Home Assistant Community Add-on: AppDaemon 4
Yes
May I ask a question. I need to use /dev/ttyUSB0 port in my phyton programs at appdaemon.
Are the serial ports exposed to the add-on already? (I saw the similar message in the top)
When I login to appdaemon container (via portainer), I see that /dev/ttyUSB0 is available there but my code is not working…it doesn’t open the port:
self.ser = serial.Serial(
port = ‘/dev/ttyUSB0’, #/dev/ttyUSB0
baudrate = 9600, # 9600 bauds
bytesize = serial.EIGHTBITS, # 7bits
parity = serial.PARITY_NONE, # even parity
stopbits = serial.STOPBITS_ONE, # 1 stop bit
xonxoff = False, # no flow control
timeout = 1
the operation is not passing and I see the following error:
File “/usr/lib/python3.8/site-packages/serial/serialposix.py”, line 322, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
OSError: [Errno 5] I/O error: ‘/dev/ttyUSB0’
Hello @alp-by,
1st of all, did you add the pyserial package in the App Daemon configuration ?
system_packages: []
python_packages:
  - pyserial
init_commands: []
log_level: info
I use the same syntax as you did to open the serial port… and it works nicely for me.
Hope this helps.
Hello Olivierov,
thank you for your quite answer.
Yes, I have pyserial there:
that’s my config.
system_packages: []
python_packages:
  • pyserial
    init_commands: []
I have AppDaemon 4 Current version: 0.5.2
would you please share the persmissions for the serial port at your linux system? maybe it it’s working because of it.
My error message: OSError: [Errno 5] I/O error: ‘/dev/ttyUSB0’ shows that /dev/ttyUSB0 exists in the system, but somehow I\O error rised :frowning:
the reason was → needed to add my hass user to dialout group:
sudo usermod -a -G dialout hass
I will do some extra testing afterwards
Hi @alp-by,
My system runs on RPi4 with the standard installation.
I also use the same revision of AppDaemon than you.
I use the SSH & Web Terminal (Current version: 8.1.1) to open a session to hassio.
[edit]
Core: core-2021.4.4
Supervisor: supervisor-2021.04.0
Operating System: Home Assistant OS 5.13
[/edit]
I’m absolutely not a Linux user, so please apologize if I answer not correctly to your requests…
If you need some other information, please feel free to ask me by giving me the command I need to type.
HTH
Olivier
#whoami
root
#ll /dev/ttyUSB0
crw-rw----    1 root     audio     188,   0 Apr 11 13:07 /dev/ttyUSB0
#cat /etc/group
root:x:0:root
bin:x:1:root,bin,daemon
daemon:x:2:root,bin,daemon
sys:x:3:root,bin,adm
adm:x:4:root,adm,daemon
tty:x:5:
disk:x:6:root,adm
lp:x:7:lp
mem:x:8:
kmem:x:9:
wheel:x:10:root,hassio
floppy:x:11:root
mail:x:12:mail
news:x:13:news
uucp:x:14:uucp
man:x:15:man
cron:x:16:cron
console:x:17:
audio:x:18:
cdrom:x:19:
dialout:x:20:root
ftp:x:21:
sshd:x:22:
input:x:23:
at:x:25:at
tape:x:26:root
video:x:27:root
netdev:x:28:
readproc:x:30:
squid:x:31:squid
xfs:x:33:xfs
kvm:x:34:kvm
games:x:35:
shadow:x:42:
cdrw:x:80:
usb:x:85:
vpopmail:x:89:
users:x:100:games
ntp:x:123:
nofiles:x:200:
smmsp:x:209:smmsp
locate:x:245:
abuild:x:300:
utmp:x:406:
ping:x:999:
nogroup:x:65533:
nobody:x:65534:
docker:x:101:
messagebus:x:102:messagebus
plugdev:x:103:
hassio:x:1000:
#ha hardware info (extract)
- attributes:
    DEVLINKS: /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D34L7RNO-if00-port0 /dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0-port0
    DEVNAME: /dev/
    DEVPATH: /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/ttyUSB0/tty/ttyUSB0
    ID_BUS: usb
    ID_MODEL: FT230X_Basic_UART
    ID_MODEL_ENC: FT230X\x20Basic\x20UART
    ID_MODEL_ID: "6015"
    ID_PATH: platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0
    ID_PATH_TAG: platform-fd500000_pcie-pci-0000_01_00_0-usb-0_1_4_1_0
    ID_REVISION: "1000"
    ID_SERIAL: FTDI_FT230X_Basic_UART_D34L7RNO
    ID_SERIAL_SHORT: D34L7RNO
    ID_TYPE: generic
    ID_USB_DRIVER: ftdi_sio
    ID_USB_INTERFACE_NUM: "00"
    ID_USB_INTERFACES: ':ffffff:'
    ID_VENDOR: FTDI
    ID_VENDOR_ENC: FTDI
    ID_VENDOR_ID: "0403"
    MAJOR: "188"
    MINOR: "0"
    SUBSYSTEM: tty
    TAGS: ':systemd:'
    USEC_INITIALIZED: "4494105"
  by_id: /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D34L7RNO-if00-port0
  dev_path: /dev/ttyUSB0
  subsystem: tty
  sysfs: /sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/ttyUSB0/tty/ttyUSB0
Here is my app without the frame parsing and some extra code.
