Home Assistant card (replacing former bar-card config)
I am getting the following, I placed the image in the right folder and named it the same.
Changed the border colour to --divider-color
I ended up adding the picture as a header, using the below code.
Card Code
          - type: entities
            entities:
              - entity: sensor.system_monitor_last_boot
                format: datetime
                card_mod:
                  style: |
                    hui-generic-entity-row {
                      border: none !important;
              - entity: sensor.system_monitor_processor_use
                card_mod:
                  style: |
                      background:
                        {% set perc = states(config.entity)|float(0) %}
                        {% set rest = 100 - perc %}
                        {% if perc >= 59 %} {% set bar = '255,0,0' %}
                        {% elif perc >= 44 %} {% set bar = '128,0 0' %}
                        {% elif perc >= 24 %} {% set bar = '255,165,0' %}
                        {% elif perc >= 9 %} {% set bar = '0,100,0' %}
                        {% else %} {% set bar = '0,128,0' %}
                        /*linear-gradient(to left,ivory {{rest}}%, {{bar}} {{perc}}%);*/
                        linear-gradient(to right, rgb({{bar}},0.9) 0%, rgb({{bar}},0.6) {{perc}}%,
                                                  rgba({{bar}},0.3){{perc}}%, rgba({{bar}},0.1) 100%);
              - entity: sensor.system_monitor_processor_temperature
                card_mod:
                  style: |
                      background:
                        {% set temp = states(config.entity)|float(0) %}
                        {% set rest = 100 - temp %}
                        {% if temp >= 85 %} {% set bar = '255,0,0' %}
                        {% elif temp >= 75 %} {% set bar = '128,0,0' %}
                        {% elif temp >= 65 %} {% set bar = '255,99,71' %}
                        {% elif temp >= 55 %} {% set bar = '255,69,0' %}
                        {% elif temp >= 45 %} {% set bar = '255,140,0' %}
                        {% elif temp >= 35 %} {% set bar = '255,165,0' %}
                        /*linear-gradient(to left,ivory {{rest}}%, {{bar}} {{temp}}%);*/
                        linear-gradient(to right, rgba({{bar}},0.9) 0%, rgba({{bar}},0.9) {{temp}}%,
                                                  rgba({{bar}},0.6){{temp}}%, rgba({{bar}},0.2) 100%);
              - entity: sensor.system_monitor_memory_usage
                card_mod:
                  style: |
                      background:
                        {% if perc >= 85 %} {% set bar = '255,0,0' %}
                        {% elif perc >= 75 %} {% set bar = '128,0,0' %}
                        {% elif perc >= 60 %} {% set bar = '255,165,0' %}
                        {% elif perc >= 50 %} {% set bar = '165,42,42' %}
                        linear-gradient(to right, rgba({{bar}},0.9) 0%, rgb({{bar}},0.9) {{perc}}%,
                                                  rgba({{bar}},0.6){{perc}}%, rgba({{bar}},0.2) 100%);
              - entity: sensor.system_monitor_disk_usage
                card_mod:
                  style: |
                      background:
              - entity: sensor.system_monitor_swap_usage
                card_mod:
                  style: |
                      background:
                        {% set swap = states(config.entity)|float(0) %}
                        {% set rest = 1000 - swap %}
                        /*{% set factor = 0.06 %}*/
                        {% if swap >= 768 %} {% set bar = '255,0,0' %}
                        {% elif swap >= 640 %} {% set bar = '255,215,0' %}
                        {% else %} {% set bar = '50,205,50' %}
                        /*linear-gradient(to left,ivory {{rest*factor}}%, {{bar}} {{swap*factor}}%);*/
                        linear-gradient(to right, rgba({{bar}},0.9) 0%, rgba({{bar}},0.9) {{swap}}%,
                                                  rgba({{bar}},0.1){{swap}}%, rgba({{bar}},0.1) 100%);
              - entity: sensor.home_assistant_v2_db_size
                name: Home Assistant V2 DB size
                card_mod:
                  style: |
            header:
              type: picture
              image: >-
                /local/home-assistant/home-assistant-wordmark-monochrome-on-dark.png
              tap_action:
                action: none
              hold_action:
                action: none
            footer:
              type: graph
              hours_to_show: 168
              detail: 1
            card_mod:
              style:
                hui-sensor-entity-row:
                      height: 25px;
                      padding: 0px 16px;
                      border-radius: 24px;
                      border: 1px groove var(--divider-color);
                  .card-content {
                    background: var(--ha-color);
                  ha-card {
                    color: white;
                    --card-mod-icon-color: white;
                    --mdc-icon-size: 20px;
                    font-weight: bold;
