after the latest Home Assistant update some of my automations started running with delays or sometimes do not trigger at all. Notifications, smart lights, and motion based actions were working correctly before but now the response time feels inconsistent. I already restarted the system and checked the automation logs but could not find a clear cause. Has anyone experienced similar behavior after a recent update?
If you are running your OS using an SD card as the main drive, the update process is the most likely time the card will fail. There is a lot of new files and old files released to for new drive space, and that is when you notice problems.
I'm not saying that is your problem, but it is something to look at if the situation applies. I'm having to guess due to incomplete info.