May be it will useful for you to see how I manage the serial port because I remember I had some connection issues at the beginning of writing it.
import appdaemon.plugins.hass.hassapi as hass
import serial
from threading import Thread
import time
# REMOVED extra lines
# RS_TIC App
# Args:
class Context():
    worker_thread = None
    thread_runs = True
    serial_port = None
class RS_TIC(hass.Hass):
    def initialize(self):
        self.log("initialize starting ++++++++++++++++++++++++++++++++++++++++++++++++++++")
        Context.thread_runs = True
        # Create worker thread
        Context.worker_thread = Thread(target=self.worker)
        Context.worker_thread.daemon = True
        Context.worker_thread.start()
        self.log("initialize exit ---------------------------------------------------------")
    def worker(self):
        self.log("worker thread starting ---------------------------------------------------------")
    # constants declaration ------------------------------------------------------
        # Enedis delimiter characters
        bStartOfFrame   = b'\x02'
        bEndOfFrame     = b'\x03'
        StartOfGroup    = '\n'
        EndOfGroup      = '\r'
        FieldSeparator  = '\t'
        GroupSeparator  = '\x00'
        self.log('Context.thread_runs=%s', str(Context.thread_runs))
        self.log('enter while main loop >>>>>>>>>>>')
    # thread loop ------------------------------------------------------
        while Context.thread_runs:
        # open the serial port ------------------------------------------------------
            try:
                if Context.serial_port == None:
                    self.log('Try to open serial port')
                    Context.serial_port = serial.Serial(
                        port = '/dev/ttyUSB0',
                        bytesize = serial.SEVENBITS,    # 7bits
                        parity = serial.PARITY_EVEN,    # even parity
                        timeout = None                  # None => read is blocking, 0 => read is non-blocking
                # end if 'if Context.serial_port == None:'
            except Exception as e:
                self.log('/!\\Error occured when opening serial port /!\\')
                self.log(e)
                time.sleep(5)
                continue
            # end of 'try:''
        # listen the serial port ------------------------------------------------------
            try:
                frame = Context.serial_port.read_until(bEndOfFrame)
                self.log('/!\\ Error occured when reading serial port /!\\')
                self.log(e)
                Context.serial_port = None
                time.sleep(5)
                continue
            # end of 'try:''
# Frame parsing
        # end of 'while Context.thread_runs:'
        self.log('exit while main loop <<<<<<<<<<<')
        self.log("worker thread exit ???????????????????????????????????????????????")
    def terminate(self):
        self.log('terminate enter ---------------------------------------')
        self.log('set Context.thread_runs = False')
        Context.worker_thread.join()
        if Context.serial_port != None:
            Context.serial_port.close()
            self.log('Serial port closed')
        self.log('terminate exit ---------------------------------------')
Thank you! for your quite reply
btw… I used some part of your code in my app. (i.e. closing port at def terminate(self))…thank you for the example, but any wait I have the following issue.
when app is loading first time → it works.
but in case of my app (appdaemon) is reloading serial port is not openning again and I have the same error message “OSError: [Errno 5] I/O error: ‘/dev/ttyUSB0’”
restarting of appdaemon doesn’t solve the problem.
Don’t you have such a problem?
It looks like the serial port is still open when you try to open it again. Are you sure your program is executing the ‘def terminate’ clause?
