I have recently purchased an Xiaomi LYWSD03MMC BLE temperature and humidity sensor, I would like to connect this device to my Home Assistant system.
Therefore, I would like to enable Bluetooth integration to Home Assistant. When I attempt to add the integration it says:
No unconfigured Bluetooth adapters found
There is a help link that points to Bluetooth - Home Assistant and I believe Balena would fall under this.
- Home Assistant Container: The host system must run BlueZ, and the D-Bus socket must be accessible to Home Assistant inside the container.
I believe D-Bus access is achieved by adding the io.balena.features.dbus: '1'
label to homeassistant service in docker-compose.yml
But, I don’t know how to run bluez on the host system. I have connected to the Balena HostOS serial console and noticed there are HCI tools already installed, from there I was able to run hcitool lescan and the device I want to connect to is discovered:
root@2b97a16:~# hcitool lescan
LE Scan ...
A4:C1:38:F3:FA:1B ATC_F3FA1B
This tells me bluetooth already is available to the host … So why am I unable to detect the BLE device in Home Assistant :-/
