Home Assistant card (replacing former bar-card config)
Because custom Bar-card has not been maintained for a while, I decided to try and mimic it as much as possible with core HA elements and card_mod, which in my toolset is practically core…
I’ve posted about this in the bar-card topic, but since it has become more than a simple replacement, I figured it might be useful and fun for the community to share standalone.
It features some nice and a bit more complex card_mods (setting generic mods on entities in an entities card, but overrule that on individual entities). Ive addded yaml anchors to not have to repeat yaml.
It is fully dynamic to my theme (you can change easily if you desire), and has a view in a glance aspect I need to see all is well (or not…)
The drawing of the graph itself is done with:
linear-gradient(to right, rgb({{bar}},0.9) 0%, rgb({{bar}},0.6) {{perc}}%,
                                      rgba({{bar}},0.3){{perc}}%, rgba({{bar}},0.1) 100%);
and is pure css on the linear gradient, the main feature of the mods on the backgrounds of the entities (combined with Jinja templating, and HA theme variables) :wink:
I’ve left some of my earlier testing in comments so you can see what I had done before. or go to this post in the bar-card topic to see the true iterations I did.
anyways, this is the yaml I now use:
Click for Yaml of Home Assistant card
type: entities
card_mod:
  style:
    hui-sensor-entity-row:
        hui-generic-entity-row {
          height: 25px;
          padding: 0px 16px;
          border-radius: 24px;
          border: 1px groove var(--primary-color);
      .card-content {
        background:
          {% set dark = is_state('binary_sensor.donker_thema','on') %}
          {% if not dark %} var(--ha-color) {% endif %};
      ha-card {
        color: white;
        --card-mod-icon-color: white;
        --mdc-icon-size: 20px;
        font-weight: bold;
entities:
  - type: custom:hui-element
    card_type: picture
    entity: device_tracker.ha_main
# in logo-pack
    image: /local/home-assistant/home-assistant-wordmark-monochrome-on-dark.png
# homeassistant-header.png from website is a tad too narrow
    card_mod:
      style: |
        ha-card {
          box-shadow: none;
          background:
          {% if not dark %} var(--ha-color){% endif %};
    tap_action:
      action: more-info
    hold_action:
      action: navigate
      navigation_path: /config/system
  - entity: sensor.last_boot
    format: datetime
    card_mod:
      style: |
          border: none !important;
  - entity: sensor.processor_use
    card_mod: &perc
      style: |
          background:
            {% set perc = states(config.entity)|float(0) %}
            {% set rest = 100 - perc %}
            {% if perc >= 59 %} {% set bar = '255,0,0' %}
            {% elif perc >= 44 %} {% set bar = '128,0 0' %}
            {% elif perc >= 24 %} {% set bar = '255,165,0' %}
            {% elif perc >= 9 %} {% set bar = '0,100,0' %}
            {% else %} {% set bar = '0,128,0' %}
            {% endif %}
            /*linear-gradient(to left,ivory {{rest}}%, {{bar}} {{perc}}%);*/
  - entity: sensor.processor_temperature
    card_mod:
      style: |
          background:
            {% set temp = states(config.entity)|float(0) %}
            {% set rest = 100 - temp %}
            {% if temp >= 85 %} {% set bar = '255,0,0' %}
            {% elif temp >= 75 %} {% set bar = '128,0,0' %}
            {% elif temp >= 65 %} {% set bar = '255,99,71' %}
            {% elif temp >= 55 %} {% set bar = '255,69,0' %}
            {% elif temp >= 45 %} {% set bar = '255,140,0' %}
            {% elif temp >= 35 %} {% set bar = '255,165,0' %}
            {% endif %}
            /*linear-gradient(to left,ivory {{rest}}%, {{bar}} {{temp}}%);*/
            linear-gradient(to right, rgba({{bar}},0.9) 0%, rgba({{bar}},0.9) {{temp}}%,
                                      rgba({{bar}},0.6){{temp}}%, rgba({{bar}},0.2) 100%);
  - entity: sensor.memory_use_percent
    card_mod:
      style: |
          background:
            {% if perc >= 85 %} {% set bar = '255,0,0' %}
            {% elif perc >= 75 %} {% set bar = '128,0,0' %}
            {% elif perc >= 60 %} {% set bar = '255,165,0' %}
            {% elif perc >= 50 %} {% set bar = '165,42,42' %}
            {% endif %}
            linear-gradient(to right, rgba({{bar}},0.9) 0%, rgb({{bar}},0.9) {{perc}}%,
                                      rgba({{bar}},0.6){{perc}}%, rgba({{bar}},0.2) 100%);
  - entity: sensor.disk_use_percent_home
    card_mod: *perc
  - entity: sensor.swap_use_percent
    card_mod:
# if you use the absolute swap sensor, you need to seed a factor to calculate the correct gradient
      style: |
