When I tried setting up the Bluetooth integration it could not find a Bluetooth adapter. So I bought the ASUS usb-bt500 as it was listed for known as supported. Long story short I’m trying for 2 weeks strait and I still can’t get it to find my adapter.
If you check doc there is section call Requirements If your system doesnt met it bluetooth will not work in ha. And this is the top of the iceberg. The question you should ask yourself is Do I need it?
I build my network mostly around zigbee devices. If you put bluetooth in this network things have tendency to go ballistic. Buletooth is fighting with zigbee and vice versa. And nothing works.
My point is just this. Build your network around protocol you prefer. Just don’t mix things.Whether this is bluetooth, zigbee, rf or wifi.
i fixed it my virtual box wouldn’t connect to the device, I’ve fixed it now and I love it! I don’t need to buy a hub for my switchbot curtain anymore and I’ve also connected some thermostats.
