Home Assistant Community Add-on: Plex Media Server
:tada: Release v2.1.2
Full Changelog
This is a general maintenance release.
:hammer: Changes
  • :arrow_up: Upgrades add-on base image to v3.1.4
  • :arrow_up: Upgrades Plex to 1.16.4.1469
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck
updated and now getting.
An error occurred loading items to play.
Ideas how to get it working again?
back in 02.18 some plex user had an simalar issue with an update
just started poking around with docker exec -it addon_a0d7b954_plex /bin/bash
easy to fix with restoring an backup :woman_facepalming:
:tada: Release v2.1.3
Full Changelog
:hammer: Changes
  • :arrow_up: Upgrades add-on base image to v3.2.0
  • :arrow_up: Upgrades Plex Media Server to 1.16.5.1488
Why don’t you add the possibility to mount external folder from a NAS for example in the conf of the addon.
Addinig new parameters in the hassio conf and then mounting the folders in the /share via the plex.sh file.
:tada: Release v2.2.0
Full Changelog
:hammer: Changes
  • :arrow_up: Upgrades add-on base image to v4.0.0
  • :arrow_up: Upgrades uuid-runtime to 2.31.1-0.4ubuntu3.4
  • :fire: Removes unneeded access to config folder
  • :arrow_up: Upgrades Plex Media Server to 1.17.0.1709
+1 for the possibility to mount a network drive
Sorry,
I’m not adding that to the add-on, that is going to be a pain. IMHO this should be an Hassio feature.
:tada: Release v2.2.1
Full Changelog
:hammer: Changes
  • :arrow_up: Upgrades Plex Media Server to 1.18.1.1973
I think it is possible to link when using hassio inside docker. Create a docker volume which points to an host-mounted smb/cifs share under raspbian. Or using a plugin such as: http://netshare.containx.io/
Did you find a solution to this? I’ve tried the bind and symlinks also and struggling to make this happen. I’d really love to run Plex as an add-on, but I can never get access to my files when I run it in the add-on. The solution isn’t straightforward in the available documentation.
@Purejet or anyone else getting frustrated with mounting and it under /usr/share/hassio/share and files not appearing in the docker container. I finally had success after adding my video mount to /etc/fstab and rebooting. I could always see my files in the host under my mount, but they would never appear within the docker container. I’m not a docker guru, but I’m guessing it grabs all mount associations at startup. I’m running on an Ubuntu 18.04 running docker. YMMV.
I use the local-persist plugin for Docker to mount my USB HD across multiple containers and it works well once you set it up. I use Portainer to edit each container’s config to include the persistent volume. Works with Plex, though I opted to use the official Plex container here
Nice. Can you also confirm that this works with the Hassio-Addon?
I don’t know if it works with the Hassio addon, but it works with the Plex container I use. You can use Portainer to edit the Plex Hassio addon and include the persistent volume. The Volume settings for my Plex container looks like this (‘media’ is the persistent volume):
I can’t promise it’ll work, but I can confirm it works using Plex’s official Docker container.
:tada: Release v2.2.2
Full Changelog
:hammer: Changes
  • :arrow_up: Upgrades add-on base image to v4.0.2
  • :arrow_up: Upgrades Plex Media Server to 1.18.3.2111
Hi maybe dumb question but.
How do i access my media folder from my NAS? cant figure out how to use the /share folder
I have installed this addon on a hassio rassperrypi
If you are running HassOS, there is no option to mount those folders from remote systems.
alright I see
:tada: Release v2.2.3
Full Changelog
:hammer: Changes
  • :fireworks: Updates maintenance/license year to 2020
  • :pencil2: Funding adjustments
  • :pencil2: Fixes some spelling and grammar
  • :arrow_up: Upgrades add-on base image to v4.0.3
  • :arrow_up: Upgrades Plex Media Server to 1.18.3.2156
  • :books: Adjust add-on installation instructions
https://github.com/sponsors/frenck or https://patreon.com/frenck
:tada: Release v2.2.4
Full Changelog
:hammer: Changes
  • :arrow_up: Upgrades Plex Media Server to 1.18.4.2171
