Home Assistant Blue with corrupted boot
I’m running Home Assistant OS 7
Core: 2021.12.5
Hoping someone could steer a newbie in the right direction…
Christmas Day my Home Assistant Blue stopped working. The startup logs show “FAT-f’s (mmcbIk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.”
then it repeats “mesonBb-dumac ff3f0000.ethernet etho: Reset adapter.”
So from my understanding this is my boot volume?
I was wondering what would be the best solution for this error. I have been trying to find the answer or the right direction by searching and have found nothing the same. I would like to keep or retrieve the data file.
Can I unmount the mmcblk1p1 volume and then run fsck on it?
Can I copy the data volume and use it to restore the data with a new build?
4.3267471 FAT-f's (mmcbIk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
4.3428331 libphy: mdio_mux: probed
4.402430] Adding 975648k swap on /dev/zram0. Priority:-2 extents:1 across:975648k SS
4.4406901 EXT4-fs (mmcblk1p3): mounted filesystem with ordered data mode. Opts: (null)
4.4446021 ext4 filesystem being mounted at /mnt/overlay supports timestamps until 2038 (0x7fffffff)
14.8144871 mesonBb-dumac ff3f0000.ethernet etho: Reset adapter.
23.7744821 mesonBb-dwmac ff3f0000.ethernet etho: Reset adapter.
36.830334] meson8b-dumac ff3f0000.ethernet etho: Reset adapter.
Thank you.
David