          background:
            {% set swap = states(config.entity)|float(0) %}
            {% set rest = 1000 - swap %}
            /*{% set factor = 0.06 %}*/
            {% if swap >= 768 %} {% set bar = '255,0,0' %}
            {% elif swap >= 640 %} {% set bar = '255,215,0' %}
            {% else %} {% set bar = '50,205,50' %}
            {% endif %}
            /*linear-gradient(to left,ivory {{rest*factor}}%, {{bar}} {{swap*factor}}%);*/
            linear-gradient(to right, rgba({{bar}},0.9) 0%, rgba({{bar}},0.9) {{swap}}%,
                                      rgba({{bar}},0.1){{swap}}%, rgba({{bar}},0.1) 100%);
# green #0, 128, 0
# darkgreen #0, 100, 0
# limegreen 50, 205, 50
# gold 255, 215, 0
# brown # 165, 42, 42
# orange #255, 165, 0
# darkorange #255, 140, 0
# orangered #255, 69, 0
# tomato # 255, 99, 71
# maroon #128, 0, 0
# red #255, 0, 0
# {{'-dark' if dark }}
# url('/local/homeassistant/homeassistant_background.png');
# {% set dark = states('input_select.theme') is search('ight|Dark|Matrix',ignorecase=True) %}
# {% set bcolor = 'var(--ha-color)' if dark else 'rgb(49,150,207)' %}
and it looks like:
clear mode (day light regular)
a darker theme (evening, sun below horizon etc)
alarm set mode (note the alarm-color accents)
these are all set using the primary color in the themes on the border.
picture is the one in the official icon-pack, ice added it below
and the beauty of this, is it also shows nicely on mobile.
it has the same info as my buttons in this grid but just another feel to it:
(well these have graphs too, but they are historic …)
O, and before you ask this is the official Home Assistant blue, set in in your themes (or directly if you dont use themes):
    ha-color: '#03a9f4' # rgb(3, 169, 244)
Anyways, will probably add a few more lines regarding the modding or specifics, but, here you go, hope you like it.
As promised…
since I’ve been card-modding all of my Tiles card features to follow my ha-card-border-radius which is set to 0 (px), I figured this to be the last card in my Dashboard also needing that. Which ofc was rather quick fix, set in the global entities hui-sensor-entity-row: mod above. The result is perfect for my dashboard:
heads-up: this does not work anymore in the current beta 2025.1.0…
not sure what, but it has broken the background on the
    card_mod: &perc
      style: |
          background:
            /*{% set rest = 100 - perc %}*/
            {% endif %}
THANK you!
Whilst bar-card still works using YAML, your idea and code is very cool, and the looks are so much better as well.
I had a hard time showing the value in the bar correctly, when using value ranges, instead of 0 - 100%.
But it succeeded when I split the conversion calculations.
So this wasn’t allowed somehow:
{% set value100 = states(config.entity) | float(1) %}
{% set value = ((value100-min) / (max-min))*100 %}
Then I thought, why not split all calculations like this, which did the trick:
{% set valueA = value100 - min %}
{% set valueB = max - min %}
{% set valueC = valueA / valueB %}
{% set value = valueC * 100 %}
Complete code example:
entity: sensor.solar_total_energy_today
name: Zon Energie vandaag
card_mod:
  style: |
      background:
        /* RANGE: 0 to 20 */
        /* ! Convert Range to the needed 0-100% values ! */
        {% set valueA = value100 - 0 %}
        {% set valueB = 20 - 0 %}
        {% if value >= 8 %} {% set bar = '0,150,0' %}
        {% elif value >= 6 %} {% set bar = '255,230,0' %}
        {% elif value >= 4 %} {% set bar = '255,165,0' %}
        {% elif value >= 0.2 %} {% set bar = '255,0,0' %}
        {% else %} {% set bar = '155,205,255' %}
        {% endif %}
        linear-gradient(95deg,
        rgba({{bar}},0.9) {{value}}%,
        rgba({{bar}},0.5) {{value}}%,
        rgba({{bar}},0.15) 100%);
Graphic:
nice, and yes, you can play around with the gradients to your liking
I’ve learned since writing that one up, that we can also use the relative syntax
rgb(from <any color> r g b / 1)
and use a color variable, or name in the
this opens up a ton of extra possibilities, especially in these templates, so you dont need to hard code the rgb values :wink:
just look it up in the W3school or rgb() - CSS: Cascading Style Sheets | MDN
Would you consider making this more digestable by having a GUI configuration and available on HACS? The bar card has not been updated and so I’d welcome trying this to replace it.
haha, no, sorry, you’ll have to do it yourself
it’s less trouble for you to c&p this and renaming a few variables, than for me creating a frontend card for that
This is merely a standard entity row in a standard Entities card with a nice & useful card-mod styling.
