Home assistant can't install netdisco and RPI.GPIO
When i startup homeassistant it says at the webpage:
The following components and platforms could not be set up:
*switch.rpi-gpio
*Discovery
*rpi-gpio
When i look at the logs when starting up it also says that it can’t install netdisco and RPI.GPIO.
Any solution for this ?
Many thanks !
It will help others if you post what method you used to install and what platform you are running it on.
i used a manual installation and i’m running it on a Raspberry pi 1 B+ model.
