Good day to everyone and thanks in advance
Hold on tight this will be a doozy.
Specifics about my system:
HA is running in VirtualBox on a W10 host.
Supervisor version 2024.02.1. Core version 2023.5.4
About a week ago I lost access to the HA webpage and everything stopped working. Come to find out the SSD in my W10 system has died. After some extensive data recovery I managed to get the VDI off the SSD intact (or so i thought) Once I got the VDI back on my W10 host I booted up home assistant and everything seemed find but I do not have access to the webpage and the Observer states:
|Supervisor:|Connected|
|Supported:|Supported|
|Healthy:|Unhealthy* [setup]
Now for the things I have tried…
Supervisor repair - completes successfully
Supervisor reload - completes successfully
Supervisor restart - completes successfully
Supervisor update - No update available
Core check - Processing…Done Completes successfully
Core rebuild - Processing…Done Unknown Error, See supervisor
Core update - Blocked from execution, system is not healthy
Booting from slot A will get me to a failed to launch HA Cli.
Slot B boots just fine albeit no access to the GUI
One of the errors I got initially pertained to not being able to read the headers on the backups. So i read a bit and saw some people with storage issues due to backups taking space. I made the VDI larger by 8GB and rebooted. Still issues. I went ahead and deleted all the backups and rebooted. Still nothing
Im really not sure what else I can try. I really REALLY dont want to have to do a fresh install but if I absolutely have to is there a way to import my Z-Wave network as is or do I have to manually re-add each device?
Also I have a tonne of automations that took me a while to create, is there any way to recover those?
Any help is greatly appreciated. At this point im getting desperate.