Not disliking your cards but maybe post these in a separate topic or the template mushroom thread?
This topic was really for showing the HA system using core entity rows …
I am getting the following, I placed the image in the right folder and named it the same.
Changed the border colour to --divider-color
I ended up adding the picture as a header, using the below code.
Card Code
          - type: entities
            entities:
              - entity: sensor.system_monitor_last_boot
                format: datetime
                card_mod:
                  style: |
              - entity: sensor.system_monitor_processor_use
                card_mod:
                  style: |
                      background:
                        {% endif %}
              - entity: sensor.system_monitor_processor_temperature
                card_mod:
                  style: |
                      background:
                        {% endif %}
              - entity: sensor.system_monitor_memory_usage
                card_mod:
                  style: |
                      background:
                        {% endif %}
              - entity: sensor.system_monitor_disk_usage
                card_mod:
                  style: |
                      background:
                        {% endif %}
              - entity: sensor.system_monitor_swap_usage
                card_mod:
                  style: |
                      background:
                        {% endif %}
              - entity: sensor.home_assistant_v2_db_size
                name: Home Assistant V2 DB size
                card_mod:
                  style: |
            header:
              type: picture
              image: >-
              tap_action:
                action: none
              hold_action:
                action: none
            footer:
              type: graph
              hours_to_show: 168
              detail: 1
            card_mod:
              style:
                      height: 25px;
                      padding: 0px 16px;
                      border: 1px groove var(--divider-color);
                  .card-content {
                    background: var(--ha-color);
                  ha-card {
                    color: white;
                    font-weight: bold;
yeah but your error was caused by the fact you dont have custom card hui-element installed.
with that, you can put any card in an entities card, it’s really. very powerful.
I did also test the header option, but it was less obvious to style.
btw, meanwhile I changed that section to use a vertical-stack and 2 conditionals :wink:
So depending on the theme, it changes the image file
entities:
    card_type: vertical-stack # required because hui-element does not support visibility
    cards:
      - visibility:
          - condition: state
            entity: binary_sensor.donker_thema
            state: 'on'
        image: /local/home-assistant/home-assistant-wordmark-color-on-dark.png
        <<: &picture
          type: picture
          card_mod:
            style: |
              ha-card {
                background:
                {% endif %};
          tap_action:
            action: more-info
          hold_action:
            action: navigate
      - visibility:
          - condition: state
            state: 'off'
        <<: *picture
    format: datetime
    card_mod:
      style: |
etcetc
I will have a look for the custom card: hui element. I did not realize. Thanks for the card btw, very slick looking.
I was also getting template errors in the log for undefined values. I have changed my configuration to the following. The card displays nice and no more errors.
          - type: entities
            entities:
                format: datetime
                card_mod:
                  style: |
                card_mod:
                  style: |
                      background:
                        {% set perc = states('sensor.system_monitor_processor_use')|float(0) %}
                        {% if perc >= 59 %}
                        {% else %}
                        {% endif %}
                        /*linear-gradient(to left, ivory {{rest}}%, {{bar}} {{perc}}%);*/
                        linear-gradient(to right, rgb({{bar}},0.9) 0%, rgb({{bar}},0.6) {{perc}}%, rgba({{bar}},0.3) {{perc}}%, rgba({{bar}},0.1) 100%);
                card_mod:
                  style: |
                      background:
                        {% set temp = states('sensor.system_monitor_processor_temperature')|float(0) %}
                        {% if temp >= 85 %}
                        {% else %}
                        {% endif %}
                        /*linear-gradient(to left, ivory {{rest}}%, {{bar}} {{temp}}%);*/
                                        rgba({{bar}},0.6) {{temp}}%, rgba({{bar}},0.2) 100%);
                card_mod:
                  style: |
                      background:
                        {% set perc = states('sensor.system_monitor_memory_usage')|float(0) %}
                        {% if perc >= 85 %}
                        {% else %}
                        {% endif %}
                                        rgba({{bar}},0.6) {{perc}}%, rgba({{bar}},0.2) 100%);
                card_mod:
                  style: |
                      background:
                        {% set perc = states('sensor.system_monitor_disk_usage')|float(0) %}
                        {% if perc >= 59 %}
                        {% else %}
                        {% endif %}
                card_mod:
                  style: |
                      background:
                        {% set perc = states('sensor.system_monitor_swap_usage')|float(0) %}
                        {% if perc >= 59 %}
                        {% else %}
                        {% endif %}
                card_mod:
                  style: |
            header:
              type: picture
              image: >-
              tap_action:
                action: none
              hold_action:
                action: none
            footer:
              type: graph
              hours_to_show: 168
              detail: 1
            card_mod:
              style:
                      height: 25px;
                      padding: 0px 16px;
                  .card-content {
                  ha-card {
                    color: white;
                    font-weight: bold;
I know that this topic has been open already for some time.
