EDIT: have posted a screenshot of the working configuration in post #3
I just reconfigured my Network to use VLANs. HomeAssistant Core runs in Proxmox, everything is updated to the most current versions:
OS Version: HOme Assistant OS 8.2
Home Assistant Core: 2022.7.6
I am using the KNX device, which worked well before moving to VLANs. It’s also connected to an external MQTT Server which is on a separate VLAN and also works. (VLAN IDs 10/50/51)
enp0s18: 192.168.10.164/24 (Homeassistant UI, but currently also works on the other IPs)
enp0s19: 192.168.50.164/24 (KNX)
enp0s20: 192.168.51.164/24 (MQTT)
While MQTT works flawless, the KNX device configuration tells me it doesn’t find the KNX-IP Interface. But I can even ping it from the HomeAssistant Terminal. I tried setting the local IP in the KNX settings with 0.0.0.0 and 192.168.50.164. No difference:
I double checked the connection, I also can ping HomeAssistant on it’s VLAN50 IP address. Restarting the HA VM between different settings also didn’t make a difference.
Do you have any hint what else to check for?
Thanks in advance!
