ok I did it. thank you!
Decided to migrate from the official Terminal & SSH add-on to this one after learning about nmcli support since Iāve been having some trouble getting adguard set up correctly. Iām run into a couple hiccups in the process I was hoping for advice on
- I used to have an alias in my .profile so I could just type
ssh-hassio
and get in. Part of that alias was a little addition I found to start me in my config folder since thatās usually where I wanted to go (add-t cd config && exec bash -l
to the end for anyone interested). This doesnāt seem to work anymore, it always starts my session in the home folder which is/root
. Is there an alternate way to set the default folder that sessions start at? - I had another snippet called
scp-hassio
that allowed me to easily move files into my hassio config directory from my local machine. It looks likescp
has the same problems assftp
described in the docs though, it only works if you use root as the username. Is there an alternative way I can copy a file over without switching to root as the username? It seems like your addon looks at stdin for input, is there a way to use that to get a oneliner for sending a file to HA I can wrap up in alias? -
I use an app called JuiceSSH on my phone in case I wanted to ssh in and check or tweak something. Looks like that app is behind on security standards though since I now get an āalgorithm negotiation failureā unless I turn on compatibility mode. I donāt really want to do that so has anyone found an android app that does SSH and does support the latest security standards?[UPDATE] Just found Termius which appears to work with compatibility mode off so this one is solved
Looks great though and love the session sharing feature, very cool
OK for some reason my ssh port was removed. I added it again however, before i did i removed the ssh add on and readded it so now my iPad canāt connect because the server host key changed.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] cli: applying...
[fix-attrs.d] cli: exited 0.
[fix-attrs.d] profile: applying...
[fix-attrs.d] profile: exited 0.
[fix-attrs.d] ssh: applying...
[fix-attrs.d] ssh: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] keygen.sh: executing...
[21:24:31] INFO: Generating host keys...
ssh-keygen: generating new host keys: RSA DSA ECDSA ED25519
[cont-init.d] keygen.sh: exited 0.
[cont-init.d] profile.sh: executing...
[cont-init.d] profile.sh: exited 0.
[cont-init.d] ssh.sh: executing...
[21:24:32] INFO: Setup authorized_keys
[cont-init.d] ssh.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[21:24:33] INFO: Starting Web Terminal...
[services.d] done.
[2020/03/17 21:24:33:0285] N: ttyd 1.6.0-c15cfb7 (libwebsockets 3.2.2)
[2020/03/17 21:24:33:0285] N: tty configuration:
[2020/03/17 21:24:33:0286] N: start command: tmux -u new -A -s homeassistant bash -l
[2020/03/17 21:24:33:0286] N: close signal: SIGHUP (1)
[2020/03/17 21:24:33:0286] N: terminal type: xterm-256color
[2020/03/17 21:24:33:0484] N: Using foreign event loop...
[2020/03/17 21:24:33:0492] N: Listening on port: 8099
[21:24:33] WARNING: SSH port is disabled. Prevent start of SSH server.
Make a new one?
Hi i realized that what happened was on my clients i had to removed them from the .ssh/known_hosts folder as the key was different. After that it all worked as a new key was accepted and saved there. All good now! Thank you
Ever since sometime today, without making any changes, I am unable to login to Home Assistant via my zsh (on my MacBook Pro). It seems that port 22 cannot be enabled in the add-on, the hassio supervisor returns the following:
20-03-21 00:03:49 ERROR (SyncWorker_19) [supervisor.docker] Canāt start addon_core_ssh: 500 Server Error: Internal Server Error (ādriver failed programming external connectivity on endpoint addon_core_ssh (5b82e65fd51086499e28f4c2f2d53c983df19f7d4ed98b9835fe54ce30c45d63): Error starting userland proxy: listen tcp 0.0.0.0:22: bind: address already in useā)
This is the add-onās log:
[services.d] done.
[02:09:40] WARNING: SSH port is disabled. Prevent start of SSH server.
[02:09:40] INFO: Starting Web Terminalā¦
[2020/03/21 02:09:40:3486] N: ttyd 1.6.0-c15cfb7 (libwebsockets 3.2.2)
[2020/03/21 02:09:40:3486] N: tty configuration:
[2020/03/21 02:09:40:3487] N: start command: tmux -u new -A -s homeassistant bash -l
[2020/03/21 02:09:40:3490] N: close signal: SIGHUP (1)
[2020/03/21 02:09:40:3490] N: terminal type: xterm-256color
[2020/03/21 02:09:40:3789] N: Using foreign event loopā¦
[2020/03/21 02:09:40:3795] N: Listening on port: 8099
I have restarted all my containers but still the same. I have also tried uninstalling the add-on but it seems that home assistant would not let me to and keeps loading until I close the browser tab and reopen it in another.
Any ideas?
The host will ALREADY be using port 22 so the addon canāt bind to the same port - it actually tells you that in the message. So in the addon pick a different port. I use 622⦠but anything will do.
Hi David,
Thanks for your prompt feedback. I changed the port to 23 and it did work, however I wonder how was I able to access it on the default port (22) before today?