I don’t remember why I had to implement my program within a thread, but it may be a reason why…
Could you add logs to be sure your program executes the ‘def terminate’ clause?
[edit]
Here are the logs when I stop AppDaemon with the threaded code I provided:
2021-04-16 14:57:53.381261 INFO AppDaemon: SIGTERM Received
2021-04-16 14:57:53.382243 INFO AppDaemon: AppDaemon is shutting down
2021-04-16 14:57:53.393258 INFO HASS: Disconnecting from Home Assistant
2021-04-16 14:57:54.028068 INFO AppDaemon: Removing module /config/appdaemon/apps/RS_TIC.py
2021-04-16 14:57:54.029151 INFO AppDaemon: Removing module /config/appdaemon/apps/hello.py
2021-04-16 14:57:54.030337 INFO AppDaemon: Terminating RS_TIC
2021-04-16 14:57:54.031334 INFO AppDaemon: Calling terminate() for RS_TIC
2021-04-16 14:57:54.034749 INFO RS_TIC: terminate enter ---------------------------------------
2021-04-16 14:57:54.038841 INFO RS_TIC: set Context.thread_runs = False
2021-04-16 14:57:55.393748 INFO RS_TIC: Context.thread_runs=False
2021-04-16 14:57:55.396477 INFO RS_TIC: exit while main loop <<<<<<<<<<<
2021-04-16 14:57:55.398618 INFO RS_TIC: worker thread exit ???????????????????????????????????????????????
2021-04-16 14:57:55.404566 INFO RS_TIC: Serial port closed
2021-04-16 14:57:55.410790 INFO RS_TIC: terminate exit ---------------------------------------
2021-04-16 14:57:55.414316 INFO AppDaemon: Shutting down webserver
2021-04-16 14:57:55.416473 INFO AppDaemon: Saving all namespaces
2021-04-16 14:57:55.417518 INFO AppDaemon: AppDaemon is stopped.
Hope this helps
Yes… I have it. It is called (the reason why you don’t see the log message for closing port - because it isn’t open at the moment due to the issue from the previous message, but basically it works:
2021-04-16 16:18:16.759580 INFO curtain: Curtain MQTT: -> terminate exit
2021-04-16 16:18:16.753540 INFO curtain: Curtain MQTT: -> terminate enter
2021-04-16 16:18:16.751371 INFO AppDaemon: Calling terminate() for curtain
This is strange…
I made some tests:
  1. I’ve moved my code from my thread to the def Initialize() clause… after this modification, the program never exits from the def Initialize() clause, and it never executes the def Terminate() clause… and so the close() method is never called :roll_eyes:
  2. I also removed the try: except clauses…
  3. I’ve also removed the close() method…
  4. I’ve changed the read timeout from 0 to 1 (non-blocking reads)…
  5. I’ve removed the infinite read loop…
  6. I’ve removed my Context class, and I’ve declared the serial port object as self.serial_port
  7. I’ve disconnected the serial port source of data… :upside_down_face:
  8. I’ve disconnected/reconnected the USB to Serial device from my RPi… :crazy_face: which is not a good idea, because the system have changed the name of my USB to serial converter from ttyUSB0 to ttyUSB1 (I had to reboot the whole system :grimacing:)
Except for the last test, I’m still able to start/stop AppDaemon without error and the data from the serial port are well refreshed (except for the before last test, of course :rofl:).
Could you please tell me more about your issue?
  1. How is this behavior triggered?
  2. If you can, how do you manually trig this behavior?
  3. What kind of device is connected to the serial port?
  4. What kind of data do you receive on your serial port?
  5. How often you receive data?
  6. Are you writing to the serial port?
  7. What is your system (RPi, NUC, …)?
  8. What is the Home Assistant and OS revision?
  9. Could you provide me your code (in PM if you want) for a code review or tests on my system?
Have a nice weekend.
you only need to use a thread if you use a while loop.
