Home assistant app on samsung tablet
I bougth Home Assistant Blue bundle Limited edition and it runs fine.
added the addon “SSH & Web Terminal”
The webpage firefox on windows 10 desktop runs 100% ok.
When running the Home Assistant app on my samsung galaxy tablet I type in the command:
ls
then hit the enter key. The app changes the “ls” command in “is”
and the terminal answers
zsh: command not found: is
every comment welcome
Try Firefox on Android to log in to your HA, maybe that works fine…
I did, same result, same error
then the problem is not in app or browser, but most likely the Samsung keyboard. Try to change that… Google or Swift for example…
Are you sure this is not autocorrect?
Try turning autocorrect off.
Succes! I installed Swift keybord and it is working 100% OK
Thanks a LOTTTT
