Hello all,
I have a strange problem on my raspberry pi 3. It started with version 2021.09.X
I’m running Home Assistant OS on my raspberry.
After every update of Home Assistant Core, Home Assistant can’t finish its startup. For example it can’t finish the startup of the integration “automation”
To resolve this problem I have to restart the hole host/raspberry. After the host reboot, every restart of Home Assistant Core runs fine.
Attached you will find my current log and system health.
Thank you in advance
System health:
System Health
version: core-2021.10.1
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
user: root
virtualenv: false
python_version: 3.9.7
os_name: Linux
os_version: 5.10.17-v7
arch: armv7l
timezone: Europe/Berlin
GitHub API: ok
Github API Calls Remaining: 5000
Installed Version: 1.15.2
Stage: waiting
Available Repositories: 889
Installed Repositories: 17
logged_in: false
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: ok
host_os: Home Assistant OS 6.4
update_channel: stable
supervisor_version: supervisor-2021.09.6
docker_version: 20.10.7
disk_total: 116.7 GB
disk_used: 21.2 GB
healthy: true
supported: true
board: rpi3
supervisor_api: ok
version_api: ok
installed_addons: Samba share (9.5.1), File editor (5.3.3), Dasshio (0.3.8), Terminal & SSH (9.2.1), deCONZ (6.10.0), ESPHome (2021.9.3), NGINX Home Assistant SSL proxy (3.0.1), DSS VoIP Notifier (3.5.9), Samba Backup (5.0.0), Nginx Proxy Manager (0.10.1), MariaDB (2.4.0), heimdall (0.1.2), WireGuard (0.5.1), Mosquitto broker (6.0.1), TooGoodToGo Home Assistant MQTT Bridge (1.7.0)
dashboards: 1
resources: 12
mode: storage
api_endpoint_reachable: ok
Log:
2021-10-08 16:46:29 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-08 16:46:29 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration presence_simulation which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-08 16:46:29 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration illuminance which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-08 16:46:29 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-08 16:46:29 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration xiaomi_cloud_map_extractor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-08 16:46:29 WARNING (SyncWorker_6) [homeassistant.loader] We found a custom integration govee_ble_hci which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-08 16:46:29 WARNING (SyncWorker_5) [homeassistant.loader] We found a custom integration car_wash which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-10-08 16:46:52 WARNING (MainThread) [homeassistant.setup] Setup of automation is taking over 10 seconds.
2021-10-08 16:47:34 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: automation
2021-10-08 16:48:37 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: automation
2021-10-08 16:48:46 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 30218a5ad9eedc698fdcb92e01cb59b004ae83607b3bbb30f2b4eaee25ed2856 from IPADDRESS
2021-10-08 16:49:37 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: automation
2021-10-08 16:50:40 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: automation, media_player.alexa_media
2021-10-08 16:51:42 ERROR (MainThread) [homeassistant.setup] Setup of automation is taking longer than 300 seconds. Startup will proceed without waiting any longer
2021-10-08 16:52:16 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 30218a5ad9eedc698fdcb92e01cb59b004ae83607b3bbb30f2b4eaee25ed2856 from IPADDRESS
2021-10-08 16:54:23 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: switch.template, weather.darksky, switch.presence_simulation, switch.pi_hole, hacs, tts, weather.openweathermap, weather.met, switch.wake_on_lan
2021-10-08 16:54:30 WARNING (MainThread) [homeassistant.config_entries] Config entry 'IPADDRESS:19444' for hyperion integration not ready yet: None; Retrying in background
2021-10-08 16:54:33 WARNING (MainThread) [homeassistant.components.select] Platform netatmo not ready yet: None; Retrying in background in 30 seconds
2021-10-08 16:54:34 WARNING (MainThread) [homeassistant.components.camera] Platform netatmo not ready yet: None; Retrying in background in 30 seconds
2021-10-08 16:54:34 WARNING (MainThread) [homeassistant.components.climate] Platform netatmo not ready yet: None; Retrying in background in 30 seconds
2021-10-08 16:54:37 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform darksky is taking over 10 seconds.
2021-10-08 16:55:29 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: nanoleaf
2021-10-08 16:56:29 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: nanoleaf
2021-10-08 16:57:29 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: nanoleaf
2021-10-08 16:57:46 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 7d0656391fc78b6e2c786a1704a312abe82e235d7c9e90ddc6765d256843114a from IPADDRESS
2021-10-08 16:57:49 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 30218a5ad9eedc698fdcb92e01cb59b004ae83607b3bbb30f2b4eaee25ed2856 from IPADDRESS
2021-10-08 16:57:50 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 30218a5ad9eedc698fdcb92e01cb59b004ae83607b3bbb30f2b4eaee25ed2856 from IPADDRESS
2021-10-08 16:58:30 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: nanoleaf
2021-10-08 16:59:30 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: nanoleaf
2021-10-08 17:00:30 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: nanoleaf
2021-10-08 17:01:30 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: nanoleaf
2021-10-08 17:02:30 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: nanoleaf
