Home Assistant Binary Sensor - Force Update
I have been using this guide to help keep a device awake for updates:
I seem to have a problem that the device doesn’t reliably get the value from HASS (it does sometimes) and am really struggling to troubleshoot. I see nothing VERBOSE logging and I can’t recreate the failure scenario either.
Is there a method, lambda function or anything I can call to force the binary_sensor to update from the home assistant value? (I will add this forced update before the deep sleep check).
Thanks in advance
Cameron.
@tatham are you around?
Using the ap is not the best with deep sleep in any event. See from the creator No api connection to HA after a while using Deep Sleep · Issue #350 · esphome/issues · GitHub
Thanks. Sounds exactly like my problem. I’ll have to go the MQTT route then.
So I’ve got this all working, but my device state is showing up as unavailable shortly after reporting a value. Seems like a timeout/going to sleep is causing the sensor to go offline and HASS to treat it as unavailable.
Any suggestions, on how I can fix this? Here is is my ESPHome config for the devices.
Cameron.
esphome:
  on_boot:
    then:
      - script.execute: consider_deep_sleep
esp8266:
  board: d1_mini
# Enable logging
logger:
#  level: VERBOSE
# Enable Home Assistant API
#api:
#  password: !secret api_password
ota:
  password: !secret ota_password
wifi:
  ssid: !secret wifi_ssid
#   Optional manual IP
#  manual_ip:
#    static_ip: 192.168.1.195
#    gateway: 192.168.1.250
#    subnet: 255.255.255.0
  ap:
    ssid: "Pooltherm Fallback Hotspot"
    password: "GpS4S9L1M1SU"
captive_portal:
mqtt:
  broker: !secret homeassistantIP
  username: esphome
  password: !secret mqtt_password
  on_message:
    topic: helper/input_boolean/esphome_sleepoff_pool
    then:
      - binary_sensor.template.publish:
          state: !lambda 'if(x=="on"){return 1;}else{return 0;}'
dallas:
  - pin: GPIO12
    update_interval: 2s
  - platform: dallas
    index: 0
  - platform: adc
    pin: A0
    filters:
      - multiply: 5.24
    update_interval: 2s
  - platform: wifi_signal
    name: "WiFi Signal Sensor"
    update_interval: 2s
binary_sensor:
    name: Prevent Deep Sleep
    #entity_id: input_boolean.esphome_sleepoff_pool
deep_sleep:
  sleep_duration: 20min
  # Do NOT set a run_duration or it will override the script setting
script:
  mode: queued
  then:
    - delay: 20s  #Note: 10s with weak signal is not long enough
    - logger.log:
        format: "Sleep Signal: %1.1f"
        args: [ 'id(prevent_deep_sleep).state' ]
    - delay: 1s
    - if:
        condition:
          binary_sensor.is_on: prevent_deep_sleep
        then:
          - logger.log: 'Skipping sleep, per prevent_deep_sleep from script'
        else:
          - logger.log: 'Entering Deep Sleep from Script'
          - deep_sleep.enter: deep_sleep_control
:point_right: Last Will And Birth Messages :point_left:
ESPHome uses the last will testament and birth message feature of MQTT to achieve availability reporting for Home Assistant. If the node is not connected to MQTT, Home Assistant will show all its entities as unavailable (a feature :wink:).
../_images/mqtt-availability.png
Is there any way to trick that during sleep? With native HASS MQTT sensor you can use expiry_after and availability latest or something. (Or are you saying if I fudge the last will and testament then it’ll stop these being reported as unavailable? Interesting thought)
Otherwise MQTT isn’t a real alternative to API during sleep…
I guess I’ll have to create another manual MQTT sensor in HASS directly reading that queue.
It’s written in docs how to do disable the availability reporting (the link to that is found in my last post) :point_left:
Thank you!
:see_no_evil:
(And yes, it’s working now by setting different topics - I get error messages in compile if I tried to make them empty/null).
