Home Assistant Community Add-on: Nginx Proxy Manager
Hi All,
Does someone have Nextcloud also running behind Proxy? Everything i tried doesn’t work.
RPi 1 (192.168.100.24) HA and Proxy Manager
RPi 2 (192.168.100.25) Nextcloud running on Apache2
When i change everything HA is working behind proxy
https://hassio.my-domain.com
https://nextcloud.my-domain.com
When i try to connect to nextcloud from outside sometimes i can connect but can’t login.
The app can access but can’t login.
Tried many different things in the
/var/www/html/config/config.php
and many things in the proxy manager as well.
But every time it failed…
So does someone have good documented tutor how to do this?
Check my post no. 248 above (I had to make changes only in config.php)
You mean this part?
https://docs.nextcloud.com/server/13/admin_manual/configuration_server/reverse_proxy_configuration.html#overwrite-parameters
  'trusted_proxies'   => ['10.0.0.1'],
  'overwritehost'     => 'ssl-proxy.tld',
  'overwriteprotocol' => 'https',
  'overwritewebroot'  => '/domain.tld/nextcloud',
  'overwritecondaddr' => '^10\.0\.0\.1$',
WIth NPM you would not need all of them (on most Nextcloud installs they are not even enabled).
These are the only changes I made:
  'trusted_domains' =>
  array (
    0 => 'localhost',
    1 => '192.168.0.100',
    2 => 'nextcloud.xxx.duckdns.org',
  'overwrite.cli.url' => 'https://nextcloud.xxx.duckdns.org',
I’m trying to get local access to a device, which doesn’t have authorization via Home Assistant.
It’s accessible via a local ip and portnumber. But not from the outside.
What I would like to have:
  • Add an iframe to Home Assistant to the local device (has to be https)
  • Show the iframe when accessing Home Assistant from an external IP
  • Do not allow access when accessing the iframe url directly
What I did:
  • Made a dns entry for this device
  • Added a nginx proxy entry for this devices with a certificate (so now the device is accessible over https from the outside)
  • Add an access list to nginx, with local IP ranges (match any)
But I;m struggling to put in the right ranges in the access list. What are the IP ranges I should put in to have the device accessible via Home Assistant (Supervised via docker)?
Is it even possible?
Local access only is sadly not possible
NPM is fantastic, and now I want to use it to host an html file on the web. Is that possible? Where would I put the file, and how would I point to it?
Cheers, Richard
How can i get telegram to work. I found this, but how do i use this in Ngix proxy manager.
I tried to add a location but after saving it went “offline”
For your nginx configuration, add this:
Copy to clipboard
location /api/telegram_webhooks {
	proxy_pass http://YOUR_LOCAL_HA_IP_ADDRESS:8123/api/telegram_webhooks;
	proxy_http_version 1.1;
	proxy_set_header Host $host;
	proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
	proxy_set_header Upgrade $http_upgrade;
	proxy_set_header Connection $connection_upgrade;
	allow 149.154.167.197/32;
	allow 149.154.167.198/31;
	allow 149.154.167.200/29;
	allow 149.154.167.208/28;
	allow 149.154.167.224/29;
	allow 149.154.167.232/31;
	deny all;
But where should i past this?
Adjust as needed and past it in Advanced.
i did that to but proxy still went offline
Command failed: /usr/sbin/nginx -t -g “error_log off;”
nginx: [emerg] unknown “connection_upgrade” variable
nginx: configuration file /etc/nginx/nginx.conf test failed
try proxy_set_header Connection "upgrade"; instead
Can this add-on be used to host a static website just containing a few HTML/CSS/JS files? Or would i need to install the Apache2 add-on or similar?
Thx That worked
I am using the official .VMDK and installed HA. Using duckdns and other addons. But now I have installed the NGINX addon and it seems to run fine, I only can’t see the open WEB UI button anyware. Also tried to open http://192.168.1.xxx:81 but nothing happens. Any idea??
What addon have you installed? NGINX Home Assistant SSL proxy or Nginx Proxy Manager?
NGINX Home Assistant SSL proxy is set to reverse proxy only with Home Assistant. There is no Open WEB UI button in the addon.
With Nginx Proxy Manager (to which this topic relates to) you can reverse proxy (probably) any other services.
You’re welcome
Yes, thanks!
And for those searching for how to disable Lets Encrypt in the DuckDNS add-on, just set the accept TOS flag to false in your configuration and restart the add-on
I get error messages when I try to create a certificate in NPM. I wonder if it may be forwarding of the ports on the router that is the problem? Is this correct?
EDIT:
After posting this, I changed ports 80 - 80. This allowed me to generate SSL certificate.
But there is still something wrong. Any suggestions???
You should forward port 443 to port 443, not to 8123. NGINX routes the traffic to 8123 afterwards.
