I have multiple services running behind a reverse nginx proxy. But I am having issues with home assistant. The UI loads but the calls don’t get forwarded and error out
Failed to call service homeassistant/turn_off. Unable to find service light/turn_off
I am running https://hub.docker.com/r/homeassistant/home-assistant on Unraid.
This is the nginx config. The site loads but gives errors when I try to turn on lights.
# make sure that your dns has a cname set for homeassistant and that your homeassistant container is not using a base url
server {
listen 443 ssl;
listen [::]:443 ssl;
server_name ha.*;
include /config/nginx/ssl.conf;
client_max_body_size 0;
# enable for ldap auth, fill in ldap details in ldap.conf
#include /config/nginx/ldap.conf;
location / {
# enable the next two lines for http auth
#auth_basic "Restricted";
#auth_basic_user_file /config/nginx/.htpasswd;
# enable the next two lines for ldap auth
#auth_request /auth;
#error_page 401 =200 /login;
include /config/nginx/proxy.conf;
resolver 127.0.0.11 valid=30s;
set $upstream_app homeassistant;
set $upstream_port 8123;
set $upstream_proto http;
proxy_pass $upstream_proto://$upstream_app:$upstream_port;
location /api/websocket {
proxy_set_header Host $host;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
This is the command used to run the container:
usr/local/emhttp/plugins/dynamix.docker.manager/scripts/docker create --name='HomeAssistant' --net='proxynet' --privileged=true -e TZ="America/Los_Angeles" -e HOST_OS="Unraid" -p '8123:8123/tcp' --device='/dev/ttyUSB0' 'homeassistant/home-assistant'
