Hello everyone ich habe ein komisches Problem. Die HA App stürzt bei It happens every time I open the Entities item under Settings and then press the blue “Add Entities” button. Otherwise the app runs without any problems. I uninstalled and reinstalled the app but the problem was still there.
Hi welcome to the forum!
Are you talking about the mobile companion app because it’s not clear from what you are writing.
If so, Android or iOS?
Also, this is an English language only forum and the idea is to use 1 universal language so use a translator and refrain from using other languages.
You are right. Unfortunately the translation software didn’t quite work.I have a mobile version on my Android. Unfortunately, I cannot download entities because the app only crashes when I press “Add entities”. A reinstallation did not help
What do you mean by “I cannot download entities”?
I don’t recall knowing about this function.
Owkay, you mean adding an integration!
What happens if you do it from a computer?
If I log in via the browser and do it, it works. So it must be the app. How can I fix the error?
Even though I use the companion app extensively on Android I never use it to configure my system, just to consult.
If you want any help on this you have to share the log (as text, not a picture)
Which one? Supervisor or home assistant core?
This is a known issue and is currently fixed in the app beta
So the update will come soon and the error will be fixed? Great, thank you very much. Now I know
