Home Assistant as Alarm transmitter?
Hi all,
While there is an integration for Home Assistant acting as SIA receiver via the SIA Alarm Systems integration I haven’t been able to find the opposite - the ability to have Home Assistant act as alarm transmitter to external alarm monitoring center.
Obviously it would be nice to be able to send to external actors via protocos such as SIA over IP and SOS Access v4 over IP, if one is to build a custom alarm system in Home Assistant while still have the pro’s of sending alarms to a professional external 24x7x365 actors. I’m hoping there already is an integration or addon I have missed?
Thanks!
I’ve been looking for this also. I am a professional alarm installer and would like the ability to report conditions from HA and not be tied to my actual alarm panel. I would think the only way to do this would be utilizing asterisk some how to push the signals into the central station receiver. If anyone else has interest in working on this with me let me know. I have the resources and hardware readily available. I can easily spin up a central station account for testing!
This is a good starting point:
and then just start coding away!
I have messed around with this using telnet, but I realized that it was beyond me.
I’m sure it’s quite a daunting task to make a complete alarm PE (transmitter) out of HA, but I’m equally convinced it’s possible. All major components are already in place; sensors, server platform and internet connectivity.
I will do some probing to see if I can get a PoC SIA transmitter going from HA, and perhaps we can take it from there? :slight_smile:
I’ll join you, to the best of my abilities. I am however a sailor, not a programmer, with skills there after. :sweat_smile:
The polling feature of SIA would also be great, as you then could have professional uptime monitoring of your HA instance.
Hi there,
I found a set of python classes here and I mounted a PoC on my test server.
I can tell that the ADM-CID part is correctly implemented and reconized by a real receptor (I work in a monitoring station).
I can’t tell for the SIA-DCS part since my frontal seems not understanding well the code transmitted.
I tried also to send SIA-DCS on this integration but it seems that code are not understood well too.
I know that SIA is not well documented and somes major versions can’t be compatible with other.
But it give an idea of how to implement message sending in Python and at least it work for a real ADM-CID receptor.
Regards
Did you make any progress in this project?
Also interested in this project. Would be willing to help if this is still active?
Sorry to say, but no. And now I have moved out of the house where I had planned to use this, so I also lost my incentive along the way :frowning:
Hi, did you solve this problem? I’m working on a smart home integrated alarm system and I’ll connect it to the central station receiver. I’d work on this with you if you’re interested.
Hi, we have the same need and we have just identified that component GitHub - jdelaporte13/hass_sia_alarm_transmitter: SIA transmitter for Home Assistant
We are going to test it with a central station receiver.
Hey, have you had any luck with this and already collected some experience?
Would someone still be interested in this? I have been working on a project where a arduino acts as a SIA DCS PE Transmitter.
Hi , I would be interested in your Arduino siadc09 pe. Did you get it working?
Yeah, atleast for testing purposes. Can i supply the code in some way?
