I’m currently not aware of such a feature.
Great work Just installed this on a NUC.
If i mount my media to the “share” folder (“/shares”) is not available by default they are not visible within Plex. I tried mount --bind and symlink. None of them can be seen by Plex. Any idea?
Or is my mistake in using the /share folder?
(/usr/share/hassio/share)
Hey @frenck… great addon m8!!
Is it possible to have this working with the Plex (media player) Component? Somehow my HA fails to find it and trigger the configurator. I have GDM enabled and custom URL set.
Thanks in advance.
Release v1.0.0
The add-on has been running perfectly since its intial release, and is now STABLE!!!
Changed
- Upgrades hadolint to latest
- Upgrades base image to v2.1.0
- Sets default Shell
- Less aggressive cleanup
- Upgrades Plex Media Server to 1.13.5.5291
- Updates README and links
- Marks add-on stable
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck
Hey Frenck,
Im still seeing this error on the logs and it just wont start
INFO: Starting the Plex Media Server
./run: line 18: /usr/lib/plexmediaserver/Plex Media Server: No such file or directory
That is not how it should be!
I’m sorry. Could you provide me some details?
Right after starting the add-on, a banner will be show, which includes all kinds of system/version information. Will you please share that with me?
This is what i get when it starts.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Hass.io Add-on: Plex Media Server v1.0.0
Recorded media, live TV, online news, and podcasts ready to stream.
By: Franck Nijhof <[email protected]>
aarch64 / HassOS 1.9 / HA 0.76.0 / SU 126 / stable
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 02-updates.sh: executing...
INFO: You are running the latest version of this add-on
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 10-first-run.sh: executing...
[cont-init.d] 10-first-run.sh: exited 0.
[cont-init.d] 20-webtools.sh: executing...
[cont-init.d] 20-webtools.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
@Prathik_Gopal I’ve just noticed you are the same guy that opened the GitHub issue 5 days ago. That issue is still open right? So why push this issue in here as well?
yes i thought you fixed it in this release, it appears not.
I would have closed the issue on GitHub and you would have known before the release.
oh ok, im not active on github as i am here. i just loaded the update and posted that. sorry to post here as well, i thought it was fixed.
Release v1.0.1
Changed
- Upgrades base image to v2.1.1
is it possible to use an external usb storage to stream ?
Hi guys,
I have found something like this:
Would it be helpful to get access to external drives? I am not good at docker so you may to decide, please.
I just installed on odroid c2 on armbian, docker, hassio and now addo plex and it does not start:
aarch64 / Debian GNU/Linux 9 (stretch) / HA 0.78.1 / SU 131 / stable
[cont-init.d] done.
[services.d] done.
Strange I checked and indeed not such directory? This supouse to be a docker container so what went wrong?
This super nice! Just one thing plex is now up to 1.13.8.5395. How do I update this add-on?
The latest version of the add-on is already running that version.
It should be available as an add-on update in Hass.io.
Release v1.1.0
Updated release, with the latest and greatest Plex Media Server.
Unfortunately, I had to drop support for 64 bits HassOS (aarch64).
Changed
- Adds Hassio API security role
- Changed past to paste (#9) (@dayofdoom)
- Upgrades base image to v2.2.0
- Removes support for arm64/aarch64
- Upgrades Plex Media Server to 1.14.0.5470
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck or https://buymeacoff.ee/frenck
Woohoo! Once I setup Hass.io as a VM and free up some disk space, I’ll be sure to check this out.
Release v1.1.1
Changed
- Upgrades Plex Media Server to 1.14.1.5488
- Limit supported machines (#10) (@HoppingMonk)
