I really new to HA. Today i have Rpi zero Wi-Fi and Home Assistant installera om it. i Need to get bluetooth active to try connect my other device. Can somebody explain me how to get this to work.
Login to the UNIX operating system.
sudo raspi-config
should get you configuration options for the R Pi Zero W.
After that? How do i get this in HA
i highly recommend switching to a more powerful machine such as a Pi 3/4. You’ll quickly run into limitations with the Pi Zero W and also always use a wired network connection for your HA machine whenever possible due to speed and stability reasons.
thanks for the recommendation. I bought this with a view to learning. but I wonder is there the possibility to activate the bluetooth and use it in HA
