Current state of things: I have mosquito running and can publish to it from owntracks (I can see the messages using
mosquitto_sub -h [email protected] -t owntracks/# -p 8883 --capath /etc/ssl/certs/ -u "user" -P "password"
But if I use the MQTT developer tool in the webinterface, set topic to “owntracks/test” and Payload to “test” I don’t receive anything.
Config:
mqtt:
broker: [email protected]
port: 8883
client_id: home-assistant
username: user
password: password
I made the certificates using Letsencrypt certbot. Also I use the same user for all applications. Is that a problem?
The commandline running hass outputs
[Errno 104] Connection reset by peer
2017-12-29 16:37:45 INFO (Thread-12) [homeassistant.components.mqtt] Successfully reconnected to the MQTT server
every couple of minutes and when I try to publish a MQTT package it says
2017-12-29 16:39:34 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=mqtt, service_data=payload_template=test, topic=owntracks/test, service=publish, service_call_id=139738780625776-46>
2017-12-29 16:39:34 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=139738780625776-46>
So what’s wrong with my configuration?
