Home Assistant App is not able to connect vie Cloudflare Tunnel
Hi
I have the problem that the Home Assistant app is not able to connect via a Cloudflare tunnel while the GUI is accessible from outside. I have set it up following one of the many tutorials, but the app still does not work. I reset the app and went through the login process (which was successful), but it still won’t connect. My problem is related to SSL as it works when I disable HTTPs.
Do you have any tip for me?
Thank you very much
Flo
