Home Assistant Community Add-on: Portainer
The add-on only works over ingress, and is indeed not externally available.
Suppose I modify the docker settings for the homeassistant container. Portainer is convenient for such changes. Now, how do I persist this change or backup the container’s new config (a docker-compose.yml would be great).
I looked in the compose directory where portainer stores its docker-compose.yml files, but it is empty.
I have confirmed the portainer container has a persistent disk dir mapped into it, /home/myname/portainer_data:/data
I needed to change the HA container config to map my zigbee usb stick device path, /dev/ttyACM0, into the container for ZHA.
Now I don’t know where this config change is persisted, and I fear it is not persisted at all to disk.
If this is the wrong way of modifying the HA container’s docker settings, please help me with the correct way.
I’m running the officially supported HA install with supervisor container.
I have searched for two days and cannot find any info on why my compose dir has zero docker-compose.yml files or how I should modify the HA container’s docker settings.
Thank you in advance for any help you can provide
If you use a supervised intally you don’t use docker compose at all and you’re right none of those settings will be persistent. You need to do that mapping in the ZHA addon settings.
hi, i’ve tried to upgrade hassio from 32 bit to 64bit yesterday.
On the fresh install i installed portainer, as hassio addon. Then I try to create a new docker container(mbentley/omada-controller:latest-arm64, but i can pick any) and it doesnt work.
i get an error message in portainer : ā€˜object not found inside the database’ and the portainer log says : http error: Unable to proxy the request via the Docker socket (err=Object not found inside the database) (code=500).
I tried it twice with 2 different sd cards, am I doing something wrong or is it broken?
Hi there,
how do you guys backup container and volumes managed by via portainer only? Do you even Backup?
I only backup the config folder. You don’t backup containers. They are disposable.
You mean the portainer container /data folder? How do you backup? With an external script, cron based? Don’t you have non-disposable data in other containers?
Yes I use cron to back the config folder for all containers running from docker (except Home Assistant) Again, there is no data in the container itself. You should map persistent volume when you create the container and that is what you backup.
I’m also seeing this error, not sure how to work around it.
Same error here. Object not found. Brand new install of Portainer add-on on Home Assistant Core running on a NUC.
I think the current portainer addon 1.2.1 is broken. Version 1.2.0. works correctly on my NUC, while 1.2.1 gives the same error as mentioned.
I just tried to deploy seafile via portainer. I used this docker-compose.yaml (slightly modified) to create a new stack:
When trying to deploy, i just get this error:
Deployment error
Unable to deploy stack
When I remove the networks section (lines 43-44) and all other network entries (lines 11-12, 18-19, 40-41) it does deploy correctly. Anyone an idea, whats wrong with the network?
How do you install a specific version of Portainer via the HA addon store? Sorry, I’m new to HA. Thanks.
As far as I know, the only way to install an older version is restoring a snapshot backup. So this only works, if you have a backup of an older version.
I was just about to open an issue on the addons github, seems like frenck is already on it :slight_smile:
Take a look at https://github.com/portainer/portainer/issues/4125
Seems like this has high priority and will be adressed shortly. For now you should probably downgrade and wait for a version >1.2.1
I’m having issues trying to create a container. Previously i had Home Assistant running on on a Virtual Box in Mac with Portainer installed with 3 other containers running.
Decided to move to Raspberry Pi 4B, when i try to create the same Container with images pulled from Docker Hub i get this:
Screenshot 2020-08-09 at 4.59.07 PM
[16:47:56] INFO: Starting Portainer...
[16:47:56] TRACE: bashio::fs.file_exists: /data/hidden
[16:47:56] TRACE: bashio::config.has_value: agent_secret
[16:47:56] TRACE: bashio::config: agent_secret
[16:47:56] TRACE: bashio::jq: /data/options.json if (.agent_secret == null) then
            null
        elif (.agent_secret | type == "string") then
            .agent_secret // empty
        elif (.agent_secret | type == "boolean") then
            .agent_secret // false
        elif (.agent_secret | type == "array") then
            if (.agent_secret == []) then
                empty
            else
                .agent_secret[]
            end
        elif (.agent_secret | type == "object") then
            if (.agent_secret == {}) then
                empty
            else
                .agent_secret
            end
        else
            .agent_secret
        end
2020/08/09 16:47:56 Warning: the --no-auth flag is deprecated and will likely be removed in a future version of Portainer.
2020/08/09 16:47:56 Warning: the --template-file flag is deprecated and will likely be removed in a future version of Portainer.
2020/08/09 16:47:57 Templates already registered inside the database. Skipping template import.
2020/08/09 16:47:57 Instance already has defined endpoints. Skipping the endpoint defined via CLI.
2020/08/09 16:47:57 server: Reverse tunnelling enabled
2020/08/09 16:47:57 server: Fingerprint ec:10:45:22:e6:f0:44:d6:53:68:47:e2:bb:4c:c5:36
2020/08/09 16:47:57 server: Listening on 0.0.0.0:8000...
2020/08/09 16:47:57 Starting Portainer 1.24.1 on 0.0.0.0:1337
2020/08/09 16:47:57 [DEBUG] [chisel, monitoring] [check_interval_seconds: 10.000000] [message: starting tunnel management process]
2020/08/09 16:49:15 http error: Unable to proxy the request via the Docker socket (err=Object not found inside the database) (code=500)
Isn’t that the same issue as described above? It’s being worked on, downgrade to portainer addon v1.2.0 to fix it
My bad didn’t read the last post. How do i downgrade add-on on home assistant?
The easiest way would be to restore a backup and only select the portainer addon, if you have 1.2.0 backed up
Ok thank you, not sure if i still have the backup for 1.2.0. I’ll have to check the dates.
Edit: Don’t have the backup with the previous release, guess I’ll have to wait for it to get fixed.