I just stumbled on it recently.
My question is:
Would it be possible with this approach to also define the vertical bar charts that custom: bar-card can produce?
I’m struggling to get things sorted like font-size, and decimals in one of my bar-cards, and might give this alternative route a try if vertical bar charts are possible as well.
Here’s an example of one of my bar-cards atm.
Any pointers would be appreciated, so I can tinker the rest like I have done in the past.
:slight_smile:
many thanks for your code, the stylesheet and the idea. I use it for my solar system. Since I have absolute values in W there, I could not work with the percentages. I have the following code for the card_mod of an entity in use:
type: entities
card_mod:
  style:
          height: 3em;
          padding: 0px 6px 0px 0px;
          border-radius: 8px;
          border: 1px groove #4d4d4d;
        hui-generic-entity-row::after {
           font-weight: 400;
           font-size: 0.72em;
           font-style: italic;
           text-wrap-mode: nowrap;
           color: #b4b4b4;
           padding-left: 0.6em;
      .card-content {
        background:
      ha-card {
        color: white;
        --mdc-icon-size: 24px;
        font-weight: 500;
entities:
  - entity: sensor.inverter_pv_1_power
    name: Solar Dach Ost (P1)
    card_mod:
      style: |
          background:
            {% set value = states(config.entity) | int %}
            {% set maxvalue = 7470 | int %}
            {% set value = int( value / maxvalue * 100 ) %}
            {% if value >= 80 %} {% set bar = '0,210,0' %}
            {% elif value >= 50 %} {% set bar = '0, 155, 0' %}
            {% elif value >= 30 %} {% set bar = '255, 105, 0' %}
            {% elif value >= 10 %} {% set bar = '255, 65, 0' %}
            {% else %} {% set bar = '255, 0, 0' %}
            {% endif %}
            linear-gradient(90deg,
          content: 'max. {{ maxvalue }}W'
The percentage value is calculated from the value of the entity and a maxvalue to be set. I use css ::after to include the maxvalue in the bar.
Hi @P.vR
Did you find a way to replicate the vertical bars?
I prefer button-card for almost everything so here is my button-card template. Read the info on the Github repo on how to set it up: GitHub - custom-cards/button-card: ❇️ Lovelace button-card for home assistant
Screenshot:
Code:
  - type: custom:button-card
    entity: sensor.spk_mortgage_overview_percentage
    template: button_simple_bar
    show_name: false
    variables:
      bar_height: '40px'
      state_position: inside
      state_font_size: '1.2em'
      bar_color_normal: '#03a9f4'
      bar_color_warning: '#03a9f4'
      bar_color_critical: '#03a9f4'
      bar_image: '/local/images/spk.png'
    card_mod:
      style: |
        :host {
          padding: 0 16px;
Screenshot:
Code:
    entity: sensor.kaya_cpu_utilization
    entity: sensor.kaya_ram_usage
    entity: sensor.kaya_fan_speed
    variables:
      warning_from_state: 80
      critical_from_state: 90
    entity: sensor.kaya_power_usage
    variables:
      max_value: 500
      warning_from_state: 70
Button-card template:
button_simple_bar:
  show_icon: false
  show_state: false
  variables:
    name_padding: 50px
    state_padding: 50px
    max_value: 100
    warning_from_state: 50
    critical_from_state: 80
    bar_height: '10px'
    state_font_size: '1em'
    bar_color_text: '#000'
    bar_color_normal: '#69B34C'
    bar_color_warning: '#FAB733'
    bar_color_critical: '#FF4E11'
    bar_color_background: '#E5E6E8'
    reversed: false
    state_position: outside  # Use 'inside' or 'outside'
    bar_image: null
    bar_image_size: '40px'
  state_display: >
      return (entity && !isNaN(entity.state))
        ? `${entity.state}${entity.attributes.unit_of_measurement || ''}`
  styles:
    grid:
      - grid-template-areas: '"img n bar s"'
      - grid-template-columns: auto auto 1fr auto
      - grid-template-rows: auto
    card:
      - color: '#000'
      - font-size: 1em
      - margin: 5px 0
      - padding: 0
      - border-style: none
      - --mdc-ripple-color: none
    name:
      - text-align: left
      - min-width: '[[[ return variables.name_padding ]]]'
    state:
      - font-weight: 500
      - text-align: right