AD isnt happy when you keep an app busy, because then the app cant do its work, thats why a subthread is needed for a while loop.
and indeed you need to stop the loop in the terminate function, because without that the loop keeps running.
as i see it @alp-by is also using mqtt.
if so then also connections that are setup to the mqtt server need to be correctly stopped in the terminate function.
the best way to see if the while loop is actually stopped by the terminate function is to put a log line AFTER the while loop.
working with subthreads is not the easiest part from AD. and you need to be very carefull that you really make sure everything is correctly terminated.
but this is actually stuff that doesnt belong in this topic. because its AD related, not addon related.
my advise is to come with this subject to our discord server.
but how to do if? I don’t open any MQTT connection at my AP. I use the native AD functionality for it … and in my application I just to the analyzing of MQTT message.
how to do it? where is it?
  1. Firstly I add serial port to my system (because it’s vitural connected via Virtual Machine eSXI), then I get new /dev/ttyUSB0 device and then when I start AD and my application I see the initialization message. Then I restart the application (by changing somecode there) or it is possible to stop AD addon → in this case I see “close” message
  2. It is USB-RS485 reader.
  3. Just the regular data, nothing special. A kind of Modbus protocol
  4. As soon as data is requested from AD
  5. yes.
  6. I use VM with DEbian Linux installed inside. VM is under eSXI solution
  7. Version supervisor-2021.04.0
import hassapi as hass
import datetime
import serial
import json
import mqttapi as mqtt
import struct
import binascii
from binascii import a2b_hex, b2a_hex
INITIAL_MODBUS = 0xFFFF
INITIAL_DF1 = 0x0000
table = (
0x0000, 0xC0C1, 0xC181, 0x0140, 0xC301, 0x03C0, 0x0280, 0xC241,
0xC601, 0x06C0, 0x0780, 0xC741, 0x0500, 0xC5C1, 0xC481, 0x0440,
0xCC01, 0x0CC0, 0x0D80, 0xCD41, 0x0F00, 0xCFC1, 0xCE81, 0x0E40,
0x0A00, 0xCAC1, 0xCB81, 0x0B40, 0xC901, 0x09C0, 0x0880, 0xC841,
0xD801, 0x18C0, 0x1980, 0xD941, 0x1B00, 0xDBC1, 0xDA81, 0x1A40,
0x1E00, 0xDEC1, 0xDF81, 0x1F40, 0xDD01, 0x1DC0, 0x1C80, 0xDC41,
0x1400, 0xD4C1, 0xD581, 0x1540, 0xD701, 0x17C0, 0x1680, 0xD641,
0xD201, 0x12C0, 0x1380, 0xD341, 0x1100, 0xD1C1, 0xD081, 0x1040,
0xF001, 0x30C0, 0x3180, 0xF141, 0x3300, 0xF3C1, 0xF281, 0x3240,
0x3600, 0xF6C1, 0xF781, 0x3740, 0xF501, 0x35C0, 0x3480, 0xF441,
0x3C00, 0xFCC1, 0xFD81, 0x3D40, 0xFF01, 0x3FC0, 0x3E80, 0xFE41,
0xFA01, 0x3AC0, 0x3B80, 0xFB41, 0x3900, 0xF9C1, 0xF881, 0x3840,
0x2800, 0xE8C1, 0xE981, 0x2940, 0xEB01, 0x2BC0, 0x2A80, 0xEA41,
0xEE01, 0x2EC0, 0x2F80, 0xEF41, 0x2D00, 0xEDC1, 0xEC81, 0x2C40,
0xE401, 0x24C0, 0x2580, 0xE541, 0x2700, 0xE7C1, 0xE681, 0x2640,
0x2200, 0xE2C1, 0xE381, 0x2340, 0xE101, 0x21C0, 0x2080, 0xE041,
0xA001, 0x60C0, 0x6180, 0xA141, 0x6300, 0xA3C1, 0xA281, 0x6240,
0x6600, 0xA6C1, 0xA781, 0x6740, 0xA501, 0x65C0, 0x6480, 0xA441,
0x6C00, 0xACC1, 0xAD81, 0x6D40, 0xAF01, 0x6FC0, 0x6E80, 0xAE41,
0xAA01, 0x6AC0, 0x6B80, 0xAB41, 0x6900, 0xA9C1, 0xA881, 0x6840,
0x7800, 0xB8C1, 0xB981, 0x7940, 0xBB01, 0x7BC0, 0x7A80, 0xBA41,
0xBE01, 0x7EC0, 0x7F80, 0xBF41, 0x7D00, 0xBDC1, 0xBC81, 0x7C40,
0xB401, 0x74C0, 0x7580, 0xB541, 0x7700, 0xB7C1, 0xB681, 0x7640,
0x7200, 0xB2C1, 0xB381, 0x7340, 0xB101, 0x71C0, 0x7080, 0xB041,
0x5000, 0x90C1, 0x9181, 0x5140, 0x9301, 0x53C0, 0x5280, 0x9241,
0x9601, 0x56C0, 0x5780, 0x9741, 0x5500, 0x95C1, 0x9481, 0x5440,
0x9C01, 0x5CC0, 0x5D80, 0x9D41, 0x5F00, 0x9FC1, 0x9E81, 0x5E40,
0x5A00, 0x9AC1, 0x9B81, 0x5B40, 0x9901, 0x59C0, 0x5880, 0x9841,
0x8801, 0x48C0, 0x4980, 0x8941, 0x4B00, 0x8BC1, 0x8A81, 0x4A40,
