Home Assistant Community Add-on: phpMyAdmin
It does not start. anymore. I had to go back from 2023.9 to previous version and PhpMyAdmin as well as Advanced SSH & Web Terminal refuses to start anymore.
Log:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
 Add-on: phpMyAdmin
 A web interface for the official MariaDB add-on
 Add-on version: 0.8.7
 You are running the latest version of this add-on.
 System: Home Assistant OS 10.5  (aarch64 / raspberrypi4-64)
 Home Assistant Core: 2023.8.4
 Home Assistant Supervisor: 2023.08.3
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
Log level is set to DEBUG
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-phpmyadmin: starting
s6-rc: info: service init-nginx: starting
[23:38:08] DEBUG: Requested API resource: http://supervisor/services/mysql
[23:38:08] DEBUG: Request method: GET
[23:38:08] DEBUG: Request data: {}
[23:38:08] DEBUG: API HTTP Response code: 200
[23:38:08] DEBUG: API Response: {"result": "ok", "data": {"host": "core-mariadb", "port": 3306, "username": "service", "password": "some_series_of_numbers_and_letters_here", "addon": "core_mariadb"}}
s6-rc: info: service init-nginx successfully started
s6-rc: info: service init-phpmyadmin successfully started
s6-rc: info: service php-fpm: starting
s6-rc: info: service php-fpm successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service legacy-services: starting
[23:38:09] INFO: Starting PHP-FPM...
s6-rc: info: service legacy-services successfully started
[23:38:11] INFO: Starting NGinx....
The spinner just keeps on turning and the web gui does not open. If tried, it just asks to start the addon, but it wont
EDIT: NEVER MIND. Few complete reboots and it seems to start now. However, start is very slow and gui thakes 3 minutes to load. That, however, is an other issue and topic
Same problem, but not the same solution :frowning: When trying to add the " https://github.com/hassio-addons/repository " repository, I get a “Can’t add GitHub - hassio-addons/repository: Home Assistant Community Add-ons, already in the store” and still no PHPadmin in the store.
Any ideas?
hi all - just added the addon and am getting the error below when trying to start it - i’d be grateful for any help please :slight_smile:
 Add-on: phpMyAdmin
 Add-on version: 0.11.0
 System: Home Assistant OS 14.1  (amd64 / qemux86-64)
 Home Assistant Core: 2025.1.4
 Home Assistant Supervisor: 2024.12.3
[19:14:43] ERROR: Got unexpected response from the API: Service not enabled
s6-rc: warning: unable to start service init-phpmyadmin: command exited 128
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.```
Same error here, I’ve been running phpMyAdmin for quite some time, the last time would have been a few months ago and now I’m getting the same ERROR: Got unexpected response from the API: Service not enabled that others are reporting.
I’ll post this here as well since the issue on Github isn’t getting an love: Does anyone know of a fix for this, or an alternative that’ll do the same job? I’ve looked at stuff like Adminer but it’s not clear how to run this under HA.
There's a fix available, it's due to a race condition in phpMyAdmin, see the discussion in the Github issue.
