i got one Home assistant blue and migrated from my virtual machine , i found few issues :
my snapshot is 1.9 gb , and during the first config i cannot import it cause was accepting max 1 gb , so i have to configure the Blue , enable samba e then move the snapshot to the local backup folder and then import again
all worked perfectly, i had just to ensure the ip of the new machine will be the same of the old one otherwise i had to change all tasmota mqtt settings …
But now that all seems working fine I have just one problem …
all the sensor logs in lovelace are shown wrong , there is one line no real value are shown , for example the picture attached , is the outside temperature , actual is 7.5 °C and data is get correctly from the sensor, but the log graph show a line at about 10°C , no matter what the real temperature is the line dont change , grafana graphs are perfect, just there is this issue one the standard entity graphs …
should be a sort of bug somewhere, can someone help me ?
i deleted the DB and not this side working good , luckly all the influxdb data are still there …
but there are so meny problems after this migration, i really need some help to fix … this is my log errors , just few are shown , nabucasa , alexa, hacs , telegram, mobile app , see below :
Logger: custom_components.hacs
Source: custom_components/hacs/operational/factory.py:27
Integration: HACS (documentation, issues)
First occurred: 9:39:41 (2 occurrences)
Last logged: 9:41:02
Logger: homeassistant.components.alexa.state_report
Source: components/alexa/state_report.py:104
Integration: Amazon Alexa (documentation, issues)
First occurred: 7 gennaio 2021, 20:21:16 (3428 occurrences)
Last logged: 8:40:08
Timeout sending report to Alexa
Logger: homeassistant.components.mobile_app.webhook
Source: components/mobile_app/webhook.py:489
Integration: Mobile App (documentation, issues)
First occurred: 8:38:41 (1 occurrences)
Last logged: 8:38:41
Refusing to update IphoneSE non-registered sensor: da6d7ccad619546d2a5353f77997179f7574b9d1e3d4e1946a0b192b979a473e_geocoded_location
Logger: telegram.ext.updater
Source: /usr/local/lib/python3.8/site-packages/telegram/ext/updater.py:332
First occurred: 7 gennaio 2021, 20:16:48 (828 occurrences)
Last logged: 6:58:44
Error while getting Updates: urllib3 HTTPError HTTPSConnectionPool(host=‘api.telegram.org’, port=443): Max retries exceeded with url: /bot821054759:AAF-jie7bwdFGbh4CR7arPtytbsLRhDXfQw/getUpdates (Caused by ConnectTimeoutError(<telegram.vendor.ptb_urllib3.urllib3.connectionpool.HTTPSConnectionPool object at 0xffff70751310>, ‘Connect timed out. (connect timeout=5.0)’))
Error while getting Updates: urllib3 HTTPError [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self signed certificate in certificate chain (_ssl.c:1124)
