Home Assistant Cloud - Google Assistant - Scenes - Multiusers
HA Cloud works great with Google Assistant, it maps everything I need in it and it works fine.
The problem is really specific to Google Home app for additional users, members of my Ghome structure…
I basically create routines in Google Assistant using the scenes mapped from HA and this also works great.
The issue is for my GF (member of my google Home structure). She sees all devices from HA BUT NO SCENE.
***Actually, she sees one for some reason…
And it seems when using routines, it is user specific so my routines cannot be used by her (so the goal would be to recreate her own routines like mines but again, she doesn’t see the HA scenes).
Does anyone has any hint on how to resolve this?
Not 100% sure this is a HA issue or a Google issue (but her profile sees everything else (not just HA devices)… really about the scenes (that I see perfectly in my profile).
Thanks in advance for any help on this :slight_smile:
# Cloud
cloud:
  google_actions:
    filter:
      include_domains:
        - switch
        - light
        - scene
        - lock
        # - script
      exclude_entities:
        - switch.qbittorrent
        - switch.wol_sfpc06
        - light.bureau
        - light.ch_thomas
        - light.chambre
        - light.cuisine
        - light.entree
        - light.etabli
        - light.exterieur
        - light.flashing_lights
        - light.hotte1
        - light.hotte2
        - light.salle_a_diner
        - light.salon
        - light.sous_sol
        - light.ampouleplafond1
        - light.ampouleplafond2
      include_entities:
        - sensor.aeotec_zw100_multisensor_6_temperature
        - sensor.aeotec_zw100_multisensor_6_relative_humidity
        - sensor.capteur_soussol_temperature
        - sensor.capteur_soussol_relative_humidity
bump…
Can someone confirm if it works (for anyone mapping scenes in Google Assistant and having additional member in GHome structure)?
How can I get help with this issue? Does Nabu Casa offer any kind of assistance for this since I’m using their service to map my scenes?
I found my issue, in case it interests anyone…
For the other Google Home members to see the mapped scenes, the scenes needed to be mapped in a room.
After that, the other members of the Google home structure were able to see and use the scenes in Google Assistant.
How do you mean Map it to a room?
I can’t get it to work.
I can’t see my scene at Google assistant.
Well, the same way in Google Home app you assign a device to room, do the same for the scenes.
