I just booted hassos x64 in my laptop and its saying home assistant cli not starting. I saw multiple community post about this but nothing works for me. Internet is connected. I ping every server and saying alive. Even added dns manually. Even i cant connect into web interface. Please help
First off I’d try to reinstall again, to see if that makes a difference.
Also, make sure that you can ping/reach github.com
and ghcr.io
There is a timeout for how long we wait for the CLI. If startup takes way too long for some reason, the OS just goes back to a shell. If the same thing happens still, can you check what containers are running at this point using docker ps
connect wifi is successful, terminal input this code: nmcli d wifi connect [your wifi name] password [your wifi password] ; for example: nmcli d wifi connect cc password 123456789
i reinstalled haos generic x86 64 12.4, 8 times gives me same issue. its take only 20 sec and say home assistant cli not starting. Running on i3 10 gen laptop
