Home Assistant is installed on my Server 2012 R2 and can be accessed directly on that PC. It can also be accessed by remote connection over the internet from other PCs. However, it cannot be accessed using either of my win 7 or win 10 PCs which are connected by ethernet on the same network as the server. When I enter 192.168.1.xxx:8123, the web page stays blank for a few minutes, then the following appears:
This site can’t be reached
192.168.1.xxx took too long to respond.
All three PCs have Windows Firewall active and additional apps can be allowed to communicate. However I do not know what to specify for the Home Assistant app. It is installed under Python/----------/Sire Packages/ Homeassistant.
What is the best way to get access to Home Assistant from my networked PCs?
I had to redo the port opening and now I can get to the login and it accepts my credentials but it fails to connect to Home Assistant. If I log in using the server or by remote connection to the server, it goes directly to the interface. Is there something else that is blocking access to the interface when logging in from the network PC?
Yes. The Chrome page shows the Home Assistant logo on a white background and
Unable to connect to Home Assistant.
RETRY.
Retrying only produces the same result.
This only happens when trying to connect to Home Assistant which is installed on my server from either of my PCs. connected to the same server by ethernet.
