Thank you, I will try this
How do I ignore discovery integration?
On every restart of Hassio I get a notification of Adguard discovered. But I donāt use it.
discovery:
ignore:
- adguard (or adguard_home or adguardhome)
gave me āvalue is not allowedā
This did the trick for me:
Hi guys Iām looking at installing and Iām curious what automation have people created?
Also any advice?
Release v2.2.0
If you see This add-on is not available on your system.
; please continue readingā¦
This is a release ships with AdGuard Home v0.99.0!
https://github.com/AdguardTeam/AdGuardHome/releases/tag/v0.99.0
There are some caveats with this release:
- The add-on requires Home Assistant >= 0.101.0b0 (0.101.0 beta or newer). You wonāt be able to update or install this version if you donāt meet this requirement.
In that case, you will get aThis add-on is not available on your system.
message. - Home Assistant >= 0.100.0b0 requires at least AdGuard Home v0.99.0 (this release) for the integration to work.
- AdGuard displays a version check error, this bug is expected to be fixed in AdGuard 0.99.1, however, it does not influence the working of AdGuard Home.
Changes
- Upgrade AdGuard Home to v0.99.0 (#35)
- Upgrades add-on base image to v5.0.1
- Require Home Assistant 0.101.0b0 or newer
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck
hello @frenck
i dont understand the āThis add-on is not available on your systemā : i have 0.100.3, so that means i have to wait for a new version of hassio?
message.
I have an automation to automatically turn on Adguard protection if I manually turn it off to view a website. Sometimes I forget to turn it back on, so this automation does it for me.
How are you finding it?
Do you have any tips?
What are you running it on?
Release v2.2.1
This is a release ships with AdGuard Home v0.99.1!
https://github.com/AdguardTeam/AdGuardHome/releases/tag/v0.99.1
Changes
- Upgrade AdGuard Home to v0.99.1 (#36) (@tjorim)
It seems to block most ads. I donāt use any of Adguardās advanced features, so canāt comment on those. I also didnāt configure my routerās DNS settings to point to AdguardāI only have a few devices going through Adguard. I donāt I donāt think the whitelisting feature works, so some sites where I want to see ads, I donāt.
I use the Adguard/HA integration so I can turn on/off Adguard protection from Home Assistant, and through Google Assistant. That is useful when you need to click on a redirect URL and turn off Adguard immediately.
I used to run it on an rPi3, but now I have everything running on an old laptop. I never noticed issues running on the rPi3, though I only had 5 clients connected to it.
sounds greatā¦ but why a production release that requires beta?
AdGuard Home introduced breaking change in the API in v0.99.0. Home Assistant 0.101.0 addresses this. People running the beta, need the newer add-on version already, users on 0.100 stable, would cause the integration to break.
Thus, the add-on release is available for 0.101 and higher (which right now, is beta).
Release v2.2.3
This is a release ships AdGuard Home v0.99.2
https://github.com/AdguardTeam/AdGuardHome/releases/tag/v0.99.2
Changes
- Upgrades AdGuard Home to v0.99.2
got it ; so when HA prod goes to 101 this will be availableā¦
If you have installed 0.101 the addon will be unlocked for update automatically
Release v2.2.4
This is a general maintenance release.
Changes
- Upgrades nginx to 1.16.1-r1
- Upgrades AdGuard to v0.99.3
- Upgrades add-on base image to v5.0.2
Is there any way to configure time based service blocking?
For example an automation to disable facebook (service) between specific hours of the day?
Thanks!
I blocked it 24h/365 days
Good for you!
What about other services I want to allow only time based (@Klagio please donāt suggest to block them all permanently)?
