Home Assistant Community Add-on: Nginx Proxy Manager
Hello! Can someone write a tutorial to addon nginx proxy manager? I have a probelm with it, probably it will be easy for you, not for me
I am using newest hassio in docker on ubuntu with duckdns (should I “accept_terms” set to true in this addon aswell? i did it) Somehow I configure it well and i can acces hassio by typing mydomain.duckdns.org . My ubuntu ip is 192.168.100.6. I just want to type in addres line (for example) mydomain.duckdns.org/nginx and be connected to 192.168.100.6:81 (nginx proxy manager) so i clicked edit in existing proxy host, moved to “custom locations” add location: /nginx , scheme https ip: 192.168.100.6 forward port: 81. And after that when i go mydomian.duckdns.org it says 502 bad gateway. If i change Scheme https to http i got blank white page. What i am doing wrong? I want to type mydomian.duckdns.org/router and be connected to 192.168.100.1:80 aswell.
Second question: Is there a possibility do add a config (i am very low with that) to acces nginx proxy manager without opening 81 port? I just want have a minimal amount of ports opened, to make proxy manager work i have 81, 443 opened only.
Thanks in advance
Just wondering if there is a way to reset this addon completely?
I have reinstalled it recently and it will not allow me to log in using the default username and password or the one i had set up when i had the addon installed before:
[4/23/2019] [1:55:47 PM] [Express ] › :warning: warning No relevant user found
It works great, so easy! Thanks a lot for porting this!
I only have an issue with creating a sub domain for the Pi-Hole addon. Other subdomains are working fine.
In Nginx Proxy Manager I created a poxy host as follows:
When I go to pihole.mydomain.com I get redirected to http://pihole.mydomain.com:4865/admin, but the page doesn’t load, I get an ERR_CONNECTION_REFUSED.
Does anyone have this working? Would love to set this up for Pi-Hole.
Thanks!
I also use caddy, but I like the look of this too.
I might trial a switch…
i’ve installed the addon but when i request a ssl certificate i got an internal error. The certificate is available but won’t work when i select it ?
I currently use the older Nginx Home Assistant SSL proxy add-on. Should I switch to this one? I started it, but I think they conflict with each other. I think it also disabled the older one after restarting… and I couldn’t access the backend… Just wondering if there was reasons I should get this one working overf the older one. Thanks
If your previous configuration is working and u wont add any other config there is no reason to change.
This addon provides nice ui and it is easier to work with than previous one.
have u used this x-forwarded
if yes, please guide how to add it
I have the same configuration but I have to use pihole.mydomain.com/admin then it works fine.
I don’t use any locations or custom configuration to redirect pihole.mydomain.com to yourip:4865/admin.
Just plain forward to 4865 and then I add the /admin location when I call the URL.
Thanks for replying. Strange, I have the exact same config, but it does not load for me. Also not with pihole.mydomain.com/admin
UPDATE: ESPHome is now available in the sidebar.
Here are my notes for how to set up Nginx Proxy Manager (NPM) for
hassio: 192.168.1.xxx:8123
other server: 192.168.1.yyy:zzzz
In DNS settings for mydomain.com - create a subdomain forward for hassio and other server (I used an A record + dynamicDNS)
forward @.mydomain.com to my home IP 123.45.67.89
forward other.mydomain.com to my home IP 123.45.67.89
In my router - send incoming traffic to hassio to be grabbed by NPM
forward port 80 to 192.168.1.123 Internal Port 80 TCP
forward port 443 to 192.168.1.123 Internal Port 443 TCP
Create a Proxy Host for Hassio
Domain Names: mydomain.com
Scheme: http
Forward Hostname / IP: 192.168.1.xxx
Forward Port: 8123
Enable Websockets Support
SSL Request new Certificate
Create a Proxy Host for other server
Domain Names: other.mydomain.com
Scheme: http
Forward Hostname / IP: 192.168.1.yyy
Forward Port: zzzz
Note: NPM / Let’s Encrypt does not handle wildcard SSL at this time. So request a new SSL Certificate for every subdomain
In Configuration.yaml, comment out the HTTP section if not already done
#http:
# base_url: http://mydomain.com:8123
# ssl_certificate: /ssl/fullchain.pem
# ssl_key: /ssl/privkey.pem
In add-on configs, confirm: “ssl”: false,
My add-on TasmoAdmin is unavailable from the “Open Web UI” link so I link to them directly with http://192.168.1.xxx:9541 etc. and accept the unsecure notice.
I had to set up Grafana as an other server because it does not support Hass.io Ingress, and I need https access to the graphs.
Cheers, Richard
I cant access grafana from internet,
I can access locally but not through internet.
What are nginx conf for grafana
Please guide
Is this right place to ask for guidance?
Dear,
I have one rpi3b+,
I had installed hassio with docker on raspbian.
What should I do to use grafana with https locally as well as from internet.
Guidance needed.
Please guide
Anyone made the switch from Caddy addon to this addon?
:raised_hand:
Further questions?
Thanks for the write up.
For add-ons how can I use ssl for them?
I haven’t. Why would I? Is there some advantage this has over Caddy?
well, my real question was that, are there any advantages over Caddy? From the tone of your response I think your answer is not.
Well that’s only my opinion…