      - min-width: '[[[ return variables.state_padding ]]]'
  custom_fields:
    img: >
        if (variables.bar_image) {
          return `<img src="${variables.bar_image}" style="width: ${variables.bar_image_size}; height: ${variables.bar_image_size}; object-fit: contain; margin-right: 13px; border-radius: 50%;">`;
        return '';
    bar: >
        if (!entity || isNaN(entity.state)) {
          return `<div style="position: relative; background-color:${variables.bar_color_background}; width:${variables.state_position === 'outside' ? 'calc(100% - 50px)' : '100%'};">
                    <div style="height:${variables.bar_height}; width:100%"></div>
                  </div>`;
        const pctUsed = Math.min(100, (entity.state / variables.max_value) * 100);
        let barColor = variables.bar_color_normal;
        if (variables.reversed) {
          // Reversed thresholds (e.g., for battery meters)
          if (pctUsed < variables.warning_from_state) {
            barColor = variables.bar_color_critical;
          } else if (pctUsed < variables.critical_from_state) {
            barColor = variables.bar_color_warning;
        } else {
          // Default thresholds (e.g., for CPU meters)
          if (pctUsed > variables.critical_from_state) {
          } else if (pctUsed > variables.warning_from_state) {
        const stateDisplay = `${entity.state}${entity.attributes.unit_of_measurement || ''}`;
        const barHeight = variables.bar_height;
        const textColor = variables.bar_color_text;
        const fontSize = variables.state_font_size;
        if (variables.state_position === 'inside') {
          // Inside the progress bar, but state remains fixed to the right
          return `<div style="position: relative; background-color:${variables.bar_color_background}; width:100%; height: ${barHeight};">
                    <div style="background-color:${barColor}; height:${barHeight}; width:${pctUsed}%;">
                    </div>
                    <span style="position: absolute; right: 5px; top: 50%; transform: translateY(-50%); color: ${textColor}; font-size: ${fontSize}; font-weight: bold; text-align: right;">${stateDisplay}</span>
                  </div>`;
        } else {
          // Outside the progress bar (default behavior)
          return `<div style="display: flex; align-items: center; justify-content: space-between;">
                    <div style="flex: 0 1 calc(100% - 50px); background-color:${variables.bar_color_background};">
                      <div style="background-color:${barColor}; height:${barHeight}; width:${pctUsed}%;"></div>
                    </div>
                    <span style="flex: 0; margin-left: 10px; font-size: ${fontSize}; font-weight: bold; color: ${textColor}; text-align: right;">${stateDisplay}</span>
                  </div>`;
Added a Home Assistant Log Size sensor, using the File Size integration.
Card code with border: 1px groove var(--divider-color)
type: entities
entities:
    format: datetime
    card_mod:
      style: |
    card_mod:
      style: |
          background:
            {% endif %}
    card_mod:
      style: |
          background:
            {% endif %}
    card_mod:
      style: |
          background:
            {% endif %}
    card_mod:
      style: |
          background:
            {% endif %}
    card_mod:
      style: |
          background:
            {% endif %}
  - entity: sensor.home_assistant_log_size
    name: Home Assistant Log Size
    card_mod:
      style: |
    card_mod:
      style: |
header:
  type: picture
  tap_action:
    action: none
  hold_action:
    action: none
footer:
  type: graph
  hours_to_show: 168
  detail: 1
card_mod:
  style:
          height: 25px;
          padding: 0px 16px;
      .card-content {
      ha-card {
        color: white;
        font-weight: bold;
which integration creates that db_size sensor? Or is that also a File size sensor…?
Yes also a file size sensor. I find these are the things I need to watch, if db or log files start growing rapidly I have a problem and home assistant gets laggy. I run a home assistant blue Odroid N2+.
Great Job. Thats what i am looking for to get rid of my bar-chart.
I just have to enhance it to also accept a minvalue for Outside Temperatures in my case :wink:
