Home Assistant becoming non responsive
Hey guys could use some help. Ive been running home assistant for around 3 years now and everything has been great. This past month every day home assistant becomes unreachable with massive delays to automations. For example I ask alexa to turn on a zigbee light. She responds with something went wrong. 30 seconds later the light turns on. I originally thought this was due to interference but the dongle is on channel 25 while my APs are on channel 1 and 11. I then learned its all devices and not just zigbee. I attempted to access HA using my phone to see what was going on and I was greeted with a black screen. I could log into it on my computer but it was very very laggy. Nothing has changed in my setup in several months. I do run it as a VM but this also has not changed in like a year. Im not exactly sure how to find the culprit and its driving me crazy! I will attach logs soon as it begins to happen again. I thought I had a set but my computer thought it was unsafe and removed them so I will get a new set and attach. Maybe someone could see something I cannot? Oh and a restart solves everything for several hours but comes back shortly. Resources for the VM are hardly used as I have it with 16GB ram and 6 cores. Very low usage on that. Not sure what else I could add. Please let me know if i left out any helpful information!!
Edit: Solved I believe. It seems it was the roborock integration causing issues
