessible with more assumptions on technology and fewer on people, I understand and respect your design choices.
Your work is highly appreciated!
That a different app. HassControl was it? No point reinventing that as its been done.
Thanks anyway.
Hi. I have installed everything and it was working very well. I extended the .json file and suddenly it stopped working with the comment on the watch “API: OK / Menue: not available”. I can access the .json file from my web browser. I uninstalled everything and installed it again. But no success. Has anyone a idea what the problem could be?
Please can you confirm that you have followed the troubleshooting guide at GarminHomeAssistant/TroubleShooting.md at 2000a302767ac5d4e5fe58fc63cdecc5eed1d573 · house-of-abbey/GarminHomeAssistant · GitHub? This includes a web editor to check your JSON file.
My suspicion is your JSON file is no longer correct JSON after your edits. The web editor will be able to check both the format and the schema conformity.
Hi Philip. I did this and found that you were right and I had mistakes in the JSON file. Thanks for your support.
I just ordered myself a Garmin Forerunner watch and before doing so, I checked to see if I could control HA with it.
So thank you for making an app for Garmin! You made my choice easier for me :slight_smile:
Now, my watch obviously has not arrived yet. But maybe you can tell me some things before it gets here.
  • You mention SSL connection. Is this really still a must? My HA instance is local only and cannot be accessed via the internet with a VPN. So I never used SSL with it. Will it then not work?
  • Linked to the previous, does it support purely local connections, i.e. no routing through a cloud or similar that requires internet access to HA?
  • Will it work without my smart phone present, i.e. direct wifi connection to my network (watch - wifi - HA)?
Thanks again! :slight_smile:
Yes. Complain to Garmin about their SDK. Its beyond our control.
Yes, just change the URL, but it must be HTTPS.
Requires your Smartphone for Bluetooth. No Wi-Fi. See closed issues on Github for why. Boring. I could not get that to work as it bent the SDK and only worked in simulation.
Maybe I am wrong, but don’t public certificates e.g. through Let’s Encrypt require outside access, i.e. the Let’s Encrypt server needs to be able to access the HA instance?
Our Internet went down and we had an offline HTTPS working still. That suggests the proof of trust is in the maths behind all the certificates alone. I too might be mistaken here.
Any way, you don’t have a choice, Garmin insists on HTTPS, so if you can’t make that work, you’re stuffed.
Sorry, nothing we can do.
I am not sure it is possible. The problem is not the need for an internet connection when accessing the server, the problem is if you need public certificates, you need internet access when creating them. And it seems that needs to be a two way connection.
My internet provider (cable internet) uses DS Lite, which means multiple people share an IP. So it is not possible for websites to access my server. That is only possible via VPN/ZeroTier.
So the issue is the lack of support for self-signed certificates.
