Home Assistant Community Add-on: Node-RED
Hello - while recently trying to solve a problem with my Node-Red addons, I caught up with some posts here and noticed that there is an official Hass.io Node-Red addon.
I installed my Node-Red addon some time ago using ttps://github.com/notoriousbdg/hassio-addons
I also noticed the word “Deprecated” that is associated with this repository.
Given all of this - how do I upgrade to the official Hass.io and community version of Node-Red?
Edit:
My current version is 0.1.12
The Hass.io version is 0.4.0
But then within Node-Red, it says 0.18.7: Maintenance Release
@TheHookUp overnight my Node-Red stopped connecting to hass.io as well, trying to change base url as you suggested but Node-Red log still says connection cannot be established.
edit: forgot to change the API password when changing the base URL. However now I’m getting lots of invalid login attempt showing up in the front end:
Same here issue - thought I did something stupid but I didn’t make any changes just happened after a reboot.
welcome to the party :wink: …lets hope we find a solution soon
Same here :frowning:
Another one here
I don’t think it is a pure node red problem. Appdaemon add -on does the same.
Confirmed I have the same issue with Appdaemon too.
:raising_hand_man:
Thanks for all the replies.
All of you are confirming an issue, but no one is supplying full details, which we need to find out the issue at hand.
Things we’d need:
  • Hass.io type: Generic Linux (Ubuntu Bionic, xenial?), ResinOS, HassOS?
  • OS version?
  • Hass.io Supervisor version?
  • Beta channel?
  • Home Assistant version?
  • Add-on version?
  • When did this issue start occurring?
  • Is the used server URL in node-red http://hassio/homeassistant?
  • Is the password used by node-red to connect to the server a weird long token like string? Your password? Or empty?
  • Please provide Node-RED add-on logs which shows a failure (or taken at the moment the issue occurred)
  • Please provide Hass.io System logs which shows a failure (or taken at the moment the issue occurred)
Take the answers to these questions and put them into a GitHub ticket (or add it to a matching existing ticket).
Thanks.
My setup:
Hassio / ResinOS
Supervisor 118
Hardware Pi3B
Add-on: AppDaemon, Node Red. Problem with both.
Issue started this morning. My outside lights turned off fine at 3.40 CET, but during the morning it went wrong.
My log (from AppDaemon though):
2018-07-24 17:32:01.100086 WARNING AppDaemon: ------------------------------------------------------------
2018-07-24 17:48:12.888088 WARNING AppDaemon: ------------------------------------------------------------
2018-07-24 17:48:12.890092 WARNING AppDaemon: Unexpected error in worker for App Hjemme:
2018-07-24 17:48:12.893761 WARNING AppDaemon: Worker Ags: {'name': 'Hjemme', 'id': UUID('f435e8a1-cfcc-46a6-8265-f8dcb3ee4f1a'), 'type': 'attr', 'function': <bound method presence.hjemme of <presence.presence object at 0x746312b0>>, 'attribute': 'state', 'entity': 'device_tracker.samsung_galaxy_s7_edge', 'new_state': 'home', 'old_state': 'not_home', 'kwargs': {'handle': UUID('cf2086b5-a45b-4bb5-989d-510e03f82523')}}
2018-07-24 17:48:12.896426 WARNING AppDaemon: ------------------------------------------------------------
2018-07-24 17:48:12.900825 WARNING AppDaemon: Traceback (most recent call last):
  File "/usr/lib/python3.6/site-packages/appdaemon/appdaemon.py", line 590, in worker
    self.sanitize_state_kwargs(app, args["kwargs"]))
  File "/config/appdaemon/apps/presence.py", line 15, in hjemme
    self.turn_on("input_boolean.house_mode")
  File "/usr/lib/python3.6/site-packages/appdaemon/plugins/hass/hassapi.py", line 22, in func_wrapper
    return func(*args, **kwargs)
  File "/usr/lib/python3.6/site-packages/appdaemon/plugins/hass/hassapi.py", line 330, in turn_on
    self.call_service("homeassistant/turn_on", **rargs)
  File "/usr/lib/python3.6/site-packages/appdaemon/plugins/hass/hassapi.py", line 457, in call_service
    r.raise_for_status()
  File "/usr/lib/python3.6/site-packages/requests/models.py", line 939, in raise_for_status
    raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 401 Client Error: Unauthorized for url: http://hassio/homeassistant/api/services/homeassistant/turn_on
2018-07-24 17:48:12.902024 WARNING AppDaemon: -------------------------------------
I get constant: "Login attempt failed
Login attempt or request with invalid authentication from 172.30.32.2"
Hass.io type: HassOS
OS version? HassOS 1.5,
Hass.io Supervisor version? 118
Beta channel? No
Home Assistant version? .74
Add-on version? .4 Node-Red
When did this issue start occurring? Upon a Restart on Yesterday - 07/23
Is the password used by node-red to connect to the server a weird long token like string? Your password? Or empty? My Password
24 Jul 12:21:03 - [error] [server:Home Assistant1] Home assistant connection failed with error: Connection to home assistant could not be established with config: http://hassio/homeassistant
Trying to find the exact error.
Same issue as @ZStanard (same version numbers etc… as well)
Just done it in an already opened issue.
hi all, im getting this
[error] [server:Home Assistant] Home assistant connection failed with error: Connection to home assistant could not be established with config: http://hassio/homeassistant
It should not be your password. It should not have been changed from the token that was there.
Hi, I also getting the same error. It happened today.
How do you get the token back? I’ve tried multiple things including uninstalling, reinstalling add-on.
Uninstall, delete the node-red-folder in /config and reinstall. The token is stored in that folder as far as I know.
Guys hold on your horses… implementing a more solid fix NOW… (testing)
Update 21:02 (UTC+2): Testing successful. Awaiting new dev builds
Update 21:15 (UTC+2): Dev build succeeded. Second test run…
Update 21:22 (UTC+2): Test went fine. Awaiting release build
Update 21:35 (UTC+2): Done. See release below.