0x4E00, 0x8EC1, 0x8F81, 0x4F40, 0x8D01, 0x4DC0, 0x4C80, 0x8C41,
0x4400, 0x84C1, 0x8581, 0x4540, 0x8701, 0x47C0, 0x4680, 0x8641,
0x8201, 0x42C0, 0x4380, 0x8341, 0x4100, 0x81C1, 0x8081, 0x4040 )
# - mqtt topic
# - mqtt payload
# - address 0x3412 = Low byte: 34, High byte:12
###input_number.curtains_a2_1
gt_mqtt_units = [
            ["/devices/a2/curtains_1", "OPEN",  "0x0101"],
            ["/devices/a2/curtains_1", "CLOSE", "0x0101"],
            ["/devices/a2/curtains_1", "STOP",  "0x0101"],
            ["/devices/a2/curtains_1", "ADDR",  " "],
            ["/devices/a2/curtains_2", "OPEN",  "0xFEFE"],
            ["/devices/a2/curtains_2", "CLOSE", "0xFEFE"],
            ["/devices/a2/curtains_2", "STOP",  "0xFEFE"]
gt_units = [
# loggia
            ["input_number.curtains_a2_1", "0x0101"],  #0x3412
            ["input_number.curtains_a2_2", "0xFEFE"],
#            ["input_number.curtains_a2_2", "0x0a02"]
class Context():
    serial_port = None
#        $output = pack("C*",0x55,0xFE,0xFE,0x03,0x01,0xB9,0x24); #55FEFE0301B924
class curtain(mqtt.Mqtt, hass.Hass):
    self.debug("Hello from AppDaemon")
    self.debug("Hello from AppDaemon ddd " + str(Context.serial_port))
    try:
          self.debug("MQTT: -> open serial ... ")
            port = '/dev/ttyUSB0', #/dev/ttyUSB0
            timeout = 1
      self.debug("MQTT: -> serial is opened: " + Context.serial_port.name)
      self.debug("MQTT: -> open serial ERROR " + str(e))
#    unit[0] - virtual sensor (var)
#    unit[1] - real sensor
    for unit in gt_mqtt_units:
      # run listen
      self.listen_event(self.mqtt_callback, 'MQTT_MESSAGE', topic=unit[0], payload=unit[1], v_addr=unit[2], namespace = "mqtt")
    for unit in gt_units:
      # run listen
      self.listen_state(self.callback, unit[0], addr = unit[1])
#    except Exception as e:
#        self.debug("MQTT: -> open serial ERROR ")
#        pass
#    finally:
#    self.ser = serial.Serial(
#        port = '/dev/ttyUSB00000', #/dev/ttyUSB0
#        baudrate = 9600,                # 9600 bauds
#        bytesize = serial.EIGHTBITS,    # 7bits
#        parity = serial.PARITY_NONE,    # even parity
#        stopbits = serial.STOPBITS_ONE, # 1 stop bit
#        xonxoff = False,                # no flow control
#        timeout = 1
#    self.debug("MQTT: -> open serial " + self.ser.name)
#   timer is needed to get the position
    time_1min = datetime.time(0, 0, 0)
    self.run_minutely(self.check_pos, time_1min)
#    ser.close()
    self.debug("MQTT: -> terminate enter ")
        self.debug("MQTT: -> serial port closed ")
    self.debug("MQTT: -> terminate exit ")
  def check_pos(self, kwargs):
    self.debug("MQTT: timer -> get position ")
#      unit[0] = input_number.curtains_a2_1
#      unit[1] = addr
      str_out = self.make_serial_out_get_position(addr = unit[1])
      self.debug("MQTT: serial out " +str(str_out))
        if Context.serial_port.isOpen():
          Context.serial_port.write(str_out)
          Context.serial_port.flush()
          try:
              #read
              doc = Context.serial_port.readline()
              self.debug("MQTT 2. Recieved 1a:" + str(doc))
              self.debug("MQTT Error : try to parse an incomplete message")
              pass
#        str_out
          str2 = struct.unpack('B B B B B B B B', doc)
          str1 = []
          str1.append(struct.pack('B', str2[0]))
          str1.append(struct.pack('B', str2[1]))
          str1.append(struct.pack('B', str2[2]))
          str1.append(struct.pack('B', str2[3]))
          str1.append(struct.pack('B', str2[4]))
          str1.append(struct.pack('B', str2[5]))