I am running Home Assistant on an OpenMediaVault installation, and I was able to SSH both to the OMV and to the HomeAssistant using the default port with different usernames. What could have changed that does not allow me to do it now? Could it be the network connectivity of the HomeAssistant - it is āHostā and I believe it was set on āHostā before as wellā¦
netstat -tan
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 0.0.0.0:44479 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:2049 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:35717 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:5355 0.0.0.0:* LISTEN
tcp 0 0 192.168.0.137:5357 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:44877 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:50063 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:55669 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:23 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:8123 0.0.0.0:* LISTEN
tcp 0 0 172.30.32.1:63099 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN
tcp 0 0 192.168.0.137:36294 192.168.0.173:23 TIME_WAIT
tcp 0 0 192.168.0.137:42512 122.51.123.203:443 TIME_WAIT
tcp 0 0 172.30.32.1:42902 172.30.33.0:1883 ESTABLISHED
tcp 0 0 192.168.0.137:36320 192.168.0.173:23 TIME_WAIT
tcp 0 0 192.168.0.137:36000 192.168.0.137:23 ESTABLISHED
tcp 0 0 192.168.0.137:48766 3.122.122.135:8080 ESTABLISHED
tcp 0 0 172.30.32.1:8123 172.30.32.2:57040 ESTABLISHED
tcp 0 0 127.0.0.1:39785 127.0.0.1:50474 ESTABLISHED
tcp 0 0 192.168.0.137:36302 192.168.0.173:23 TIME_WAIT
tcp 0 0 192.168.0.137:42514 122.51.123.203:443 TIME_WAIT
tcp 0 0 127.0.0.1:53305 127.0.0.1:1883 ESTABLISHED
tcp 0 0 192.168.0.137:36342 192.168.0.173:23 TIME_WAIT
tcp 0 1568 192.168.0.137:22 192.168.0.121:49951 ESTABLISHED
tcp 0 0 192.168.0.137:36354 192.168.0.173:23 TIME_WAIT
tcp 0 0 192.168.0.137:8123 46.238.53.219:50103 ESTABLISHED
tcp 0 0 192.168.0.137:36330 192.168.0.173:23 TIME_WAIT
tcp 0 0 127.0.0.1:50474 127.0.0.1:39785 ESTABLISHED
tcp 0 0 192.168.0.137:23 192.168.0.137:36000 ESTABLISHED
tcp 0 0 192.168.0.137:42540 122.51.123.203:443 TIME_WAIT
tcp 0 0 192.168.0.137:42510 122.51.123.203:443 TIME_WAIT
tcp 0 0 192.168.0.137:42550 122.51.123.203:443 TIME_WAIT
tcp 0 0 192.168.0.137:55216 52.57.118.192:8080 TIME_WAIT
tcp 0 0 192.168.0.137:42546 122.51.123.203:443 TIME_WAIT
tcp6 0 0 :::8000 :::* LISTEN
tcp6 0 0 :::36673 :::* LISTEN
tcp6 0 0 :::2049 :::* LISTEN
tcp6 0 0 :::9090 :::* LISTEN
tcp6 0 0 :::60935 :::* LISTEN
tcp6 0 0 :::9000 :::* LISTEN
tcp6 0 0 :::5355 :::* LISTEN
tcp6 0 0 :::139 :::* LISTEN
tcp6 0 0 :::111 :::* LISTEN
tcp6 0 0 :::80 :::* LISTEN
tcp6 0 0 :::8883 :::* LISTEN
tcp6 0 0 :::60371 :::* LISTEN
tcp6 0 0 :::8884 :::* LISTEN
tcp6 0 0 :::21 :::* LISTEN
tcp6 0 0 :::22 :::* LISTEN
tcp6 0 0 :::23 :::* LISTEN
tcp6 0 0 :::1883 :::* LISTEN
tcp6 0 0 :::1627 :::* LISTEN
tcp6 0 0 :::43355 :::* LISTEN
tcp6 0 0 :::1884 :::* LISTEN
tcp6 0 0 :::51165 :::* LISTEN
tcp6 0 0 :::445 :::* LISTEN
I wouldnāt use 23 as that is normally reserved for Telnetā¦
Hello, thanks sir.
I am still wondering how I was able to ssh into OMV and HomeAssistant (using different users) on the same portā¦
I am running Home Assistant on an OpenMediaVault installation. What could have changed that does not allow me to do it now? Could it be the network connectivity of the HomeAssistant - it is āHostā and I believe it was set on āHostā before as wellā¦
Hello. I prefer to use bash over zsh. How can I set up a bashrc and bash_aliases and have them sourced upon login of non-root user? A created the files but they do not persist. Thanks
I did a fresh install of Home Assistant/Hassio on a RPi with the 3.13 image and this add-on is not available from the add-on store. (or anything related to SSH)
Has this been removed? I usually recommend setting up SSH as soon as possible in case of braking the WebUI by misstake (even if it is getting harder and harderā¦).
It seems the SSH add-on is now hidden until you enable advanced mode
Click on your name in the lower left corner and enable advanced mode. Then you will probably see it.
Hi! The latest update removed port 22. So far ssh so I connected. Now it says that port 22 is in use. Why? Of course you can rewrite the port, but I want to know what has changed. Thank you
I have just tried to install the addon and it wont start stating;
Bind to port 22 on 0.0.0.0 failed: Address in use.
Bind to port 22 on :: failed: Address in use.
Cannot bind any address.
[cont-finish.d] executing container finish scriptsā¦
[cont-finish.d] 99-message.sh: executingā¦
I do have ssh enabled on the underlying raspbian. Do I need to change that? or am I able to change the add-on port?
You canāt use port 22 for BOTH So set a different port for the addon. I use 622. Then I can ssh 22 for the host (Debian in my case) and 622 for Hassio
David how you set the port on the addon
hmmm feeling stupid ⦠thanks
Is this addon available for 64bit RPI 4? I dont see it on the addon store
