Just wanted to check if I am doing something wrong here -
All I did was go to the Settings>Home Assistant Cloud section, switched it on and signed up to the Nabu Casa cloud.
The link it gave me for remote access works perfectly.
The mobile app for HA however does not -
Unable to connect to Home Assistant with Settings/Refresh External URL or Wait as an option.
Cloud Connection is Connected and not seeing anything in the logs unless I am missing it.
Note, I am new to HA and only just paired up all the z-wave devices
Yes - Works perfectly at home on wi-fi - in actual fact, must better than my previous automation system
Yes - Assuming you mean via the URL Nabu Casa has generated ? Then yes, this is accessible on my standard 4G/5G/LTE connection and also as I type, works perfectly on my laptop at work
In the Companion app → Settings → Companion app → (whatever you instance is called under Servers and Devices - probably ‘Home’) → Home Assistant URL → is Use HA Cloud turned on?
I was contemplating shutting my forum account and starting a new one just to save the embarrassment. Bearing in mind I’m a developer so to even ask a question like this was on here was a brave one!
Cannot believe I missed this - I did switch this on I’m sure but I’m now thinking whether I did it in the first iteration of HA which I then wiped once I was happy with it…and started again.
Jumping on the bandwagon here … sorry !
I have the same issue yet for me, the Use Home Assistant Cloud is the option selected under the topic Home Assistant URL. And it does not work …
Any other things I can try ?
Thanks !