#        str1.append(struct.pack('B', int('{:02x}'.format(doc[1]))))
          crc1 = calcString(str1, INITIAL_MODBUS)
          crc1_high, crc1_low = bytes(crc1)
          self.debug("MQTT 2. Recieved 1b:" + str(str2))
          self.debug("MQTT 2. Recieved 1c:" + str(str2[5]))
          if ( crc1_low == '0x{:02x}'.format(str2[6]) and
              crc1_high == '0x{:02x}'.format(str2[7]) ):
            self.debug("MQTT CRC OK:")
          position = int('0x{:02x}'.format(doc[5]),16)
        #doc[5] просто в int значение
#        self.call_service("input_number/set_value", entity_id = unit[0], value = position)
#        self.set_value(unit[0], position)
          self.debug("MQTT 2. set_value:" + str(unit[0]) + " " + str(position))
          self.debug("MQTT 2. Recieved:" + str(position))
        else:
          self.debug("MQTT: Error - serial closed ")
  def callback(self, entity, attribute, old, new, kwargs):
    addr_high, addr_low = bytes(int(kwargs.get('addr'),16))
    if isInt(int(float(self.get_state(entity)))):
      self.debug("MQTT: Position" + str(int(float(self.get_state(entity)))))
      position = hex(int(float(self.get_state(entity))))
      command = '0x04'
      str_out = self.make_serial_out(addr = kwargs.get('addr'), command = command, data = position)
#      command = '0x01'
#      str_out = self.make_serial_out(addr = kwargs.get('addr'), command = command, data = "")
        try:
            #read
            self.debug("MQTT: Position Recieved 1a:" + str(doc))
            pass
      else:
        self.debug("MQTT: Error - serial closed")
    else:
      self.debug("MQTT: Position is not int" + self.get_state(entity))
  def mqtt_callback(self, event_name, data, kwargs): #data, kwargs): #self, event_name, *args, **kwargs):
    payload = kwargs.get('payload')
    self.debug("MQTT-mqtt_callback: Command ")
    if payload == 'OPEN':
      addr_high, addr_low = bytes(int(kwargs.get('v_addr'),16))
      command = '0x01'
      str_out = self.make_serial_out(addr = kwargs.get('v_addr'), command = command, data = "")
    elif payload == 'CLOSE':
      command = '0x02'
    elif payload == 'STOP':
      command = '0x03'
    elif payload == 'ADDR':
#      self.check_pos(self)
      command = ''
      str_out = self.make_serial_out_set_addr(addr_curr = "0x0000", addr = self.get_state('input_text.curtains_new_addr'))
    self.debug("MQTT: Command " + command)
    self.debug("MQTT: serial out " + str(str_out))
      try:
            #read
          self.debug("MQTT-mqtt_callback: Command Recieved 1a:" + str(doc))
          pass
    else:
# compose serial string | commands: OPEN CLOSE STOP
  def make_serial_out(self, **kwargs):
      command = kwargs.get('command')
      data = kwargs.get('data')
      str1 = []
      str1.append(struct.pack('B', int('0x55',16)))
      str1.append(struct.pack('B', int(addr_low,16)))
      str1.append(struct.pack('B', int(addr_high,16)))
      str1.append(struct.pack('B', int('0x03',16)))
      str1.append(struct.pack('B', int(command,16)))
      if data != "":
        str1.append(struct.pack('B', int(data,16)))
      str1.append(struct.pack('B', int(crc1_low,16)))
      str1.append(struct.pack('B', int(crc1_high,16)))
      if data != "":
        str_out = struct.pack('B B B B B B B B',
                int('0x55',16),
                int(addr_low,16),
                int(addr_high,16),
                int('0x03',16),
                int(command,16),
                int(data,16),
                int(crc1_low,16),
                int(crc1_high,16))
      else:
        str_out = struct.pack('B B B B B B B',
                int('0x55',16),
                int(addr_low,16),
                int(addr_high,16),
                int('0x03',16),
                int(command,16),
                int(crc1_low,16),
                int(crc1_high,16))
      return str_out
# compose serial string | command: set new address
  def make_serial_out_set_addr(self, **kwargs):
      addr_high, addr_low = bytes(int(kwargs.get('addr_curr'),16))
      addr_n_high, addr_n_low = bytes(int(kwargs.get('addr'),16))
      str1 = []
      str1.append(struct.pack('B', int('0x02',16)))
      str1.append(struct.pack('B', int('0x00',16)))
      str1.append(struct.pack('B', int(addr_n_low,16)))
      str1.append(struct.pack('B', int(addr_n_high,16)))
      str_out = struct.pack('B B B B B B B B B B',
                int('0x55',16),
                int(addr_low,16),
                int(addr_high,16),
                int('0x02',16),
                int('0x00',16),
                int('0x02',16),
                int(addr_n_low,16),
                int(addr_n_high,16),
                int(crc1_low,16),
                int(crc1_high,16))
      return str_out
  def make_serial_out_get_position(self, **kwargs):
      str1 = []
      str1.append(struct.pack('B', int('0x01',16)))
                int('0x55',16),
                int(addr_low,16),
                int(addr_high,16),
                int('0x01',16),
                int('0x02',16),
                int('0x01',16),
                int(crc1_low,16),
                int(crc1_high,16))
      return str_out
  def do_process (self, entity, attribute, old, new, kwargs):
    clicks = '1'
    Context.serial_port.write(bytes(clicks.encode('ascii')))
    buffer = ""
    while True:
        try:
                buffer = ser.readline()
                self.log(buffer)
                doc = json.loads(buffer)
                read_b1 = doc["b1"]
                read_b2 = doc["b2"]
                read_s1 = doc["s1"]
                read_s2 = doc["s2"]
                self.log(read_b1)
                buffer = ""
        except json.JSONDecodeError:
                self.log("Error : try to parse an incomplete message")
  def debug(self, text):
    if self.args["DEBUG"] == 1:
      self.log("Curtain " + text)
def isInt(value):
  try:
    int(value)
    return True
  except ValueError:
    return False
  except TypeError:
    return False
def calcByte( ch, crc):
    #Given a new Byte and previous CRC, Calc a new CRC-16"""
    if type(ch) == type("c"):
        by = ord(ch)
    else:
        by = ch
    crc = (crc >> 8) ^ table[(crc ^ by) & 0xFF]
    return (crc & 0xFFFF)
def calcString(st, crc):
    #Given a bunary string and starting CRC, Calc a final CRC-16 """
    for ch in st:
        crc = (crc >> 8) ^ table[(crc ^ ord(ch)) & 0xFF]
    return crc
def bytes(num):
    return hex(num >> 8), hex(num & 0xFF)
def ascii_to_packed_hex(string_data):
    # convert each pair of hex digits in the string into an integer
    # then convert those to characters and join them into a string
    return ''.join(chr(int(digits, 16)) for digits in
                (string_data[x:x+2] for x in range(0, len(string_data), 2)))
def decode_int(num):
    # remove 0x at the start
    dec = hex(num)[2:]
    # if num is long hex() will add L at the end
    dec = dec.replace("L", "", 1)
    if len(dec) % 2 == 1:
        dec = "0" + dec
    return a2b_hex(dec)
#v_sensor = kwargs.get('v_sensor')
#    aaa = bytes.fromhex('01')
#    self.debug("MQTT: HEX    " +str(ascii_to_packed_hex('55')))
#    ppp = decode_int('\x55')
#    self.debug("MQTT: st1    " +str(ppp))
#    st = "\x55" + "\x12\x34" + "\x03" + "\x04" + "\x32"
#55 - фиксированный префикс
#12 34  - адрес устройства
#03 - отправить команду
#04 - положение карниза
#32 - число 50 в hex
#С9 38 - CRC16/modbus с обратным расположением байтов
#    crc = calcString(st, INITIAL_MODBUS)
#    crc_high, crc_low = bytes(crc)
    #addr_high, addr_low = bytes(int(kwargs.get('v_addr'),16))
    ##position = hex(int(float(self.get_state(entity))))
    #command = '0x04'
#    aaa = []
#    aaa.append(ascii_to_packed_hex('55'))
#    aaa.append(ascii_to_packed_hex('aa'))
#    aaa.append(ascii_to_packed_hex('01'))
#    self.debug("MQTT: HEX    " +str(aaa))
#    self.debug("MQTT: st    " +st)
#    str1 = struct.pack('B B B B B B B B',
#      int('0x55',16),
#      int(addr_low,16),
#      int(addr_high,16),
#      int('0x03',16),
#      int('0x04',16),
#      int(position,16),
#      int(crc_low,16),
#      int(crc_high,16))
#    aaa1 = []
    #aaa1.append(ascii_to_packed_hex(int('0x55',16)))
    #byte_body = binascii.a2b_hex(struct.pack('B',int('0x55',16)))
#    hexadecimal_string = "55"
#    byte_array = bytearray.fromhex(hexadecimal_string)
#    self.debug("MQTT: byte_body    " +str(byte_array))
#    self.debug("MQTT: st11111    " +str(crc1_high) + " " + str(crc1_low))
#    self.debug("MQTT: st222    " +str(str2))
#    #str1 = struct.pack('H H H H H H H', '55', addr_low, addr_high, '3', position, crc_low, crc_high)
#    self.ser.write(b'hello')
#    self.debug("MQTT: crc" + str(crc_low) + " " + str(crc_high))
#    self.debug("MQTT: addr" + str(addr_low) + " " + str(addr_high))
#    self.debug("MQTT: pos" + str(position))
#    self.debug("MQTT: str1 " +str(str2))
#    if ser.isOpen():
#send data
#        ser.write(data)
#        ser.flush()
#        try:
#            #read
#            doc = ser.readline()
#            self.log(2)
#            self.log("Error : try to parse an incomplete message")
#            pass
#      ser.close()
#      doc = json.loads(doc)
#      self.log("2. Recieved: %s\n",doc)
#    str1 = []
#    str1.append(struct.pack('B', int('0x55',16)))
#    str1.append(struct.pack('B', int(addr_low,16)))
#    str1.append(struct.pack('B', int(addr_high,16)))
#    str1.append(struct.pack('B', int('0x03',16)))
#    str1.append(struct.pack('B', int(command,16)))
#    crc1 = calcString(str1, INITIAL_MODBUS)
#    crc1_high, crc1_low = bytes(crc1)
#    str1.append(struct.pack('B', int(crc1_low,16)))
#    str1.append(struct.pack('B', int(crc1_high,16)))
#    str_out = struct.pack('B B B B B B B',
#                int('0x55',16),
###                int(addr_low,16),
#                int('0x03',16),
##                int(command,16),
#                int(crc1_low,16),
#                int(crc1_high,16))
#    if ser.isOpen():
#send data
#        ser.write(data)
#        ser.flush()
#        try:
#            #read
#            self.log(2)
#            pass
#      ser.close()
 #   else:
 #     self.debug("MQTT: not Int " + self.get_state(entity))
there is a lot in the code that i see what can cause trouble. but also i believe a lot of obsolete stuff.
i just took a glance at it, but to little to find the problem that causes your issues.
when you come to our discord ill take the time to go through stuff with you. that would take up to much overhere.
I am there. Ok. i will post my code there
Even though it’s in spanish, I think it could be helpful the examples used here to see the advantages to use appdaemon for some automations in Home Assistant: Cómo usar AppDaemon en Home Assistant - Paciencia Digital. Domótica, Estadística y Datos
Hi, I have a noob question, can you using AppDaemon use this API: AirMusic to control my internet radios via media_control card in lovelace?
I’m trying to integrate my internet radios with HA, but I have absolutely no programing skills :wink:
yes its possible, but completely without programming skills its not going to be easy.
youll need to learn a lot for it.
